完整版请看附件
- #include<reg52.h>
- #define uint unsigned int
- #define uchar unsigned char
- sbit l1=P1^0; //LED指示
- sbit bump=P2^2; //蜂鸣器控制
- sbit relay=P2^3;//继电器输出
- sbit lcden=P2^7;//LCD1602液晶控制端
- sbit lcdrs=P2^6;
- sbit sda=P2^0; //AT24C02数据端口
- sbit scl=P2^1; //时钟端口
- /**********显示内容**************************/
- uchar code xianshi0[]="input password:";
- uchar code xianshi1[]="please come in!";
- uchar code xianshi2[]="*";
- uchar code xianshi3[]=" you are thief!";
- uchar code xianshi4[]=" new password:";
- uchar code xianshi5[]=" alter succeed!";
- uchar code xianshi6[]=" first error!";
- uchar code xianshi7[]=" second error!";
- uchar code xianshi8[]=" third error!";
- uchar code xianshi9[]=" alter fail!!";
- uchar table[8]; //给按键输入留取存储空间
- uchar table1[8]; //给密码修改留取存储空间
- uchar mima[8]; //给从存储中读取密码留取存储空间
- uchar num,num1,num2,num3,etimes,fanhui,kai;
- bit alterflog,cpflog,suoflog;//定义各种标志位 修改密码键按下标志 密码比较正确标志 上锁标志
- void keyscan(); //声明键盘扫描函数
- void init();
- void keydeal15();
- void keydeal16(); //声明初始化函数
- /********************延时一毫秒函数**************/
- void delay_xs(uint x)
- { uint i,j;
- for(i=x;i>0;i--) for(j=110;j>0;j--);}
- void writecom(uchar com) //写命令
- lcdrs=0; P0=com; delay_xs(5);
- lcden=1; delay_xs(5); lcden=0;
- /*********************液晶写命令数据函数******************/
- void writedate(uchar date) //写命令
- lcdrs=1; P0=date; delay_xs(5);
- /***************24c02读取写入数据初始化****************/
- void delay() //微妙级延时函数
- void stop() //停止
- sda=0;delay();scl=1;delay();sda=1;delay();
- void respons() //应答
- uchar i;
- scl=1; delay();
- while((sda==1)&&(i<250)) i++;
- scl=0; delay();
- uchar read_byte() //读一位数据
- uchar i,k;
- scl=0; delay();
- sda=1; delay();
- for(i=0;i<8;i++)
- scl=1; delay();
- k=(k<<1)|sda;
- scl=0; delay();
- return k;
- void write24c02(uchar address,uchar date) //写一字节函数
- start();
- write_byte(0xa0);
- respons();
- write_byte(address);
- respons();
- write_byte(date);
- respons();
- stop();
- uchar read24c02(uchar address) //读一字节函数
- uchar date;
- start();
- write_byte(0xa0);
- respons();
- respons();
- start();
- write_byte(0xa1);
- respons();
- date=read_byte();
- stop();
- return date;
- /************各按键对应处理函数***************/
- /*************各按键功能********************
- 1-2-3-4-5-6-7-8-9-0-确认-重新输入-未定义-上锁-密码修改
- -密码修改确认-未定义*************************/
- void keydeal1() //按键1
- table[num]=1;
- num++;
- if(alterflog==1){table1[num1]=1;num1++; }
- void keydeal2() //按键2
- table[num]=2;
- num++;
- if(alterflog==1){table1[num1]=2;num1++; }
- void keydeal3() //按键3
- table[num]=3;
- num++;
- if(alterflog==1){table1[num1]=3;num1++; }
- void keydeal4() //按键4
- table[num]=4;
- num++;
- if(alterflog==1){table1[num1]=4;num1++; }
- void keydeal5() //按键5
- table[num]=5;
- num++;
- if(alterflog==1) {table1[num1]=5;num1++;}
- void keydeal6() //按键6
- table[num]=6;
- num++;
- if(alterflog==1){table1[num1]=6;num1++; }
- void keydeal7() //按键7
- table[num]=7;
- num++;
- if(alterflog==1){table1[num1]=7;num1++; }
- void keydeal8() //按键8
- table[num]=8;
- num++;
- if(alterflog==1){table1[num1]=8;num1++; }
- void keydeal9() //按键9
- table[num]=9;
- num++;
- if(alterflog==1){table1[num1]=9; num1++; }
- void keydeal10() //按键10
- table[num]=0; num++;
- if(alterflog==1){table1[num1]=0;num1++; }
- void compare() //比较密码正确与否函数
- uchar j;
- for(j=0;j<8;j++)
- if(table[j]==mima[j]){cpflog=1;l1=0;}
- else cpflog=0;
- l1=1;
- void keydeal11() //确认键
- uchar j;
- if(alterflog==1)
- goto n; //如果密码修改键按下再按此键无效
- if(num==8) //判断是否输入八个数字
- num=0; //将输入数字个数清零
- compare(); //进行密码比较
- for(j=0;j<8;j++) //用FFFFFFFF将输入的数据清空
- table[j]=0x0f;
- if(cpflog==1) //如果密码正确,标志位为1
- l1=0; //点亮开锁灯
- cpflog=0; //使比较密码标志位归零
- etimes=0; //使记错次数归零
- kai=1; //使打开锁标志位置1
- writecom(0x01); //液晶屏清空显示
- writecom(0x80); //让液晶显示“please come in!”
