宝上的,给大家共享
- #include <reg52.h> //调用单片机头文件
- #define uchar unsigned char //无符号字符型 宏定义 变量范围0~255
- #define uint unsigned int //无符号整型 宏定义 变量范围0~65535
- #include "ds1302.h"
- //数码管段选定义 0 1 2 3 4 5 6 7 8 9
- uchar code smg_du[]={0xa0,0x75,0x32,0x2a,0x32,0x25,0xb4,0xBa,0x20,0x28,
- 0x30,0x25,0xe4,0x23,0x64,0x74,0xff}; //断码
- //数码管位选定义
- uchar code smg_we[]={0xfe,0xbf,0xfb,0xef,0xf7,0xdf,0xfd,0x7f};//数码管位选定义
- uchar dis_smg[8] = {0xa0,0xbb,0x62,0x2a,0x39,0x2c,0x24,0xBa};
- uchar smg_i = 8; //显示数码管的个位数
- bit flag_200ms ;
- bit flag_100ms ;
- bit flag_500ms; //500ms标志位
- sbit beep = P3^7; //蜂鸣器定义
- bit flag_beep_en;
- uint clock_value; //用作闹钟用的
- uchar flag_s = 0x03;//控制数码管闪烁的变量
- sbit dq = P3^1; //18b20 IO口的定义
- uint temperature ; //温度变量
- uchar flag_nl; //农历 阳历显示标志位
- uchar menu_1,menu_2,menu_i;
- sbit dat0 = B^0;
- sbit dat1 = B^1;
- sbit dat2 = B^2;
- sbit dat3 = B^3;
- sbit dat4 = B^4;
- sbit dat5 = B^5;
- sbit dat6 = B^6;
- sbit dat7 = B^7;
- //控制数码管闪烁的函数
- void smg_s(uchar dat)
- B = dat;
- if(dat0 == 1)
- dis_smg[0] = 0xff;
- if(dat1 == 1)
- dis_smg[1] = 0xff;
- if(dat2 == 1)
- dis_smg[2] = 0xff;
- if(dat3 == 1)
- dis_smg[3] = 0xff;
- if(dat4 == 1)
- dis_smg[4] = 0xff;
- if(dat5 == 1)
- dis_smg[5] = 0xff;
- if(dat6 == 1)
- dis_smg[6] = 0xff;
- if(dat7 == 1)
- dis_smg[7] = 0xff;
- /***********************延时函数************************/
- void delay_uint(uint q)
- while(q--);
- /***********************1ms延时函数*****************************/
- void delay_1ms(uint q)
- uint i,j;
- for(i=0;i<q;i++)
- for(j=0;j<120;j++);
- /********************独立按键程序*****************/
- uchar key_can; //按键值
- void key() //独立按键程序
- static uchar key_new;
- key_can = 20; //按键值还原
- P3 |= 0x78; //对应的按键IO口输出为1
- if((P3 & 0x78) != 0x78) //按键按下
- delay_1ms(1); //按键消抖动
- if(((P3 & 0x78) != 0x78) && (key_new == 1))
- { //确认是按键按下
- key_new = 0;
- switch(P3 & 0x78)
- case 0xe0: key_can = 1; break; //得到按键值
- case 0x68: key_can = 2; break; //得到按键值
- case 0x58: key_can = 3; break; //得到按键值
- case 0x98: key_can = 4; break; //得到按键值
- else
- key_new = 1;
- #include "menu.h"
- /************菜单处理函数****************/
- void menu_dis()
- if((menu_1 > 0) && (menu_2 == 0)) //选择键面
- if(flag_500ms == 1)
- dis_smg[0] = smg_du[1]; //1
- dis_smg[1] = smg_du[10]; //A
- dis_smg[2] = smg_du[2]; //2
- dis_smg[3] = smg_du[10]; //A
- dis_smg[4] = smg_du[3]; //3
- dis_smg[5] = smg_du[10]; //A
- dis_smg[6] = smg_du[4]; //4
- dis_smg[7] = smg_du[10]; //A
- smg_i = 8;
- else
- smg_s(flag_s);
- if((menu_1 == 1) && (menu_2 > 0)) //选设置时 分 秒
- smg_i = 8;
- dis_smg[0] = smg_du[miao % 16]; //显示秒
- dis_smg[1] = smg_du[miao / 16]; //
- dis_smg[2] = 0x7f;
- dis_smg[3] = smg_du[fen % 16]; //显示分
- dis_smg[4] = smg_du[fen / 16]; //
- dis_smg[5] = 0x7f;
- dis_smg[6] = smg_du[shi % 16]; //显示秒
- dis_smg[7] = smg_du[shi / 16]; //
- else
- smg_s(flag_s);
- if((menu_1 == 2) && (menu_2 > 0)) //选设置年 月 日
- smg_i = 8;
- dis_smg[0] = smg_du[ri % 16]; //显示日
- dis_smg[1] = smg_du[ri / 16]; //
- dis_smg[3] = smg_du[yue % 16]; //显示月
- dis_smg[4] = smg_du[yue / 16]; //
- dis_smg[6] = smg_du[nian % 16]; //显示年
- dis_smg[7] = smg_du[nian / 16]; //
- if((menu_1 == 3) && (menu_2 > 0)) //设置星期 和 闹钟的开和关
- smg_i = 8;
- dis_smg[0] = smg_du[week % 16]; //显示星期
- dis_smg[1] = smg_du[week / 16]; //
- if(open1 == 1) //开闹钟
- dis_smg[3] = 0xb0; //OPEN
- dis_smg[4] = 0x64;
- dis_smg[5] = 0x70;
- dis_smg[6] = 0xa0;
- }else
- dis_smg[3] = 0x74; //OFF
- dis_smg[4] = 0x74;
