查看: 6312|回复: 10
单片机多点温度采集系统LCD1602+仿真+程序
  多点温度采集系统,仿真+程序   LCD自动切换显示多点温度
#include <AT89X52.h>
#include <Intrins.h>
#define                DATA        P1      //1602驱动端口
//ROM操作命令
#define                 READ_ROM                       0x33                    //读ROM
#define                 SKIP_ROM                       0xCC                    //跳过ROM
#define                 MATCH_ROM               0x55                    //匹配ROM
#define                 SEARCH_ROM              0xF0                    //搜索ROM
#define                 ALARM_SEARCH            0xEC                    //告警搜索
//存储器操作命令
#define                 ANEW_MOVE                     0xB8                    //重新调出E^2数据
#define                 READ_POWER              0xB4                    //读电源
#define                 TEMP_SWITCH             0x44                    //启动温度变换
#define                 READ_MEMORY             0xBE                    //读暂存存储器
#define                 COPY_MEMORY             0x48                    //复制暂存存储器
#define                 WRITE_MEMORY            0x4E                    //写暂存存储器
//数据存储结构
typedef struct tagTempData
        unsigned char                                         btThird;                                                        //百位数据
        unsigned char                                         btSecond;                                                        //十位数据
        unsigned char                                         btFirst;                                                        //个位数据
        unsigned char                                         btDecimal;                                                        //小数点后一位数据
        unsigned char                                        btNegative;                                                        //是否为负数
}TEMPDATA;
TEMPDATA m_TempData;
//引脚定义
sbit                                                         DQ = P2^7;                                                        //数据线端口
sbit                 RS=                P2^0;
sbit                 RW=                P2^1;
sbit                 E=                P2^2;
//DS18B20序列号,通过调用GetROMSequence()函数在P1口读出(读8次)
const unsigned char code ROMData1[8] = {0x28, 0x33, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0xD7};        //U1
const unsigned char code ROMData2[8] = {0x28, 0x30, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0x8E};        //U2
const unsigned char code ROMData3[8] = {0x28, 0x31, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0xB9};        //U3
const unsigned char code ROMData4[8] = {0x28, 0x32, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0xE0};        //U4
const unsigned char code ROMData5[8] = {0x28, 0x34, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0x52};        //U5
const unsigned char code ROMData6[8] = {0x28, 0x35, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0x65};        //U6
const unsigned char code ROMData7[8] = {0x28, 0x36, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0x3C};        //U7
const unsigned char code ROMData8[8] = {0x28, 0x37, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0x0B};        //U8
//判断忙指令
void Busy()
        DATA = 0xff;
        RS = 0;
        RW = 1;
           while(DATA & 0x80)
                E = 0;
                   E = 1;
           E = 0;
//写指令程序
void WriteCommand(unsigned char btCommand)
        Busy();
        RS = 0;
        RW = 0;
        E = 1;
        DATA = btCommand;
        E = 0;
//写数据程序
void WriteData(unsigned char btData)
        Busy();
        RS = 1;
        RW = 0;
        E = 1;
        DATA = btData;
        E = 0;
//清屏显示
void Clear()
        WriteCommand(1);
//初始化
void Init()
        WriteCommand(0x0c);        //开显示,无光标显示
        WriteCommand(0x06);        //文字不动,光标自动右移
        WriteCommand(0x38);        //设置显示模式:8位2行5x7点阵
//显示单个字符
void DisplayOne(bit bRow, unsigned char btColumn, unsigned char btData, bit bIsNumber)
        if (bRow)                 WriteCommand(0xc0 + btColumn);
        else                      WriteCommand(0x80 + btColumn);
        if (bIsNumber)         WriteData(btData + 0x30);
        else                   WriteData(btData);
//显示字符串函数
void DisplayString(bit bRow, unsigned char btColumn, unsigned char *pData)
        while (*pData != '\0')
                   if (bRow) WriteCommand(0xc0 + btColumn);        //显示在第1行
                   else            WriteCommand(0x80 + btColumn);        //显示在第0行
                WriteData(*(pData++));                                                //要显示的数据
                btColumn++;        //列数加一
//延时16us子函数
void Delay16us()
        unsigned char a;
        for (a = 0; a < 4; a++);
//延时60us子函数
void Delay60us()