- for(j=0;j<15;j++)
- writedate(xianshi1[j]); delay_xs(3);
- for(j=0;j<2;j++) //蜂鸣器响两声提示开锁成功
- bump=0; delay_xs(200);
- bump=1; delay_xs(200);
- /*********等待按下上锁键或者密码修改键**********/
- while((suoflog!=1)&(alterflog!=1))
- P3=0xf7;
- if(P3==0xe7) suoflog=1; //上锁键按下上锁标志位置1
- if(P3==0xd7) alterflog=1; //密码修改键按下标志位置1
- if(suoflog==1) //上锁后进行初始化
- init();
- n: if(alterflog==1) //密码修改键按下显示new passsword
- writecom(0x01); writecom(0x38);
- for(j=0;j<15;j++){writedate(xianshi4[j]); }
- suoflog=0; //上锁标志位清零
- else //否则密码错误,执行密码错误指令
- num=0; //将输入数据个数清零
- num1=0; //将修改密码输入数字个数清零
- etimes++; //记录错误次数加1
- bump=0; //报警一声
- delay_xs(500); bump=1;
- for(j=0;j<8;j++) //清空修改密码输入数据
- { table1[j]=0x0f; }
- if(etimes==1) //如果输错一次
- writecom(0x01); //清屏
- writecom(0x80);
- for(j=0;j<14;j++) //显示first error
- { writedate(xianshi6[j]); }
- delay_xs(2000); //延时两秒
- writecom(0xc);
- writecom(0x80);
- for(j=0;j<16;j++) //第一行显示input passsword
- writedate(xianshi0[j]); delay_xs(5);
- writecom(0x80+0x40+4); //第二行显示--------
- for(j=0;j<8;j++) {writedate('-'); }
- if(etimes==2) //如果输错两次
- writecom(0x01); writecom(0x80);
- for(j=0;j<15;j++) //显示second error
- writedate(xianshi7[j]);
- writecom(0xc);
- writecom(0x80);
- for(j=0;j<8;j++) //第二行显示--------
- writedate('-');
- if(etimes==3) //如果输错三次
- writecom(0x01);
- writecom(0x80);
- for(j=0;j<15;j++) //显示you are thief!
- writedate(xianshi3[j]);
- for(j=0;j<10;j++) //报警十秒钟
- bump=0; delay_xs(500);
- bump=1; delay_xs(500);
- init(); //初始化
- void keydeal12() //重新输入键
- uint i;
- if(kai==0) //如果所没被打开
- { //初始化回到输入密码状态
- init();
- else //如果锁被打开,则显示new password:
- if(alterflog==1)
- num=0; num1=0;
- writecom(0x01); writecom(0x80);//清屏
- for(i=0;i<15;i++){writedate(xianshi4[i]); }
- void keydeal15() //确认密码修改键
- uchar i;
- alterflog=0; //修改标志位归零
- num=0; //数据输入个数清零
- for(i=0;i<8;i++) //输入数据清空
- table[i]=0x0f;
- if(num1==8) //如果输入修改数字够八个进入
- num1=0; //将输入修改数字个数清零
- for(i=0;i<8;i++) //将修改后八个数字写入存储器中
- write24c02(i+1,table1[i]); delay_xs(5);
- writecom(0x80);
- for(i=0;i<15;i++) //显示alter succeed!!
