电路原理图如下:
- #include <reg52.h> // 头文件包含
- #include <intrins.h>
- #define uchar unsigned char // 以后unsigned char就可以用uchar代替
- #define uint unsigned int //以后unsigned int就可以用uint 代替
- sfr ISP_DATA = 0xe2; // 数据寄存器
- sfr ISP_ADDRH = 0xe3; // 地址寄存器高八位
- sfr ISP_ADDRL = 0xe4; //地址寄存器低八位
- sfr ISP_CMD = 0xe5; //命令寄存器
- sfr ISP_TRIG = 0xe6; // 命令触发寄存器
- sfr ISP_CONTR = 0xe7; //命令寄存器
- sbit LcdRs_P = P1^2; //1602液晶的RS管脚
- sbit LcdRw_P = P1^3; //1602液晶的RW管脚
- sbit LcdEn_P = P1^4; //1602液晶的EN管脚
- sbit DHT11_P = P1^0; //温湿度传感器DHT11数据接入
- sbit LedTL_P = P3^4; //温度过低报警指示灯
- sbit LedTH_P = P3^5; //温度过高报警指示灯
- sbit LedHL_P = P3^6; //湿度过低报警指示灯
- sbit LedHH_P = P3^7; //湿度过高报警指示灯
- sbit Buzzer_P = P1^1; // 蜂鸣器
- sbit KeySet_P = P1^5; // “设置”按键的管脚
- sbit KeyDown_P = P1^6; // “减”按键的管脚
- sbit KeyUp_P = P1^7; //“加”按键的管脚
- uchar temp; // 保存温度
- uchar humi; // 保存湿度
- uchar AlarmTL; // 温度下限报警值
- uchar AlarmTH; // 温度上限报警值
- uchar AlarmHL; // 湿度下限报警值
- uchar AlarmHH; // 湿度上限报警值
- // 单片机内部EEPROM不使能
- void ISP_Disable()
- ISP_CONTR= 0;
- ISP_ADDRH= 0;
- ISP_ADDRL= 0;
- // 从单片机内部EEPROM读一个字节,从0x2000地址开始
- unsigned char EEPROM_Read(unsigned int add)
- ISP_DATA = 0x00;
- ISP_CONTR= 0x83;
- ISP_CMD = 0x01;
- ISP_ADDRH= (unsigned char)(add>>8);
- ISP_ADDRL= (unsigned char)(add&0xff);
- //对STC89C51系列来说,每次要写入0x46,再写入0xB9,ISP/IAP才会生效
- ISP_TRIG = 0x46;
- ISP_TRIG = 0xB9;
- _nop_();
- ISP_Disable();
- return(ISP_DATA);
- // 往单片机内部EEPROM写一个字节,从0x2000地址开始
- void EEPROM_Write(unsigned int add,unsignedchar ch)
- ISP_CONTR= 0x83;
- ISP_CMD = 0x02;
- ISP_DATA = ch;
- ISP_TRIG = 0x46;
- ISP_TRIG = 0xB9;
- _nop_();
- ISP_Disable();
- // 擦除单片机内部EEPROM的一个扇区
- // 写8个扇区中随便一个的地址,便擦除该扇区,写入前要先擦除
- void Sector_Erase(unsigned int add)
- ISP_CONTR= 0x83;
- ISP_CMD = 0x03;
- ISP_TRIG = 0x46;
- ISP_TRIG = 0xB9;
- _nop_();
- ISP_Disable();
- // 毫秒级的延时函数,time是要延时的毫秒数
- void DelayMs(uint time)
- uinti,j;
- for(i=0;i<time;i++)
- for(j=0;j<112;j++);
- // 1602液晶写命令函数,cmd就是要写入的命令
- void LcdWriteCmd(uchar cmd)
- LcdRs_P = 0;
- LcdRw_P = 0;
- LcdEn_P = 0;
- P0=cmd;
- DelayMs(2);
- LcdEn_P = 1;
- DelayMs(2);
- LcdEn_P = 0;
- // 1602液晶写数据函数,dat就是要写入的命令
- void LcdWriteData(uchar dat)
- LcdRs_P = 1;
- LcdRw_P = 0;
- LcdEn_P = 0;
- P0=dat;
- DelayMs(2);
- LcdEn_P = 1;
- DelayMs(2);
- LcdEn_P = 0;
- // 1602液晶初始化函数
- void LcdInit()
- LcdWriteCmd(0x38); // 16*2显示,5*7点阵,8位数据口
- LcdWriteCmd(0x0C); // 开显示,不显示光标
- LcdWriteCmd(0x06); // 地址加1,当写入数据后光标右移
- LcdWriteCmd(0x01); // 清屏
- // 液晶光标定位函数
- void LcdGotoXY(uchar line,uchar column)
- //第一行
- if(line==0)
- LcdWriteCmd(0x80+column);
- //第二行
- if(line==1)
- LcdWriteCmd(0x80+0x40+column);