        unsigned char a;
        for (a = 0; a < 18; a++);
//延时480us子函数
void Delay480us()
        unsigned char a;
        for (a = 0; a < 158; a++);
//延时240us子函数
void Delay240us()
        unsigned char a;
        for (a = 0; a < 78; a++);
//延时500ms子函数
void Delay500ms()
        unsigned char a, b, c;
        for (a = 0; a < 250; a++)
        for (b = 0; b < 3; b++)
        for (c = 0; c < 220; c++);
//芯片初始化
void Initialization()
                DQ = 0;
                Delay480us();                         //延时480us
                DQ = 1;
                Delay60us();                        //延时60us
                if(!DQ)                                  //收到ds18b20的应答信号
                        DQ = 1;
                        Delay240us();                //延时240us
                        break;
//写一个字节(从低位开始写)
void WriteByte(unsigned char btData)
        unsigned char i, btBuffer;
        for (i = 0; i < 8; i++)
                btBuffer = btData >> i;
                if (btBuffer & 1)
                        DQ = 0;
                        _nop_();
                        _nop_();
                        DQ = 1;
                        Delay60us();
                        DQ = 0;
                        Delay60us();
                        DQ = 1;
//读一个字节(从低位开始读)
unsigned char ReadByte()
        unsigned char i, btDest;
                btDest >>= 1;
                DQ = 0;
                _nop_();
                _nop_();
                DQ = 1;
                Delay16us();
                if (DQ) btDest |= 0x80;
                Delay60us();
        return btDest;
//序列号匹配
void MatchROM(const unsigned char *pMatchData)
        unsigned char i;
        Initialization();
        WriteByte(MATCH_ROM);
        for (i = 0; i < 8; i++) WriteByte(*(pMatchData + i));
//得到64位ROM序列(在P1口显示,必须与Proteus联调且在单步调试下才能得到)
/*void GetROMSequence()
        unsigned char i;
        Initialization();
        WriteByte(READ_ROM);
        P1 = ReadByte();
//读取温度值
TEMPDATA ReadTemperature()
        TEMPDATA TempData;
        unsigned int iTempDataH;
        unsigned char btDot, iTempDataL;
        static unsigned char i = 0;
        TempData.btNegative = 0;                                                //为0温度为正
        i++;
        if (i == 9) i = 1;
        Initialization();
        WriteByte(SKIP_ROM);                                                        //跳过ROM匹配
        WriteByte(TEMP_SWITCH);                                                        //启动转换
        Delay500ms();        //调用一次就行
        Delay500ms();
        Initialization();
        //多个芯片的时候用MatchROM(ROMData)换掉WriteByte(SKIP_ROM)
        switch (i)
                case 1 : MatchROM(ROMData1); break;                        //匹配1
                case 2 : MatchROM(ROMData2); break;                        //匹配2
                case 3 : MatchROM(ROMData3); break;                        //匹配3
                case 4 : MatchROM(ROMData4); break;                        //匹配4
                case 5 : MatchROM(ROMData5); break;                        //匹配5
                case 6 : MatchROM(ROMData6); break;                        //匹配6
                case 7 : MatchROM(ROMData7); break;                        //匹配7
                case 8 : MatchROM(ROMData8); break;                        //匹配8
        //WriteByte(SKIP_ROM);                                                        //跳过ROM匹配(单个芯片时用这句换掉上面的switch)
        WriteByte(READ_MEMORY);                                                        //读数据
        iTempDataL = ReadByte();
        iTempDataH = ReadByte();
        iTempDataH <<= 8;
        iTempDataH |= iTempDataL;
        if (iTempDataH & 0x8000)
                TempData.btNegative = 1;
                iTempDataH = ~iTempDataH + 1;                                //负数求补
        //为了省去浮点运算带来的开销,而采用整数和小数部分分开处理的方法(没有四舍五入)
        btDot = (unsigned char)(iTempDataH & 0x000F);        //得到小数部分
        iTempDataH >>= 4;        //得到整数部分
        btDot *= 5;        //btDot*10/16得到转换后的小数数据
        btDot >>= 3;
......部分下载解压包可看全部
全部资料51hei下载地址:
多点温度采集系统LCD1602 仿真 程序.rar (75.72 KB, 下载次数: 217)
参与人数 1黑币 +100 收起 理由
admin + 100 共享资料的黑币奖励!
收藏收藏10 分享淘帖 顶 踩
ID:221028 发表于 2019-1-6 18:18 | 只看该作者
好好好。感谢楼主分享
ID:501495 发表于 2019-3-31 00:04 | 只看该作者
有用感谢楼主分享
ID:454689 发表于 2019-4-21 00:27 | 只看该作者
是51单片机吗?硬件实现不了
ID:711686 发表于 2020-3-21 21:23 | 只看该作者
楼主用的proteus仿真是哪个版本的,我怎么打不开啊
ID:506104 发表于 2020-4-27 13:37 | 只看该作者
用楼主这个程序LCD屏能亮 但是不显示数据 有没有人和我遇到相同的情况?
ID:506104 发表于 2020-4-27 20:12 | 只看该作者
我8.9版可以打开
ID:753342 发表于 2020-5-28 11:07 | 只看该作者
硬件实现不了
ID:768898 发表于 2020-6-4 17:35 | 只看该作者
我也是
ID:772706 发表于 2020-6-8 12:37 来自手机 | 只看该作者
感谢楼主分享
ID:1024251 发表于 2022-5-6 10:31 | 只看该作者
感谢,可惜还是有些没搞懂
