查看: 2693|回复: 0
使用单片机STC89C51舵机平衡程序
视频:https://video.tudou.com/v/XMTk5MTExNTQzMg==.html?__fr=oldtd
  1. #include "STC15F2K.h"
  2. #include <math.h>    //Keil library
  3. #include <stdio.h>   //Keil library
  4. #include <INTRINS.H>
  5. typedef unsigned char  uchar;
  6. typedef unsigned short ushort;
  7. typedef unsigned int   uint;
  8. char d,s,a,b;
  9. //****************************************
  10. // 定义51单片机端口
  11. //****************************************
  12. #define Stop 0 //宏定义,停止
  13. #define Left 1 //宏定义,左转
  14. #define Right 2 //宏定义,右转
  15. #define DataPort P0                //LCD1602数据端口
  16. sbit ControlPort = P1^0; //舵机信号端口
  17. sbit ControlPort1 = P1^1; //舵机信号端口
  18. sbit    SCL=P1^6;                        //IIC时钟引脚定义
  19. sbit    SDA=P1^7;                        //IIC数据引脚定义
  20. sbit    LCM_RS=P4^5;                //LCD1602命令端口
  21. sbit    LCM_RW=P5^5;                //LCD1602命令端口
  22. sbit    LCM_EN=P5^4;                //LCD1602命令端口
  23. unsigned char TimeOutCounter = 0,TimeOutCounter1=0,LeftOrRight = 0; //TimeOutCounter:定时器溢出计数 LeftOrRight:舵机左右旋转标志
  24. //****************************************
  25. // 定义MPU6050内部地址
  26. //****************************************
  27. #define        SMPLRT_DIV                0x19        //陀螺仪采样率,典型值:0x07(125Hz)
  28. #define        CONFIG                        0x1A        //低通滤波频率,典型值:0x06(5Hz)
  29. #define        GYRO_CONFIG                0x1B        //陀螺仪自检及测量范围,典型值:0x18(不自检,2000deg/s)
  30. #define        ACCEL_CONFIG        0x1C        //加速计自检、测量范围及高通滤波频率,典型值:0x01(不自检,2G,5Hz)
  31. #define        ACCEL_XOUT_H        0x3B
  32. #define        ACCEL_XOUT_L        0x3C
  33. #define        ACCEL_YOUT_H        0x3D
  34. #define        ACCEL_YOUT_L        0x3E
  35. #define        ACCEL_ZOUT_H        0x3F
  36. #define        ACCEL_ZOUT_L        0x40
  37. #define        TEMP_OUT_H                0x41
  38. #define        TEMP_OUT_L                0x42
  39. #define        GYRO_XOUT_H                0x43
  40. #define        GYRO_XOUT_L                0x44
  41. #define        GYRO_YOUT_H                0x45
  42. #define        GYRO_YOUT_L                0x46
  43. #define        GYRO_ZOUT_H                0x47
  44. #define        GYRO_ZOUT_L                0x48
  45. #define        PWR_MGMT_1                0x6B        //电源管理,典型值:0x00(正常启用)
  46. #define        WHO_AM_I                        0x75        //IIC地址寄存器(默认数值0x68,只读)
  47. #define        SlaveAddress        0xD0        //IIC写入时的地址字节数据,+1为读取
  48. //****************************************
  49. //定义类型及变量
  50. //****************************************
  51. uchar dis[4];                                                        //显示数字(-511至512)的字符数组
  52. int        dis_data;                                                //变量
  53. //int        Temperature,Temp_h,Temp_l;        //温度及高低位数据
  54. //****************************************
  55. //函数声明
  56. //****************************************
  57. void  delay(unsigned int k);        //延时
  58. //LCD相关函数
  59. void  InitLcd();        //初始化lcd1602
  60. void  lcd_printf(uchar *s,int temp_data);
  61. void  WriteDataLCM(uchar dataW);        //LCD数据
  62. void  WriteCommandLCM(uchar CMD,uchar Attribc);                                //LCD指令
  63. void  DisplayOneChar(uchar X,uchar Y,uchar DData);                        //显示一个字符
  64. void  DisplayListChar(uchar X,uchar Y,uchar *DData,L);        //显示字符串
  65. //MPU6050操作函数
  66. void  InitMPU6050();        //初始化MPU6050
  67. void  Delay2us();
  68. void  I2C_Start();
  69. void  I2C_Stop();
  70. void  I2C_SendACK(bit ack);
  71. bit   I2C_RecvACK();
  72. void  I2C_SendByte(uchar dat);
  73. uchar I2C_RecvByte();
  74. void  I2C_ReadPage();
  75. void  I2C_WritePage();
  76. void  display_ACCEL_x();
  77. void  display_ACCEL_y();
  78. void  display_ACCEL_z();
  79. uchar Single_ReadI2C(uchar REG_Address);                                                //读取I2C数据
  80. void  Single_WriteI2C(uchar REG_Address,uchar REG_data);        //向I2C写入数据