- dis_smg[5] = 0xa0;
- dis_smg[6] = 0xFF;
- if((menu_1 == 4) && (menu_2 > 0)) //选设置时 分 秒
- smg_i = 8;
- dis_smg[0] = 0xff; //
- dis_smg[1] = 0xff; //
- dis_smg[2] = smg_du[fen1 % 16]; //显示分
- dis_smg[3] = smg_du[fen1 / 16]; //
- dis_smg[4] = 0x7f;
- dis_smg[5] = smg_du[shi1 % 16]; //显示秒
- dis_smg[6] = smg_du[shi1 / 16]; //
- /*************闹钟报警函数***************/
- void clock_dis()
- static uchar mm,value;
- if(flag_100ms == 1) //100ms执行一次
- flag_100ms = 0;
- if(open1 == 1) //如果闹钟打开
- if((miao == 0) && (fen == fen1) && (shi == shi1))
- flag_beep_en = 1; //有报警 打开蜂鸣器响的标志位
- if(flag_beep_en == 1) //闹钟以被打开
- clock_value++;
- if(clock_value <= 30)
- beep = ~beep; //蜂鸣器叫3秒
- else if(clock_value > 30)
- beep = 1; //蜂鸣器停1秒
- if(clock_value > 40)
- clock_value = 0;
- /*************定时器0初始化程序***************/
- void time_init()
- EA = 1; //开总中断
- TMOD = 0X01; //定时器0、工作方式1
- ET0 = 1; //开定时器0中断
- TR0 = 1; //允许定时器0定时
- /***********************18b20初始化函数*****************************/
- void init_18b20()
- bit q;
- dq = 1; //把总线拿高
- delay_uint(1); //15us
- dq = 0; //给复位脉冲
- delay_uint(80); //750us
- dq = 1; //把总线拿高 等待
- delay_uint(10); //110us
- q = dq; //读取18b20初始化信号
- delay_uint(20); //200us
- dq = 1; //把总线拿高 释放总线
- /*************写18b20内的数据***************/
- void write_18b20(uchar dat)
- uchar i;
- for(i=0;i<8;i++)
- { //写数据是低位开始
- dq = 0; //把总线拿低写时间隙开始
- dq = dat & 0x01; //向18b20总线写数据了
- delay_uint(5); // 60us
- dq = 1; //释放总线
- dat >>= 1;
- /*************读取18b20内的数据***************/
- uchar read_18b20()
- uchar i,value;
- for(i=0;i<8;i++)
- dq = 0; //把总线拿低读时间隙开始
- value >>= 1; //读数据是低位开始
- dq = 1; //释放总线
- if(dq == 1) //开始读写数据
- value |= 0x80;
- delay_uint(5); //60us 读一个时间隙最少要保持60us的时间
- return value; //返回数据
- /*************读取温度的值 读出来的是小数***************/
- uint read_temp()
- uint value;
- uchar low; //在读取温度的时候如果中断的太频繁了,就应该把中断给关了,否则会影响到18b20的时序
- init_18b20(); //初始化18b20
- write_18b20(0xcc); //跳过64位ROM
- write_18b20(0x44); //启动一次温度转换命令
- delay_uint(50); //500us
- write_18b20(0xbe); //发出读取暂存器命令
- EA = 0;
- low = read_18b20(); //读温度低字节
- value = read_18b20(); //读温度高字节
- EA = 1;
- value <<= 8; //把温度的高位左移8位
- value |= low; //把读出的温度低位放到value的低八位中
- value *= 0.625; //转换到温度值 小数
- return value; //返回读出的温度 带小数
- /*************时钟显示***************/
- void init_1602_ds1302()
- static uchar value;
- smg_i = 8;
- value ++;
- if(value <= 5*2) //2秒
- dis_smg[2] = 0x3f;
- dis_smg[5] = 0x3f;
- else if(value <= 5*4) //2秒
- else if(value <= 5*6) //2秒
- dis_smg[3] = smg_du[12];
- dis_smg[4] = smg_du[temperature % 10] ; //
- dis_smg[6] = smg_du[temperature / 100 % 10];
- else
- value = 0;
- /*****************主函数********************/
- void main()
- init_ds1302(); //ds1302初始化
- time_init(); //定时器初始化
- init_menu();
- while(1)
- key(); //按键程序
- if(key_can < 10)
- key_with();
- if(flag_200ms == 1)
- flag_200ms = 0;
- if(menu_1 == 0)
- read_time(); //读时间
- temperature = read_temp(); //先读出温度的值
- init_1602_ds1302(); //显示时钟
- menu_dis(); //设置的对应的显示处理
- clock_dis(); //闹钟报警函数
- delay_1ms(1);
- /*************定时器0中断服务程序***************/
- void time0_int() interrupt 1
- static uint value;
- static uchar ii;
- TH0 = 0xF8;
- TL0 = 0x30; // 2ms 12M
- value ++;
- if((value % 50) == 0) //100ms
- flag_100ms = 1;
- if(value >= 250)
- value = 0;
- flag_500ms = ~flag_500ms;
- P0 = 0xff; //消隐
- P2 = smg_we[ii]; //位选
- P0 = dis_smg[ii]; //段选
- ii++;
- if(ii >= smg_i)
- ii = 0;
单片机万年历数码管显示 发送资料 SMG.7z
(3.28 MB, 下载次数: 90)
