程序中,也有一些我自己写的注解,仿真图的画法不是那么标准,但是不影响仿真效果,亲测。
本人水平有限,如有错误的地方,希望大家指出,谢谢了
有图有真相:程序 图
仿真 图
- #include<reg51.h>
- #include<intrins.h>
- typedef unsigned char uint8;
- typedef unsigned int uint16;
- typedef unsigned long uint32;
- sbit ADDRC = P1^0;
- sbit ADDRB = P1^1;
- sbit ADDRA = P1^2;//控制138译码器的三个引脚
- sbit I2C_SDA = P2^1;
- sbit I2C_SCL = P2^0;//I2C通信的两个引脚
- bit flag_300ms = 0;//300ms时间标志位
- uint8 T0RH = 0;//定时器高8位初值
- uint8 T0RL = 0;//定时器低8位初值
- uint8 AD_value = 0;//AD值
- uint8 code led_char[] = {0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,
- 0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};//LED段码
- void config_timer0(uint8 ms);
- uint8 get_ADC_vaule(uint8 chn);
- void main()
- config_timer0(1);//初始化通用定时器0,定时1ms
- while(1)
- if(flag_300ms == 1) //判断300ms时间是否到了
- flag_300ms = 0;//清除标志位
- AD_value = get_ADC_vaule(0);//读取通道0的AD值
- void I2C_delay()//I2C延时函数
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- void I2C_start()//I2C起始信号
- I2C_SDA = 1;
- I2C_SCL = 1;
- I2C_delay();
- I2C_SDA = 0;
- I2C_delay();
- I2C_SCL = 0;
- I2C_delay();
- void I2C_stop()//I2C停止信号
- I2C_SDA = 0;
- I2C_SCL = 0;
- I2C_delay();
- I2C_SCL = 1;
- I2C_delay();
- I2C_SDA = 1;
- I2C_delay();
- bit I2C_write(uint8 dat)//I2C写一个字节
- bit ack = 0;
- uint8 mask = 0;
- for(mask=0x80;mask!=0;mask>>=1)
- if((mask&dat) == 0)
- I2C_SDA = 0;
- else
- I2C_SDA = 1;
- I2C_delay();
- I2C_SCL = 1;
- I2C_delay();
- I2C_SCL = 0;
- I2C_delay();
- I2C_SDA = 1;
- I2C_delay();
- I2C_SCL = 1;
- I2C_delay();
- ack = I2C_SDA;
- I2C_delay();
- I2C_SCL = 0;
- I2C_delay();
- return (~ack);
- uint8 I2C_read_ACK()//I2C读一个字节,并发送应答位
- uint8 dat = 0;
- uint8 mask = 0;
- I2C_SDA = 1;
- if(I2C_SDA == 0)
- dat = dat & (~mask);
- else
- dat = dat | mask;
- I2C_delay();
- I2C_SCL = 1;
- I2C_delay();
- I2C_SCL = 0;
- I2C_delay();
- I2C_SDA = 0;
- I2C_delay();
- I2C_SCL = 1;
- I2C_delay();
- I2C_SCL = 0;
- I2C_delay();
- return dat;
- uint8 I2C_read_NACK()//I2C读一个字节,并发送非应答位
- uint8 dat = 0;
- uint8 mask = 0;
- I2C_SDA = 1;
- if(I2C_SDA == 0)
- else
- dat = dat | mask;
- I2C_delay();
- I2C_SCL = 1;
- I2C_delay();
- I2C_SCL = 0;
- I2C_delay();
- I2C_SDA = 1;
- I2C_delay();
- I2C_SCL = 1;
- I2C_delay();
- I2C_SCL = 0;
- I2C_delay();
- return dat;
- uint8 get_ADC_vaule(uint8 chn)//获取AD值
- uint8 value = 0;
- I2C_start();//I2C起始信号
- if(!I2C_write(0X90))//写入PCF8591地址及读写选择位为写
- I2C_stop();
- return 0;
- // I2C_write(0X40 | chn);//写入PCF8591通道0
- I2C_write(0x00 | chn);//写入PCF8591通道0
- I2C_write(0x48<<1 | 0x01);
- I2C_read_ACK();//提供转换所需的时钟信号
- value = I2C_read_NACK();//读取上一次转换的结果
- I2C_stop();//I2C结束信号
- return value;
- void config_timer0(uint8 ms)//配置定时器0的通用函数
- uint32 temp =0 ;
- temp = 11059200/12;
- temp = (temp * ms)/1000;
- temp = 65536 - (temp + 12);
- T0RH = (uint8)(temp >> 8);
- T0RL = (uint8)temp;
- TMOD = TMOD & 0XF0;
- TMOD = TMOD | 0X01;
- TH0 = T0RH;
- TL0 = T0RL;
- EA = 1;
- ET0 = 1;
- TR0 = 1;
- void led_scan()//LED扫描函数,每个1ms扫描一次
- static uint8 index = 0;
- P0 = 0X00;
- switch(index)
- case 0:ADDRC=1;ADDRB=1;ADDRA=1;P0=led_char[AD_value%10];break;
- case 1:ADDRC=1;ADDRB=1;ADDRA=0;P0=led_char[AD_value/10%10];break;
- case 2:ADDRC=1;ADDRB=0;ADDRA=1;P0=led_char[AD_value/100];break;
- default:break;
- index++;
- if(index >= 3)
- index = 0;
- void interrupt_timer0() interrupt 1//定时器0的中断函数
- static uint16 cnt = 0;
- TH0 = T0RH;
- TL0 = T0RL;
- led_scan();
- cnt++;
- if(cnt >= 300)
- cnt = 0;
- flag_300ms = 1;
数码管显示AD值.rar
(91.21 KB, 下载次数: 144)
