查看: 3739|回复: 4
HC6800-ES V2.0单片机DS1302可调电子时钟程序
实现的功能如下(无闹钟功能)。实物图和工程文件在压缩包
制作出来的实物图如下:
1302显示可调时间日期+设置闹钟
  1. //显示格式24-35-25 ,小时-分钟-秒钟, 按下S3后,显示年月日,2017.09.10,延时6秒后返回
  2. #include <reg52.h>
  3. #include <intrins.h>
  5. #define uint unsigned  int
  6. #define sce   timedate[1]
  7. #define min   timedate[2]
  8. #define hour  timedate[3]
  9. #define date  timedate[4]
  10. #define week  timedate[6]
  11. #define month timedate[5]
  12. #define year  timedate[7]
  13. uchar displaychar1[8]={0,1,2,3,4,5,6,7},a,ya,ja ;                                         //a结尾的字符都用来专门延时,a通用,ya日期延时程序用
  14. uchar commandchar[9]={0,0x80,0x82,0x84,0x86,0x88,0x8a,0x8c,0x8e};                  //与timedate对应,分别控制每个寄存器的写,读时数组+1,第8个数是控制写保护位
  15. uchar timedate[8],sdat,seta,m;
  16. bit s,s2,s3,s4,K,setbit,sk;
  17. sbit d = P2^6;
  18. sbit w = P2^7;
  19. sbit S2 = P3^0;
  20. sbit S3 = P3^1;
  21. sbit S4 = P3^2;
  22. sbit SCLK = P3^3;
  23. sbit TIO  = P3^4;
  24. sbit TRST = P3^5;
  25. uchar LD = 1;             //************数码管,亮度调节,0最小,10最高,越亮越闪 因会影响开始信号查询时间,建议最高设置为3**************
  26. unsigned char code duan[]=
  27. {                0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x40,0x00                };           //段选码0-9
  28. void timeout(uchar a)
  29. {
  30.    uchar b;
  31.    for(;a>0;a--)
  32.                 for(b=114;b>0;b--);
  33. }
  34. void timeout5us()
  35. {
  36.         _nop_();
  37. }
  38. void display()                                           //两个数,分别记录键值和重复码个数
  39. {
  40.
  41.         P0 = 0xfe;                                         w = 1;          w = 0;    //显示1位
  42.         P0 = (displaychar1[0]);                d = 1;                 d = 0;
  43.         timeout(LD);
  44.         P0 = 0;                                                d = 1;                d = 0;                                                            //清除段选
  45.
  46.         P0 = 0xfd;                                  w = 1;                 w = 0;    //显示2位
  47.         P0 = displaychar1[1];                 d = 1;                d = 0;
  48.         timeout(LD);
  49.         P0 = 0;                                                d = 1;                d = 0;                                                          //清除段选
  50.         P0 = 0xfb;                                  w = 1;                 w = 0;   //显示3位
  51.         P0 = displaychar1[2];                d = 1;                 d = 0;
  52.         timeout(LD);
  53.         P0 = 0;                                                d = 1;                d = 0;                                                          //清除段选
  54.         P0 = 0xf7;                                        w = 1;                w = 0;   //显示4位
  55.         P0 = displaychar1[3];                d = 1;                 d = 0;
  56.         timeout(LD);
  57.         P0 = 0;                                                d = 1;                d = 0;                                                        //清除段选,否则下一个位选变化后由于段选没变会将此位信息显示到下一个位。
  58.
  59.         P0 = 0xef;                                        w = 1;          w = 0;   //显示5位
  60.         P0 = displaychar1[4];                d = 1;                d = 0;
  61.         timeout(LD);
  62.         P0 = 0;                                                d = 1;                d = 0;                                                          //清除段选
  63.
