#include<reg51.h>
#include<intrins.h>
#include <absacc.h>
#define uint unsigned int
#define BUSY 0x80
#define DATAPORT P0
#define PLAYE_ADDR XBYTE[0XBFFF]
sbit RED_ALARM=P1^0;
sbit WRITE_ALARM=P1^1;
sbit GREEN_ALARM=P1^2;
sbit P1_4=P1^4;
sbit P1_5=P1^5;
sbit P1_6=P1^6;
sbit DQ = P1^7;
sbit LCM_RS=P2^0;
sbit LCM_RW=P2^1;
sbit LCM_EN=P2^2;
sbit ad_busy=P3^2;
sbit RECLED_EOC=P3^5;
sbit OUT=P3^7;
uchar ad_data;
uchar seconde=0;
uchar minite=0;
uchar hour=12;
uchar mstcnt=0;
uchar temp1,temp2,temp;
uchar t,set;
uchar K;
bit ON_OFF=0;
bit outflag;
uchar code str0[]={"--- : : --- "};
uchar code str1[]={"SET: C SA: . C"};
void delay_LCM(uint);
void initLCM( void);
void lcd_wait(void);
void WriteCommandLCM(uchar WCLCM,uchar BusyC);
void WriteDataLCM(uchar WDLCM);
void DisplayOneChar(uchar X,uchar Y,uchar DData);
void DisplayListChar(uchar X,uchar Y,uchar code *DData);
void init_timer0(void);
void displayfun1(void);
void displayfun2(void);
void displayfun3(void);
void displayfun4(void);
void keyscan(void );
void set_adj(void);
void inc_key(void);
void dec_key(void);
void delay_18B20(unsigned int i);
void Init_DS18B20(void) ;
uchar ReadOneChar(void);
void WriteOneChar(unsigned char dat);
void ReadTemperature(void);
void ad0809(void);
void playalarm(void);
void delay_LCM(uint k)
uint i,j;
for(i=0;i<k;i++)
for(j=0;j<60;j++)
if(BusyC)lcd_wait();
DATAPORT=WCLCM;
LCM_RS=0;
LCM_RW=0;
LCM_EN=1;
_nop_();
_nop_();
_nop_();
LCM_EN=0;
lcd_wait( );
DATAPORT=WDLCM;
LCM_RS=1;
LCM_RW=0;
LCM_EN=1;
_nop_();
_nop_();
_nop_();
LCM_EN=0;
void lcd_wait(void)
DATAPORT=0xff;
LCM_EN=1;
LCM_RS=0;
LCM_RW=1;
_nop_();
while(DATAPORT&BUSY)
{ LCM_EN=0;
_nop_();
_nop_();
LCM_EN=1;
_nop_();
_nop_();
LCM_EN=0;
void initLCM( )
DATAPORT=0;
delay_LCM(15);
WriteCommandLCM(0x38,0); //三次显示模式设置,不检测忙信号
delay_LCM(5);
delay_LCM(5);
delay_LCM(5);
WriteCommandLCM(0x38,1); //8bit数据传送,2行显示,5*7字型,检测忙信号
WriteCommandLCM(0x08,1); //关闭显示,检测忙信号
WriteCommandLCM(0x01,1); //清屏,检测忙信号
WriteCommandLCM(0x06,1); //显示光标右移设置,检测忙信号
WriteCommandLCM(0x0c,1); //显示屏打开,光标不显示,不闪烁,检测忙信号
uchar ListLength=0;
Y&=0x01;
X&=0x0f;
while(X<16)
DisplayOneChar(X,Y,DData[ListLength]);
ListLength++;
X++;
while(i--);
unsigned char x=0;
DQ = 1; //DQ复位
delay_18B20(8); //稍做延时
DQ = 0; //单片机将DQ拉低
delay_18B20(80); //精确延时 大于 480us
DQ = 1; //拉高总线
delay_18B20(14);
x=DQ; //稍做延时后 如果x=0则初始化成功 x=1则初始化失败
delay_18B20(20);
/***********ds18b20读一个字节**************/
unsigned char ReadOneChar(void)
uchar i=0;
uchar dat = 0;
for (i=8;i>0;i--)
DQ = 0; // 给脉冲信号
dat>>=1;
DQ = 1; // 给脉冲信号
if(DQ)
dat|=0x80;
delay_18B20(4);
return(dat);
/*************ds18b20写一个字节****************/