  81. //****************************************
  82. //整数转字符串
  83. //****************************************
  84. void lcd_printf(uchar *s,int temp_data)
  85. {
  86.         if(temp_data<0)
  87.         {
  88.                 temp_data=-temp_data;
  89.                 *s='-';
  90.         }
  91.         else *s=' ';
  92.         *++s =temp_data/100+0x30;
  93.         temp_data=temp_data%100;     //取余运算
  94.         *++s =temp_data/10+0x30;
  95.         temp_data=temp_data%10;      //取余运算
  96.         *++s =temp_data+0x30;
  97. }
  98. //****************************************
  99. //延时
  100. //****************************************
  101. void delay(unsigned int k)
  102. {
  103.         unsigned int i,j;
  104.         for(i=0;i<k;i++)
  105.         {
  106.                 for(j=0;j<121;j++);
  107.         }
  108. }
  109. //**************************************
  110. //延时5微秒(STC90C52RC@12M)
  111. //不同的工作环境,需要调整此函数
  112. //当改用1T的MCU时,请调整此延时函数
  113. //**************************************
  114. void Delay2us()
  115. {
  116.           unsigned char i;
  117.         i = 3;
  118.         while (--i);
  119. }
  120. void T_C_init (void)
  121. {
  122.         TMOD = 0x11; //高4位控制T/C1 [ GATE,C/T,M1,M0,GATE,C/T,M1,M0 ] 0001 0001 16位T/C
  123.     EA = 1; //中断总开关
  124.     TH1 = ( 65535 - 25 ) / 256; //0.25ms后中断
  125.          TL1 = ( 65535 - 25) % 256;
  126.         TH0 = ( 65535 - 25) / 256; //0.25ms后中断
  127.     TL0 = ( 65535 - 25) % 256;
  128.     ET0 = 1; //T/C0中断开关
  129.     TR0 = 1; //T/C0启动开关
  130.         ET1 = 1; //T/C0中断开关
  131.     TR1 = 1; //T/C0启动开关
  132. }
  133. //**************************************
  134. //I2C起始信号
  135. //**************************************
  136. void I2C_Start()
  137. {
  138.     SDA = 1;                    //拉高数据线
  139.     SCL = 1;                    //拉高时钟线
  140.     Delay2us();                 //延时
  141.     SDA = 0;                    //产生下降沿
  142.     Delay2us();                 //延时
  143.     SCL = 0;                    //拉低时钟线
  144. }
  145. //**************************************
  146. //I2C停止信号
  147. //**************************************
  148. void I2C_Stop()
  149. {
  150.     SDA = 0;                    //拉低数据线
  151.     SCL = 1;                    //拉高时钟线
  152.     Delay2us();                 //延时
  153.     SDA = 1;                    //产生上升沿
  154.     Delay2us();                 //延时
  155. }
  156. //**************************************
  157. //I2C发送应答信号
  158. //入口参数:ack (0:ACK 1:NAK)
  159. //**************************************
  160. void I2C_SendACK(bit ack)
  161. {
  162.     SDA = ack;                  //写应答信号
  163.     SCL = 1;                    //拉高时钟线
  164.     Delay2us();                 //延时
  165.     SCL = 0;                    //拉低时钟线
  166.     Delay2us();                 //延时
  167. }
  168. //**************************************
  169. //I2C接收应答信号
  170. //**************************************
  171. bit I2C_RecvACK()
  172. {
  173.     SCL = 1;                    //拉高时钟线
  174.     Delay2us();                 //延时
  175.     CY = SDA;                   //读应答信号
  176.     SCL = 0;                    //拉低时钟线
  177.     Delay2us();                 //延时
  178.     return CY;
  179. }
  180. //**************************************
  181. //向I2C总线发送一个字节数据
  182. //**************************************
  183. void I2C_SendByte(uchar dat)
  184. {
  185.     uchar i;
  186.     for (i=0; i<8; i++)         //8位计数器
  187.     {
  188.         dat <<= 1;              //移出数据的最高位
  189.         SDA = CY;               //送数据口
  190.         SCL = 1;                //拉高时钟线
  191.         Delay2us();             //延时
  192.         SCL = 0;                //拉低时钟线
  193.         Delay2us();             //延时
  194.     }
  195.     I2C_RecvACK();
  196. }
  197. //**************************************
  198. //从I2C总线接收一个字节数据
  199. //**************************************
  200. uchar I2C_RecvByte()
  201. {
  202.     uchar i;
  203.     uchar dat = 0;