  64.         P0 = 0xdf;                                         w = 1;                 w = 0;   //显示6位
  65.         P0 = displaychar1[5];                d = 1;                d = 0;
  66.         timeout(LD);
  67.         P0 = 0;                                                d = 1;                 d = 0;                                                  //清除段选
  68.         P0 = 0xbf;                                         w = 1;                w = 0;   //显示7位
  69.         P0 = displaychar1[6];                 d = 1;                 d = 0;
  70.         timeout(LD);
  71.         P0 = 0;                                                d = 1;                 d = 0;                                                  //清除段选
  72.         P0 = 0x7f;                                        w = 1;                w = 0;  //显示8位
  73.         P0 = displaychar1[7];                d = 1;                d = 0;
  74.         timeout(LD);
  75.         P0 = 0;                                                d = 1;                d = 0;                                                        //清除段选,否则下一个位选变化后由于段选没变会将此位信息显示到下一个位。
  76.
  77. }
  78. /************************************************************************************
  79. -------------------------------以下是与时钟芯片的数据时序---------------------------*/
  80. //写控制和一个字节
  81. void sendchar(uchar csdat,uchar sdat)
  82. {        SCLK = 0;
  83.         TRST = 1;
  84.         for(a=0;a<8;a++)
  85.         {
  86.                 SCLK = 0;
  87.                 TIO  = (csdat%2);
  88.                 SCLK = 1;
  89.                 csdat >>=1;
  90.         }
  91.         for(a=0;a<8;a++)
  92.         {
  93.                 SCLK = 0;
  94.                 TIO  = (sdat%2);
  95.                 SCLK = 1;
  96.                 sdat >>=1;
  97.         }
  98.         SCLK = 0;
  99.         TRST = 0;
  100. }
  101. //读一个字节
  102. uchar receviechar(uchar crdat)
  103. {
  104.         uchar rdat;
  105.         TRST = 1;
  106. //        TIO  = 1;
  107.         TRST = 1;
  108.         for(a=0;a<8;a++)
  109.         {
  110.                 SCLK = 0;
  111.                 TIO  = (crdat%2);
  112.                 SCLK = 1;
  113.                 crdat >>=1;
  114.         }
  115.         for(a=0;a<8;a++)
  116.         {
  117.                 SCLK =   1;
  118.                 rdat >>= 1;
  119.                 SCLK =   0;
  120.
  121.                 if(TIO)
  122.                         rdat = rdat|0x80;
  123.         }
  124.         SCLK = 0;        TRST = 0;
  125.         return rdat ;
  126. }
  127. //读取时分秒
  128. void readtime()
  129. {
  130.         sendchar(0x8e,0);
  131.         hour = receviechar(0x85);
  132.         min  = receviechar(0x83);
  133.         sce  = receviechar(0x81);
  134.         sendchar(0x8e,0x80); //
  135.
  136. }
  137. //读取年月日
  138. void readyear()
  139. {
  140.         sendchar(0x8e,0);
  141.         date = receviechar(0x87);
  142.         month  = receviechar(0x89);
  143.         year  = receviechar(0x8d);
  144.         sendchar(0x8e,0x80);         //
  145.