- // 液晶输出字符串函数
- void LcdPrintStr(uchar *str)
- while(*str!='\0') //判断是否到字符串的尽头了
- LcdWriteData(*str++);
- // 液晶输出数字
- void LcdPrintNum(uchar num)
- LcdWriteData(num/10+48); // 十位
- LcdWriteData(num%10+48); // 个位
- // 液晶显示内容的初始化
- void LcdShowInit()
- LcdGotoXY(0,0); // 第0行的显示内容
- LcdPrintStr(" DHT11 System ");
- LcdGotoXY(1,0); // 第1行的显示内容
- LcdPrintStr("T: C H: %RH");
- LcdGotoXY(1,4); // 温度单位摄氏度上面的圆圈符号
- LcdWriteData(0xdf);
- // 10us级延时程序
- void Delay10us()
- _nop_(); // 执行一条指令,延时1微秒
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- // 读取DHT11单总线上的一个字节
- uchar DhtReadByte(void)
- bitbit_i;
- ucharj;
- uchardat=0;
- for(j=0;j<8;j++)
- while(!DHT11_P); // 等待低电平结束
- Delay10us(); // 延时
- Delay10us();
- Delay10us();
- if(DHT11_P==1) // 判断数据线是高电平还是低电平
- bit_i=1;
- while(DHT11_P);
- else
- bit_i=0;
- dat<<=1; // 将该位移位保存到dat变量中
- dat|=bit_i;
- return(dat);
- // 读取DHT11的一帧数据,湿高、湿低(0)、温高、温低(0)、校验码
- void ReadDhtData()
- ucharHumiHig; // 湿度高检测值
- ucharHumiLow; // 湿度低检测值
- ucharTemHig; // 温度高检测值
- ucharTemLow; // 温度低检测值
- uchar check; //校验字节
- DHT11_P=0; // 主机拉低20ms
- DelayMs(20);
- DHT11_P=1; // DATA总线由上拉电阻拉高主机延时40us
- Delay10us(); // 延时等待30us
- Delay10us();
- Delay10us();
- while(!DHT11_P); //等待DHT的低电平结束
- while(DHT11_P); //等待DHT的高电平结束
- //进入数据接收状态
- HumiHig= DhtReadByte(); // 湿度高8位
- HumiLow= DhtReadByte(); // 湿度低8为,总为0
- TemHig = DhtReadByte(); // 温度高8位
- TemLow = DhtReadByte(); // 温度低8为,总为0
- check = DhtReadByte(); // 8位校验码,其值等于读出的四个字节相加之和的低8位
- DHT11_P=1; // 拉高总线
- if(check==HumiHig+ HumiLow + TemHig + TemLow) // 如果收到的数据无误
- temp=TemHig; // 将温度的检测结果赋值给全局变量temp
- humi=HumiHig; // 将湿度的检测结果赋值给全局变量humi
- // 是否需要报警判断
- void AlarmJudge(void)
- uchari;
- if(temp>AlarmTH) // 温度是否过高
- LedTH_P=0;
- LedTL_P=1;
- elseif(temp<AlarmTL) // 温度是否过低
- LedTL_P=0;
- LedTH_P=1;
- else //温度正常
- LedTH_P=1;
- LedTL_P=1;
- if(humi>AlarmHH) //湿度是否过高
- LedHH_P=0;
- LedHL_P=1;
- elseif(humi<AlarmHL) // 湿度是否过低
- LedHL_P=0;
- LedHH_P=1;
- else // 湿度正常
- LedHH_P=1;
- LedHL_P=1;
- if((LedHH_P==0)||(LedHL_P==0)||(LedTH_P==0)||(LedTL_P==0)) // 蜂鸣器判断,只要至少1个报警灯亮,蜂鸣器就报警
- for(i=0;i<3;i++)
- Buzzer_P=0;
- DelayMs(100);
- Buzzer_P=1;
- DelayMs(100);
- // 按键扫描,用于设置温湿度报警范围
- void KeyScanf()
- if(KeySet_P==0) //判断设置按键是否被按下
- /*将液晶显示改为设置页面的************************************/
- LcdWriteCmd(0x01); // 设置界面的显示框架
- LcdGotoXY(0,0);
- LcdPrintStr("Temp: - ");
- LcdGotoXY(1,0);
- LcdPrintStr("Humi: - ");
- LcdGotoXY(0,6); //在液晶上填充温度的下限值
- LcdPrintNum(AlarmTL);
- LcdGotoXY(0,9); //在液晶上填充温度的上限值
- LcdPrintNum(AlarmTH);
- LcdGotoXY(1,6); //在液晶上填充湿度的下限值
- LcdPrintNum(AlarmHL);