  204.     SDA = 1;                    //使能内部上拉,准备读取数据,
  205.     for (i=0; i<8; i++)         //8位计数器
  206.     {
  207.         dat <<= 1;
  208.         SCL = 1;                //拉高时钟线
  209.         Delay2us();             //延时
  210.         dat |= SDA;             //读数据
  211.         SCL = 0;                //拉低时钟线
  212.         Delay2us();             //延时
  213.     }
  214.     return dat;
  215. }
  216. //**************************************
  217. //向I2C设备写入一个字节数据
  218. //**************************************
  219. void Single_WriteI2C(uchar REG_Address,uchar REG_data)
  220. {
  221.     I2C_Start();                  //起始信号
  222.     I2C_SendByte(SlaveAddress);   //发送设备地址+写信号
  223.     I2C_SendByte(REG_Address);    //内部寄存器地址,
  224.     I2C_SendByte(REG_data);       //内部寄存器数据,
  225.     I2C_Stop();                   //发送停止信号
  226. }
  227. //**************************************
  228. //从I2C设备读取一个字节数据
  229. //**************************************
  230. uchar Single_ReadI2C(uchar REG_Address)
  231. {
  232.         uchar REG_data;
  233.         I2C_Start();                   //起始信号
  234.         I2C_SendByte(SlaveAddress);    //发送设备地址+写信号
  235.         I2C_SendByte(REG_Address);     //发送存储单元地址,从0开始
  236.         I2C_Start();                   //起始信号
  237.         I2C_SendByte(SlaveAddress+1);  //发送设备地址+读信号
  238.         REG_data=I2C_RecvByte();       //读出寄存器数据
  239.         I2C_SendACK(1);                //接收应答信号
  240.         I2C_Stop();                    //停止信号
  241.         return REG_data;
  242. }
  243. //****************************************
  244. //LCD1602初始化
  245. //****************************************
  246. void InitLcd()
  247. {
  248.         WriteCommandLCM(0x38,1);
  249.         WriteCommandLCM(0x08,1);
  250.         WriteCommandLCM(0x01,1);
  251.         WriteCommandLCM(0x06,1);
  252.         WriteCommandLCM(0x0c,1);
  253.         DisplayOneChar(0,0,'A');
  254.         DisplayOneChar(0,1,'G');
  255. }
  256. //****************************************
  257. //LCD1602写允许
  258. //****************************************
  259. void WaitForEnable(void)
  260. {
  261.         DataPort=0xff;
  262.         LCM_RS=0;LCM_RW=1;_nop_();
  263.         LCM_EN=1;_nop_();_nop_();
  264.         while(DataPort&0x80);
  265.         LCM_EN=0;
  266. }
  267. //****************************************
  268. //LCD1602写入命令
  269. //****************************************
  270. void WriteCommandLCM(uchar CMD,uchar Attribc)
  271. {
  272.         if(Attribc)WaitForEnable();
  273.         LCM_RS=0;LCM_RW=0;_nop_();
  274.         DataPort=CMD;_nop_();
  275.         LCM_EN=1;_nop_();_nop_();LCM_EN=0;
  276. }
  277. //****************************************
  278. //LCD1602写入数据
  279. //****************************************
  280. void WriteDataLCM(uchar dataW)
  281. {
  282.         WaitForEnable();
  283.         LCM_RS=1;LCM_RW=0;_nop_();
  284.         DataPort=dataW;_nop_();
  285.         LCM_EN=1;_nop_();_nop_();LCM_EN=0;
  286. }
  287. //****************************************
  288. //LCD1602写入一个字符
  289. //****************************************
  290. void DisplayOneChar(uchar X,uchar Y,uchar DData)
  291. {
  292.         Y&=1;
  293.         X&=15;
  294.         if(Y)X|=0x40;
  295.         X|=0x80;
  296.         WriteCommandLCM(X,0);
  297.         WriteDataLCM(DData);
  298. }
  299. //****************************************
  300. //LCD1602显示字符串
  301. //****************************************
  302. //void DisplayListChar(uchar X,uchar Y,uchar *DData,L)
  303. //{
  304. //        uchar ListLength=0;
  305. //        Y&=0x1;
  306. //        X&=0xF;
  307. //        while(L--)
  308. //        {
  309. //                DisplayOneChar(X,Y,DData[ListLength]);
  310. //                ListLength++;
  311. //                X++;
  312. //        }
  313. //}
  314. //**************************************
  315. //初始化MPU6050
  316. //**************************************
  317. void InitMPU6050()