  146. }
  147. //=========================键盘扫描,用定时器延时================================
  148. bit jianpan(K)
  149. {
  150.         if((!K)&TF0)    //如果S2按下且计时器0溢出
  151.                 {
  152.                         TF0 = 0;
  153.                         ja++;
  154.                         if(ja>=2)
  155.                                 {//        P1 = 0;
  156.                                         TR0 = 0;                    //每次按下后都会关闭定时器,后面的程度会检测松手,松开按键后会重新打开定时器,可以保护每次按下只起作用一次
  157.                                         ja = 0;
  158.                                         s = 1;
  159.                                 }
  160.                         return s;
  161.                 }
  162.         return s;
  163. }
  164. //===========================================================================================================
  165. //**********************************************设置时间日期子函数*******************************************
  166. //===========================================================================================================
  167. void settime()
  168. {
  169. //        uchar sdat,seta;
  170. //        bit sk;
  171.         setbit=1;                                           //设置控制标识,进本函数后先就让标识打开,在下面延时跳出前都会一直跳入设置功能函数
  172.         if(TF1&(s2==s3==s4==0))                          //没有按键按下时用定时器1来延时跳出
  173.         {
  174.                 TF1=0;
  175.                 seta ++;
  176.         }
  177.         if(!(s2==s3==s4==0))        seta = 0;        //延时时间超过一定值,或者有按键被按下(注意!这个符号)时,时间会被延长
  178.         if(s3); //P1++;                                                  //P1++无用:调试软件时检测运行的次数
  179.         if(seta>=70)
  180.         {
  181.                 setbit=0;                                          //关闭设置
  182.                 sdat = 0;
  183.         }
  184.         if(sk!=s2)                                              //sk用来做s2的中间暂存数据,用来用来识别S2是否变化过
  185.         {
  186.                 sk = s2;
  187.                 if(s2)
  188.                 sdat ++;                                               //每次进行一次S2动作时才自加一次SDTA
  189.                 if(sdat ==6)sdat=7;                         //跳过星期,本程序不显示星期
  190.         }
  191.         m = timedate[sdat]/16*10+timedate[sdat]%16;                          //m用10进制存下
  192.         if(s3) m--;
  193.         if(s4) m++;
  194.         switch (sdat)                                                   //每次进入设置的对应操作判断
  195.         {
  196.         case 1:
  197.                 if(m>59) m = 0;                                break;
  198.         case 2:
  199.                 if(m>59) m = 0;                                break;
  200.         case 3:
  201.                 if(m>23) m = 0;                                break;
  202.         case 4:
  203.                 if(timedate[5]==4|timedate[5]==6|timedate[5]==9|timedate[5]==11)  //小月
  204.                 {
  205.                         if(m>30) m = 1;                        break;
  206.                 }
  207.                 if(timedate[5]==2&(timedate[7]%4==0))                                                  //闰年2月
  208.                 {
  209.                         if(m>29) m=1;         P1++;                break; //
  210.                 }
  211.                 if(timedate[5]==2&(timedate[7]%4!=0))                                                  //平年2月
  212.                 {
  213.                         if(m>28) m=1;                        break;
  214.                 }
  215.                 if(m>31) m =1;                                break;                                                          //其它月分情况
  216.         case 5:
  217.                 if(m>12) m = 1;                                 break;
  218.         case 6:                 sdat++;                                           //跳过星期本程序不显示星期
  219.                 if(m>7)  m = 1;                                 break;
  220.         case 7:
  221.                 if(m>99) m = 0;                                 break;
  222.         default : /****不在判断范围的进行初始化处理*/
  223.                 sdat = 0; sk=0; setbit = 0;s2 = 0;//        P1++;        //本程序所有P1++都是测试软件运行情况用                                  //每次在不满足条件时自动让数据初始化,
  224.        break;
  225.                                                    //s2=0是优化点,在按下S2后按键标识不会清零,松手时程序已重复运行了很多遍,所以会重新跳回设置的第一位,加本命令可以让设置判断失效,不进设置页。
  226.         }
  227.         //==================================
  228.         //setbit为1则说明以上有成立的条件,需要发送修改数据
  229.         if(setbit)
  230.         {
  231.                 sendchar(0x8e,0);        //去写保护
  232.                 sendchar(commandchar[sdat],m/10*16+m%10);                                                //将改好的数字发送到1302
  233.                 sendchar(0x8e,0x80);        //加写保护
  234.
  235.                 if(seta%5>2&seta<50)
  236.                 timedate[sdat] = 0xbb;        //设置延时操作期间控制闪烁时间
  237.         }                                          //显示空,对应段选的两位11;0xbb/16=11,0xbb%16=11  ,而上面段选数组中第12个数是显示空
  238. //写程序时用的测试语句,无用时未删供复习时看看当时的思路
  239. /*        switch (sdat)
  240.         {
  241.                 case 1:
  242.                 P1=0xfe;
  243.                 m = sce;
  244.                 if(s4) m++;
  245.                 if(s3) m--;
  246.
