- #include "macro.h"
- typedef unsigned int u16;
- u16 un;
- uchar buf_Direction; //?????????
- uint set_speed; //?????????
- uchar step_motor_loop[8]={0x01,0x03,0x02,0x06,0x04,0x0C,0x08,0x09};//28byj-48电机时序
- //uchar step_motor_loop[4]={0x09,0x06,0x03,0x0c};//42步进时序
- uchar step_index;
- #define CST_STEP_MOTOR_Z 10 //??
- #define CST_STEP_MOTOR_F 20 //??
- #define CST_STEP_MOTOR_ST 0 //?
- #define fosc_12MHz 12
- #define fosc_24MHz 24
- #define fosc_setting fosc_12MHz
- //????1
- #define CST_TIME_MS 200
- #define CST_TH0 (65536-CST_TIME_MS*fosc_setting/fosc_12MHz)/256
- #define CST_TL0 (65536-CST_TIME_MS*fosc_setting/fosc_12MHz)%256
- uchar buf_SpeedString[]=" ";
- //void iniLCD(void);
- //void list_write_HZ_Str( int x1,int y1, uchar *point ) ;
- void delay(u16 num)
- u16 x,y;
- for(x=num; x>0; x--)
- for(y=110; y>0; y--)
- ;//??1ms
- void step_motor_driver(void)
- static uint speed_delay=0;
- speed_delay++;
- if( buf_Direction==CST_STEP_MOTOR_Z)
- P0=step_motor_loop[step_index];
- if(speed_delay >=set_speed )
- speed_delay =0;
- step_index--;
- if(step_index <=0)
- step_index =7;
- //=================================================转1圈
- un++;
- if(un>=3600)
- un=0;
- step_index=3;
- buf_Direction=0;
- else if( buf_Direction==CST_STEP_MOTOR_F)
- if(speed_delay >=set_speed)
- speed_delay =0;
- step_index++; //??7,????
- if(step_index >7)
- step_index =0;
- un++;
- if(un>=4100)
- un=0;
- step_index=3;
- buf_Direction=0;
- else
- speed_delay =0;
- un=0;
- step_index=3;
- P0=0x00;
- void key_Scan (void)
- static uchar key_loose=0;
- uchar temp=0;
- P1=0XFF;
- temp=P1&0xFF;
- if(key_loose >0)
- if(temp==0xFF)
- key_loose=0;
- return;
- else if(temp !=0xFF)
- key_loose=10;
- temp=P1&0xFF;
- switch(temp)
- case 0xFE:
- buf_Direction=CST_STEP_MOTOR_Z;
- // list_write_HZ_Str(6,20,"??");
- // caluate();
- break;
- case 0xFD:
- buf_Direction=CST_STEP_MOTOR_F;
- // caluate();
- break;
- case 0xFB:
- buf_Direction=CST_STEP_MOTOR_ST;
- // list_write_HZ_Str(6,60," ");
- break;
- case 0xEF:
- if(buf_Direction !=CST_STEP_MOTOR_ST)
- if(set_speed <100)
- set_speed +=5;; //??
- // caluate();
- break;
- case 0xF7:
- if(set_speed >2)
- set_speed -=5; //??
- // caluate();
- break;
- default:
- break; //?????
- void isr_timer0 (void) interrupt 1 using 1
- TH0=CST_TH0;
- TL0=CST_TL0;
- step_motor_driver();
- void init_timer0(void)
- TCON=0x00;
- TMOD=0x00;
- TL0=0x00;
- TH0=0x00;
- TCON=0x00;
- // Timer 0 C/T=0,??????
- //Timer 0 M1,M0=0,1 .work mode 1 www.gdzs.si.gov.cn
- TMOD=0x01; //GATE=0,??????TR0 ?????0 ?C/T=0,??????
- TH0=CST_TH0;
- TL0=CST_TL0;
- TF0=0;//clear 0. count over flag.
- TR0=1;// enable TIMER0 ,start count
- ET0=1; //enable accept interrupt
- void main(void)
- P2=0xff;
- P1=0xff;
- P0=0Xff;
- init_timer0();
- //iniLCD(); //??? LCD
- set_speed=30;
- step_index=3;
- EA=1; //???
- while(1)
- key_Scan();
步进控制.zip
(25.13 KB, 下载次数: 88)
