查看: 1697|回复: 0
51单片机+AD0809怎么样实现多路采集和发送 求帮助
不知道protues的原理图和程序是否配套
  1. #include"reg51.h"
  2. #include <intrins.h>
  3. #include<stdio.h>
  4. typedef unsigned int u16;          //对数据类型进行声明定义
  5. typedef unsigned char u8;
  6. #define uint unsigned int
  7. #define uchar unsigned char
  8. uchar code LEDData[]=
  9. {0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
  10. sbit LSA=P2^2;
  11. sbit LSB=P2^3;
  12. sbit LSC=P2^4;
  13. sbit OE  = P1^0;
  14. sbit EOC = P1^1;
  15. sbit ST  = P1^2;
  16. sbit CLK = P1^3;
  17. sbit ADDA = P1^4;
  18. sbit ADDB = P1^5;
  19. sbit ADDC = P1^6;
  20. sbit LED=P1^7;
  21. u8 weixuan[4];
  22. uint temp;
  23. uchar getdata;
  24. uchar b;
  25. uchar s;
  26. uchar g;
  27. void delayus(uchar us)
  28. {
  29. uchar i;
  30. while(us--)
  31. for(i=0;i<120;i++);
  32. }
  33. void init()
  34. {
  35. TMOD=0x21;
  36. TH0=(65536-200)/256;
  37. TL0=(65536-200)%256;
  38. TH1=0XF3;
  39. TL1=0XF3;
  40. PCON=0X80;
  41. SCON=0X50;
  42. ES=1;
  43. ET0=1;
  44. EA=1;
  45. TR1=1;
  46. TR0=1;
  47. }
  48. void TImer0()interrupt 1
  49. { TH0=(65535-200)/256;
  50. TL0=(65535-200)%256;
  51. CLK=~CLK;
  52. }
  53. void DigDisplay()
  54. {
  55.         u8 i;
  56.         for(i=0;i<4;i++)
  57.         {
  58.                 switch(i)         //位选,选择点亮的数码管,
  59.                 {
  60.                         case(0):
  61.                                 LSA=0;LSB=0;LSC=0; break;//显示第0位
  62.                         case(1):
  63.                                 LSA=1;LSB=0;LSC=0; break;//显示第1位
  64.                         case(2):
  65.                                 LSA=0;LSB=1;LSC=0; break;//显示第2位
  66.                         case(3):
  67.                                 LSA=1;LSB=1;LSC=0; break;//显示第3位
  68.
  69.                 }
  70.                 P0=weixuan[i];//发送段码
  71.                 delayus(10); //间隔一段时间扫描
  72.             P0=0x00;//消隐
  73.         }
  74. }
  75. void Display_Result()
  76. {
  77.         weixuan[1] =  LEDData[b];
  78.
  79.         weixuan[2] =  LEDData[s];
  80.
  81.         weixuan[3] =  LEDData[g];
  82.
  83.              DigDisplay();
  84.
  85. }
  86. void ADDX(uchar x,uchar y,uchar z)
  87. {
  88. ADDC=x;
  89. ADDB=y;
  90. ADDA=z;
  91. }
  92. void send(uchar x)
  93. {
  94. EA=0;
  95. SBUF=x;
  96. while(TI==0);
  97. TI=0;
  98. EA=1;
  99. }
  100. void ADC0808()
  101. {
  102. ST=0;
  103. OE=0;
  104. ST=1;
  105. ST=0;
  106. while(EOC==0);
  107. OE=1;
  108. getdata=P3;
  109. send(getdata);
  110. OE=0;
  111. }
  112. void main()
  113. {
  114. init();
  115. LED=0;
  116. ADDX(0,0,0);
  117. while(1)
  118. {
  119. ADC0808();
  120. temp=getdata*1.0/255*500;
  121. b=temp/100;
  122. s=temp/10%10;
  123. g=temp%10;
  124. if(RI==1)
  125. {
  126. RI=0;
  127. if(SBUF=='A')
  128. {
  129. LED=~LED;
  130. }
  131. }
  132. Display_Result();
  133. }
  134. }
收藏收藏 分享淘帖 顶1 踩