  247.                            break;
  248.                 case 2:
  249.                 P1=0xfd;                   break;
  250.                 case 3:
  251.                 P1=0xfb;                   break;
  252.                 case 4
  253.                 :P1=0xf7;                   break;
  254.                 case 5:
  255.                 P1=0xef;                   break;
  256.                 case 6:
  257.                 P1=0xdf;                   break;
  258.                 case 7:
  259.                 P1=0xbf;                   break;
  260.                 case 8:
  261.                 P1=0x7f;                   break;
  262.                 default :
  263.                 sdat = 0;sk=0;                                //每次在不满足条件时自动让数据初始化,
  264.                 break;
  265.         } */
  266. }
  267. //===================================================================================
  268. //============================== 主函数==============================================
  269. main()
  270. {
  271.
  272.         SCLK = 0 ;
  273.         TRST = 0 ;
  274.         readyear();        //读取年月日
  275.         if(year!=0x17)        //如果不是2017年,就初始化1302        ,给初值是17年10月03日,12:11:15
  276.         {
  277.                 sendchar(0x8e,0);
  278.                 sendchar(0x80,0x15);
  279.                 sendchar(0x82,0x11);
  280.                 sendchar(0x84,0x12);
  281.
  282.                 sendchar(0x86,0x03);
  283.                 sendchar(0x88,0x10);
  284.                 sendchar(0x8c,0x17);
  285.                 sendchar(0x8e,0x80);
  286.         }
  287.         TMOD = 0x12;                   //设置定时器工作模式
  288.         TR1 = 1;
  289.         TR0 = 1;
  290.         while(1)
  291.         {
  292.                 if(!S2) s2 = jianpan(S2);
  293.                 if(!S3) s3 = jianpan(S3);
  294.                 if(!S4) s4 = jianpan(S4);
  295.
  296.                 TRST = 0;
  297.         /*以下是开始年月日自动归零的问题修改,问题产生原因是开始没有加!setbit这个条件,程序在运行到设置年月日时依然会进
  298.           入下面这个判断,然后再进入设置,但是年月日在这里还没有读数,所以这里的设置就会进入M=0然后加或减,从而让设置值
  299.           出现错误
  300.         */
  301.                 if((!ya&(!setbit)&(!s3))|(setbit&(sdat<4)))                                         //如果S2没有被按下且不在显示年月日的延时范围,而且设置标识为0时,或者在标识为1但是设置值在123中时,则正常显示时间格式
  302.                 {
  303.                         readtime();         //P1++;           //先读一下时间然后再判官设置程序,这样的主要目的是让初m的值由1302决定。
  304.                         if(s2|setbit)                        //按下S2或设置标识打开时会进入本判断
  305.                         {
  306.                                 ya = 0;
  307.                                 settime();
  308.                         }
  309.                         displaychar1[0] = duan[hour/16];
  310.                         displaychar1[1] = duan[hour%16];
  311.                         displaychar1[2] = duan[10];
  312.                         displaychar1[3] = duan[min/16];
  313.                         displaychar1[4] = duan[min%16];
  314. ……………………
  315. …………限于本文篇幅 余下代码请从51黑下载附件…………
单片机DS1302可调电子时钟.rar (214.88 KB, 下载次数: 52)
ID:619942 发表于 2019-12-23 11:17 | 只看该作者
实验程序很方便,就是还没上去试试行不行
自己技术太差了,需要师兄们帮助啊、~~~~~
ID:619942 发表于 2019-12-23 12:53 | 只看该作者
感觉这个程序还是太长了点,不过比我自己写的好很多,说实话,小拜对这些东西了解起来实在是困难
ID:315554 发表于 2020-1-8 10:23 | 只看该作者
谢谢楼主,不错的程序代码,注释详细,如果有个原理图更妙,
ID:737450 发表于 2020-4-25 08:31 | 只看该作者
有点读不懂
