查看: 3097|回复: 0
C8051F020串口通讯 IO口测试 流水灯闪烁灯等实例程序
C8051F020实例
  2. /********************************************************************************************************************************************
  3. /***                                        C8051F120开发板实验:        5. 串口通讯实验
  4. /***
  5. /***          说明: 本实验采用UART0输出数据到PC机  实验时将跳线帽接至+3V 复位一次,单片机发送256个数据 波特率为115200
  6. /***                        推荐使用本店EC5进行下载和调试
  7. /*** 开发环境:        C8051F120最小系统板、EC5调试器、Keil uVision2
  8. *********************************************************************************************************************************************/
  9. #include <c8051f120.h>
  10. #define uchar unsigned char
  11. #define uint unsigned int
  12. #define SYSCLK      100000000UL               // SYSCLK frequency in Hz
  13. #define BAUDRATE    115200                          // Baud rate of UART in bps
  14. sfr16 RCAP2  = 0xCA;            /* TIMER 2 CAPTURE REGISTER - LOW BYTE          */
  15. sfr16 TMR2   = 0xCC;            /* TIMER 2 - LOW BYTE                           */
  16. void SYSCLK_Init();
  17. void PORT_Init();
  18. void UART0_Init();
  19. void SYSCLK_Init()
  20. {
  21.     uint i = 0;
  22.     SFRPAGE   = CONFIG_PAGE;
  23.     OSCXCN    = 0x67;
  24.     for (i = 0; i < 3000; i++);  // Wait 1ms for initialization
  25.     while ((OSCXCN & 0x80) == 0);
  26.     PLL0CN    = 0x04;
  27.     CCH0CN   &= ~0x20;
  28.     SFRPAGE   = LEGACY_PAGE;
  29.     FLSCL     = 0xB0;
  30.     SFRPAGE   = CONFIG_PAGE;
  31.     CCH0CN   |= 0x20;
  32.     PLL0CN   |= 0x01;
  33.     PLL0DIV   = 0x01;
  34.     PLL0FLT   = 0x01;
  35.     PLL0MUL   = 0x04;                        // 4倍倍频 -> 100MHz
  36.     for (i = 0; i < 15; i++);          // Wait 5us for initialization
  37.     PLL0CN    |= 0x02;
  38.     while ((PLL0CN & 0x10) == 0);
  39.     CLKSEL    = 0x02;
  40. }
  41. void PORT_Init()
  42. {
  43.     SFRPAGE  = CONFIG_PAGE;                // 寄存器页配置
  44.     XBR0     = 0x04;                        // RART0: EN
  45.     XBR2     = 0x40;                        // 全局弱上拉使能
  46.         P0MDOUT  = 0xFF;
  47. }
  48. void UART0_Init()
  49. {
  50.         uchar SFRPAGE_SAVE = SFRPAGE;
  51.         SFRPAGE = UART0_PAGE;
  52.            SCON0   = 0x50;               // SCON0: mode 1, 8-bit UART, enable RX
  53.         SSTA0   = 0x15;
  54.         SFRPAGE = TMR2_PAGE;
  55.         TMR2CN  = 0x00;
  56.         TMR2CF  = 0x08;
  57.         RCAP2   = -((uint)(SYSCLK / BAUDRATE) >> 4);
  58.         TMR2    = RCAP2;
  59.         TR2     = 1;
  60.         EA      = 1;
  61.         SFRPAGE = SFRPAGE_SAVE;
  62. }
  63. void main()
  64. {
  65.         uchar SFRPAGE_SAVE;
  66.         uint i;
  67.         WDTCN=0XDE;
  68.         WDTCN=0XAD;
  69.         SYSCLK_Init();
  70.         PORT_Init();
  71.         UART0_Init();
  72.         for(i=0;i<256;i++)
  73.         {
  74.                 SFRPAGE = UART0_PAGE;
  75.                 SBUF0=i;
  76.                 while(!TI0);
  77.                 TI0=0;
  78.                 SFRPAGE = SFRPAGE_SAVE;
  79.         }
  80.         while(1);
  81. }
C8051F120例程.rar (59.57 KB, 下载次数: 34)
参与人数 2黑币 +62 收起 理由
YJGG + 12 赞一个!
收藏收藏1 分享淘帖 顶 踩