- LcdGotoXY(1,9); // 在液晶上填充湿度的上限值
- LcdPrintNum(AlarmHH);
- LcdGotoXY(0,7); //光标定位到第0行第7列
- LcdWriteCmd(0x0F); // 光标闪烁
- DelayMs(10); // 去除按键按下的抖动
- while(!KeySet_P); // 等待按键释放
- DelayMs(10); // 去除按键松开的抖动
- /*设置温度的下限值************************************//
- while(KeySet_P) // “设置键”没有被按下,则一直处于温度下限的设置
- if(KeyDown_P==0) //判断 “减按键“是否被按下
- if(AlarmTL>0) //只有当温度下限值大于0时,才能减1
- AlarmTL--;
- LcdGotoXY(0,6); //重新刷新显示更改后的温度下限值
- LcdGotoXY(0,7); //重新定位闪烁的光标位置
- DelayMs(350); //延时
- if(KeyUp_P==0) //判断 “加按键“是否被按下
- if(AlarmTL<99) // 只有当温度下限值小于99时,才能加1
- AlarmTL++;
- LcdGotoXY(0,6); // 重新刷新显示更改后的温度下限值
- LcdGotoXY(0,10);
- /*设置温度的上限值************************************//
- while(KeySet_P) // “设置键”没有被按下,则一直处于温度上限的设置
- if(AlarmTH>0) // 只有当温度上限值大于0时,才能减1
- AlarmTH--;
- LcdGotoXY(0,9); // 重新刷新显示更改后的温度上限值
- LcdGotoXY(0,10); // 重新定位闪烁的光标位置
- if(AlarmTH<99) //只有当温度上限值小于99时,才能加1
- AlarmTH++;
- LcdGotoXY(0,9); //重新刷新显示更改后的温度上限值
- LcdGotoXY(1,7);
- /*设置湿度的下限值************************************//
- while(KeySet_P) // “设置键”没有被按下,则一直处于湿度下限的设置
- if(AlarmHL>0) //只有当湿度下限值大于0时,才能减1
- AlarmHL--;
- LcdGotoXY(1,6); //重新刷新显示更改后的湿度下限值
- LcdGotoXY(1,7); //重新定位闪烁的光标位置
- DelayMs(350);
- if(AlarmHL<99) // 只有当湿度下限值小于99时,才能加1
- AlarmHL++;
- LcdGotoXY(1,6); // 重新刷新显示更改后的湿度下限值
- LcdGotoXY(1,7); // 重新定位闪烁的光标位置
- LcdGotoXY(1,10);
- /*设置湿度的上限值************************************//
- while(KeySet_P) // “设置键”没有被按下,则一直处于湿度上限的设置
- if(AlarmHH>0) // 只有当湿度上限值大于0时,才能减1
- AlarmHH--;
- LcdGotoXY(1,9); // 重新刷新显示更改后的湿度上限值
- LcdGotoXY(1,10); // 重新定位闪烁的光标位置
- DelayMs(350);
- if(KeyUp_P==0) // 判断“加按键“ 是否被按下
- if(AlarmHH<99) //只有当湿度上限值小于99时,才能加1
- AlarmHH++;
- LcdGotoXY(1,9); //重新刷新显示更改后的湿度上限值
- LcdWriteCmd(0x0C); //取消光标闪烁
- LcdShowInit(); //液晶显示为检测界面的
- Sector_Erase(0x2000); //存储之前必须先擦除
- EEPROM_Write(0x2000,AlarmTL); //把温度下限存入到EEPROM的0x2000这个地址
- EEPROM_Write(0x2001,AlarmTH); //把温度上限存入到EEPROM的0x2001这个地址
- EEPROM_Write(0x2002,AlarmHL); //把湿度下限存入到EEPROM的0x2002这个地址
- EEPROM_Write(0x2003,AlarmHH); //把湿度上限存入到EEPROM的0x2003这个地址
- // 主函数
- void main()
- uchari;
- LcdInit(); //液晶功能的初始化
- LcdShowInit(); // 液晶显示的初始化
- AlarmTL=EEPROM_Read(0x2000); // 从EEPROM的0x2000这个地址读取温度的报警下限
- AlarmTH=EEPROM_Read(0x2001); // 从EEPROM的0x2001这个地址读取温度的报警上限
- AlarmHL=EEPROM_Read(0x2002); // 从EEPROM的0x2002这个地址读取湿度的报警下限
- AlarmHH=EEPROM_Read(0x2003); // 从EEPROM的0x2003这个地址读取湿度的报警上限
- while(1)
- ReadDhtData(); //检测温湿度数据
- LcdGotoXY(1,2); //定位到要显示温度的地方
- LcdPrintNum(temp); // 显示温度值
- LcdGotoXY(1,11); // 定位到要显示湿度的地方
- LcdPrintNum(humi); // 显示湿度值
- AlarmJudge(); // 判断并根据需要报警
- for(i=0;i<25;i++)
- KeyScanf(); // 按键扫描
- DelayMs(20); //延时