- writedate(xianshi5[i]);
- delay_xs(2000);
- else //如果输入数字不够八个进入
- writecom(0x80);
- for(i=0;i<14;i++) //显示alter error!
- writedate(xianshi9[i]);
- /**************修改后将键入返回程序************/
- if(kai==1) //如果锁被打开
- num=0; //输入数字个数清零
- delay_xs(2000); //延时两秒钟
- writecom(0x80);
- for(i=0;i<15;i++) //显示please come in!
- writedate(xianshi1[i]);
- delay_xs(3);
- } //继续等待上锁或修改密码
- P3=0xf7;
- if(suoflog==1) { init(); }
- if(alterflog==1)
- for(i=0;i<15;i++){ writedate(xianshi4[i]); }
- else //如果所没被打开,显示alter error两秒后
- { //进行初始化
- delay_xs(2000); init();
- void keydeal16() //键16未定义
- /******************键盘扫描函数**************************/
- void keyscan()
- uchar temp;
- /**************第一行扫描********************/
- P3=0xfe;
- temp=P3&0xf0;
- if(temp!=0xf0)
- delay_xs(10);
- if(temp!=0xf0) temp=P3;
- switch(temp)
- case 0xee: keydeal1(); break;
- case 0xde: keydeal2(); break;
- case 0xbe: keydeal3(); break;
- case 0x7e: keydeal4(); break;
- while((P3&0xf0)!=0xf0); //松手检测
- /******************第二行扫描**********************/
- P3=0xfd;
- temp=P3&0xf0;
- if(temp!=0xf0)
- delay_xs(10);
- switch(temp)
- case 0xed: keydeal5(); break;
- case 0xdd: keydeal6(); break;
- case 0xbd: keydeal7(); break;
- case 0x7d: keydeal8(); break;
- /*****************第三行扫描*********************/
- P3=0xfb;
- temp=P3&0xf0;
- if(temp!=0xf0)
- delay_xs(10);
- switch(temp)
- case 0xeb: keydeal9(); break;
- case 0xdb: keydeal10(); break;
- case 0xbb: keydeal11(); break;
- case 0x7b: keydeal12(); break;
- /********************第四行扫描********************/
- P3=0xf7;
- temp=P3&0xf0;
- if(temp!=0xf0)
- delay_xs(10);
- switch(temp)
- case 0xe7: // keydeal13();
- break;
- case 0xd7: // keydeal14();
- break;
- case 0xb7: keydeal15(); break;
- case 0x77: keydeal16(); break;
- /****************显示函数*************/
- void display()
- uint c;
- if(alterflog==0) //如果不处于修改密码状态,显示num个*
- for(c=0;c<num;c++){ writedate('*'); delay_xs(5); }
- else //如果处于密码修改显示num1个*
- for(c=0;c<num1;c++){ writedate('*'); delay_xs(5);}
- /*******************初始化函数***********/
- void init()
- uint i,a,b;
- num=0; //输入数据个数清零
- num1=0;
- kai=0; //开锁标志位清零
- l1=1; //关闭开锁灯
- alterflog=0; //修改密码标志位清零
- sda=1; //24c02进行释放总线
- delay(); scl=1; delay();
- writecom(0x38); //液晶初始化
- writecom(0x0c);
- writecom(0x06);
- writecom(0x01);
- for(i=0;i<8;i++) //读取存储器中密码,并存放于mima[]中
- mima[i]=read24c02(i+1);
- writecom(0x80);
- for(a=0;a<16;a++) //显示input password:
- writedate(xianshi0[a]); delay_xs(5);
- for(b=0;b<8;b++){ writedate('-'); }
- /*****************主函数******************/
- void main()
- init(); //初始化
- while(1) //不停地对键盘和显示进行扫描
- keyscan(); //键盘扫描和密码输入处理
- display(); //LCD显示
