通过按钮可以调整正常时间和闹钟时间
下面是部分代码
// SCK接P32 DIO接 P33 RCK接P34 上电后数码管会显示时钟
#include <AT89X51.H>
#define DISP_WEI P2
typedef unsigned char U8;
typedef unsigned int U16;
sbit KEY1 =P2^4;
sbit KEY2 =P2^5;
sbit KEY3 =P2^6;
sbit KEY4 =P2^7;
U16 tcount;
U8 m;
U8 TIME_HOU_C,TIME_MIN_C,TIME_SEC_C;
U8 TIMER_TEMP,DISP_NUM;
static U8 second,minute,hour;
bit CLOCK_BUFF,CLOCK_FLAG;
bit ADJUST_TIME_FLAG,ADJUST_CLOCK_FLAG;
int bing ;
sbit BEEP = P1^5;
//int mode;//闹钟模式,时间模式 0闹钟 1 时间模式 //2正常模式
U8 code segbit[]={0x80,0x40,0x20,0x10,0x08,0x04,0x02,0x01}; //位选
U8 disbuf[8]={0,0,0,0,0,0,0,0};
U8 ADJUST_TIME[8]={0,0,0,0,0,0,0,0};
U8 code fseg[]={
0xc0, //0
0xf9, //1
0xa4, //2
0xb0, //3
0x99, //4
0x92, //5
0x82, //6
0xf8, //7
0x80, //8
0x90, //9
0x88, //10 A
0x83, //11 B
0xc6, //12 C
0xa1, //13 D
0x86, //14 E
0x8e, //15 F
0x8b, //16 h
0x89, //17 H
0xa3, //18 o
0xc1, //19 u
0xaa, //20 M
0xcf, //21 I
0xc8, //22 N
0xbf , //23 -
0xff , // 24 灭
0x00 // 25 全亮
void Buzzer();
void CLOCK_CALC();
void display();
void init();
void IN_KEY();
void hour_time();
void min();
void sec();
void hour_c();
void min_c();
void sec_c();
void sdata_c();
void DISP_ADJUST_TIME();
//数据传输//
void sdata(void)
unsigned char b,c,num;
if(b==0)
b++;
num=segbit[m];
for(c=0;c<8;c++)
P3_2=0;
P3_3=num&0x80;
num<<=1;
P3_2=1;
if(b==1)
b--;
if((m==2||m==5))
{num=0xbf;}
num=fseg[disbuf[m]];
for(c=0;c<8;c++)
{ P3_2=0;
P3_3=num&0x80;
num<<=1;
P3_2=1;
m++;
if(m==8)
{m=0;
//数据传输//
void sdata_c(void)
if(b==0)
b++;
num=segbit[m];
for(c=0;c<8;c++)
P3_2=0;
P3_3=num&0x80;
num<<=1;
P3_2=1;
if(b==1)
b--;
num = fseg[ADJUST_TIME[m]];
for(c=0;c<8;c++)
{ P3_2=0;
P3_3=num&0x80;
num<<=1;
P3_2=1;
m++;
if(m==8)
{m=0;
//延时0.1ms个单位//
void delay (unsigned char h)
{ while(h--);
//延时0.1ms个单位//
//数据输出//
void out(void)
P3_4=0;
delay(50);
P3_4=1;
//数据输出//
void bcon(void)
disbuf[0]=second%10;
disbuf[1]=second/10;
disbuf[3]=minute%10;
disbuf[4]=minute/10;
disbuf[6]=hour%10;
disbuf[7]=hour/10;
void DISP_ADJUST_TIME(){
sdata_c();
out();
void display(){
bcon();
sdata();
out();
//主函数//
void main(void)
init();
display(); //显示时间
IN_KEY(); //按键
Buzzer(); //闹钟
while(1);
//主函数//
全部资料51hei下载地址:
时钟-闹钟代码.rar
(109.94 KB, 下载次数: 89)