void WriteOneChar(uchar dat)
unsigned char i=0;
for (i=8; i>0; i--)
DQ = 0;
DQ = dat&0x01;
delay_18B20(5);
DQ = 1;
dat>>=1;
DisplayListChar(0,0,str0);
DisplayListChar(0,1,str1);
DisplayOneChar(3,0,hour/10+0x30); //液晶上显示小时
DisplayOneChar(4,0,hour%10+0x30);
DisplayOneChar(6,0,minite/10+0x30); //液晶上显示分
DisplayOneChar(7,0,minite%10+0x30);
DisplayOneChar(9,0,seconde/10+0x30); //液晶上显示秒
DisplayOneChar(10,0,seconde%10+0x30);
DisplayOneChar(4,1,K/10+0x30); //液晶上显示设定的温度
DisplayOneChar(5,1,K%10+0x30);
DisplayOneChar(11,1,temp1/10+0x30); //液晶上显示测得的温度
DisplayOneChar(12,1,temp1%10+0x30);
DisplayOneChar(14,1,temp2/10+0x30);
if(ON_OFF==0) //若温控标志为0
DisplayOneChar(14,0,0x4f); // 液晶上显示不控温的标志
DisplayOneChar(15,0,0x46);
DisplayOneChar(14,0,0x4f); // 液晶上显示控温的标志
DisplayOneChar(15,0,0x4e);
if(outflag==1)
DisplayOneChar(0,0,0x7c);
DisplayOneChar(0,0,0xef);
WriteCommandLCM(0x0f,1); //显示屏打开,光标显示,闪烁,检测忙信号
/**************键盘扫描子函数******************/
void keyscan(void)
uchar xx; //局部变量
P1=0xff;
if(P1!=0xff)
delay_LCM(50);
if(P1!=0xff)
xx=P1;
switch(xx) // 根据按键状态,调用不同的子函数
case 0xfe:set_adj(); break;
case 0xfd:inc_key(); break;
case 0xfb:dec_key(); break;
case 0xf7:ON_OFF=!ON_OFF; break;
default:break;
/**************设定工作模式子函数****************/
void set_adj(void)
delay_LCM(100);
set++;
if(set>=4)set=0;
/****************按键加法子函数******************/
void inc_key(void)
delay_LCM(100);
switch(set)
case 0:if(P1==0xf7)ON_OFF=!ON_OFF; break;
case 1:hour++; if(hour>=23)hour=23; break;
case 2:minite++; if(minite>=59)minite=59;break;
case 3:K++;if(K>=99)K=99; break;
default:break;
/****************按键减法子函数*****************/
void dec_key(void)
delay_LCM(100);
switch(set)
case 1:hour--; if(hour<=0)hour=0; break;
case 2:minite--;if(minite<=0)minite=0;break;
case 3:K--;if(K<=1)K=1; break;
default:break;
/***************定时器t0初始化*******************/
TMOD=0x01; //time0为定时器,方式1
TH0=0x3c; //预置计数初值
TL0=0xb0;
EA=1;
ET0=1;
TR0=1;
void main(void)
P1=0xff; //初始化p1口,全设为1
delay_LCM(500); //延时500ms启动
initLCM( ); //LCD初始化
init_timer0( ); //时钟定时器0初始化
Init_DS18B20( ) ; //DS18B20初始化
while (1)
keyscan(); //按键扫描
ReadTemperature(); //温度采集
switch(set) //LCD根据工作模式显示
case 0:displayfun1();delay_LCM(1000);break; //正常工作显示
case 1:displayfun2();delay_LCM(1000);break; //调整时显示
case 2:displayfun3();delay_LCM(1000);break; //调整分显示
case 3:displayfun4();delay_LCM(1000);break; //温度设定
default:break;
keyscan( ); //相当于延时
if(ON_OFF==1) //若温控标志位1, 控制LAMP动作
if(temp1>=K+1){outflag=1;OUT=0;}
if(temp1<K)
delay_LCM(1000);
if(temp1<K){outflag=0;OUT=1;} //
else{outflag=0;OUT=1;}
LCD1602温控带时间.rar
(21.11 KB, 下载次数: 25)