  318. {
  319.         Single_WriteI2C(PWR_MGMT_1, 0x00);        //解除休眠状态
  320.         Single_WriteI2C(SMPLRT_DIV, 0x07);
  321.         Single_WriteI2C(CONFIG, 0x06);
  322.         Single_WriteI2C(GYRO_CONFIG, 0x18);
  323.         Single_WriteI2C(ACCEL_CONFIG, 0x01);
  324. }
  325. //**************************************
  326. //合成数据
  327. //**************************************
  328. int GetData(uchar REG_Address)
  329. {
  330.         char H,L;
  331.         H=Single_ReadI2C(REG_Address);
  332.         L=Single_ReadI2C(REG_Address+1);
  333.         return (H<<8)+L;   //合成数据
  334. }
  335. //**************************************
  336. //在1602上显示10位数据
  337. //**************************************
  338. //void Display10BitData(int value,uchar x,uchar y)
  339. //{
  340. //        value/=64;                                                        //转换为10位数据
  341. //        lcd_printf(dis, value);                        //转换数据显示
  342. //        DisplayListChar(x,y,dis,4);        //启始列,行,显示数组,显示长度
  343. //}
  344. //*********************************************************
  345. //主程序
  346. //*********************************************************
  347. void main()
  348. {
  349.         int n;
  350.         T_C_init();                //定时器初始化
  351.         delay(500);                //上电延时
  352.         InitLcd();                //液晶初始化
  353.         InitMPU6050();        //初始化MPU6050
  354.         delay(150);
  355.         while(1)
  356.         {
  357. //                Display10BitData(GetData(ACCEL_XOUT_H),2,0);        //显示X轴加速度
  358. //                Display10BitData(GetData(ACCEL_YOUT_H),7,0);        //显示Y轴加速度
  359. //                Display10BitData(GetData(ACCEL_ZOUT_H),12,0);        //显示Z轴加速度
  360. //                Display10BitData(GetData(GYRO_XOUT_H),2,1);        //显示X轴角速度
  361. //                Display10BitData(GetData(GYRO_YOUT_H),7,1);        //显示Y轴角速度
  362. //                Display10BitData(GetData(GYRO_ZOUT_H),12,1);        //显示Z轴角速度
  363.                 //delay(50);
  364.                 a=GetData(ACCEL_XOUT_H)/256;   //X轴加速度
  365.                 b=GetData(ACCEL_YOUT_H)/256;    //Y轴加速度
  366.                 WriteCommandLCM(0x82,1);
  367.                 lcd_printf(dis,GetData(ACCEL_XOUT_H)/64); //X轴加速度转字符串
  368.                 for(n=0;n<4;n++)
  369.                 {
  370.                         WriteDataLCM(dis[n]);        //显示X轴加速度
  371.                 }
  372.                 WriteCommandLCM(0x88,1);
  373.                 lcd_printf(dis,GetData(ACCEL_YOUT_H)/64);  //Y轴加速度转字符串
  374.                 for(n=0;n<4;n++)
  375.                 {
  376.                         WriteDataLCM(dis[n]); //显示Y轴加速度
  377.                 }
  378.         }
  379. }
  380. void T_C0 (void) interrupt 1 using 1
  381. {
  382.     TH0 = ( 65535 - 25 ) / 256;         //定时器T0重赋初值
  383.     TL0 = ( 65535 - 25 ) % 256;
  384.     TimeOutCounter ++;           //中断次数加1
  385.                 {
  386.                     if( TimeOutCounter <55+a)         //调节X轴方向的角度
  387.                     {
  388.                         ControlPort = 1;   //输出高脉冲
  389.                     }
  390.                     else
  391.                     {
  392.                         ControlPort = 0;
  393.                     }
  394.                 }
  395.     if( TimeOutCounter == 400 ) //周期20ms(理论值),比较可靠,最好不要修改
  396.     {
  397.         TimeOutCounter = 0;
  398.     }
  399. }
  400. void T_C1 (void) interrupt 3 using 1
  401. {
  402.     TH1= ( 65535 -25 ) / 256;         //T1重赋初值
  403.     TL1 = ( 65535 -25) % 256;
  404.     TimeOutCounter1 ++;                            //中断次数加1
  405.             if( TimeOutCounter1 < 43+b)          //调节Y轴方向的角度
  406.                 ControlPort1 = 1;           //输出高电平
  407.             else
  408.                 ControlPort1 = 0;            //输出低电平
  409.     if( TimeOutCounter1 == 400 ) //周期20ms(理论值),比较可靠,最好不要修改
  410.     {
  411.         TimeOutCounter1 = 0;
  412.     }
  413. }
