查看: 1980|回复: 0
单片机矩形按键-特定按键显示特定的数-且可以加减数字
#include<reg51.h>//矩阵键盘 从下往上 从左往右依次为1 2 3……号   14号为复位加减  15号++   16号--
#include<intrins.h>
#define uint unsigned int
#define DIG P0
#define KEY P1
sbit seg1=P2^0;
//sbit seg2=P2^2;
uchar code shuzi[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7C,0x39,0x5E};
uchar xianshi,a=0,b,c;
void delay(uint t)
        while(t--);
void keydown()
        KEY=0xf0;
        if(KEY!=0xf0)
                delay(15);
                if(KEY!=0xf0)
                        switch(KEY)
                        case(0x70):xianshi=0;break;
                        case(0xb0):xianshi=1;break;
                        case(0xd0):xianshi=2;c--;break;
                        case(0xe0):xianshi=3;c++;break;
                KEY=0x0f;
                        switch(KEY)
                        case(0x07):xianshi=xianshi;break;
                        case(0x0b):xianshi=xianshi+4;break;
                        case(0x0d):xianshi=xianshi+8;break;
                        case(0x0e):xianshi=xianshi+12;break;
                while((a<50)&&(KEY!=0XF0))
                        delay(1000);
                        a++;
        seg1=0;
  keydown();
        if ((xianshi>=0)&&(xianshi<=12))
                DIG=shuzi[xianshi];
        if(xianshi==13)
                c=5;
        DIG=shuzi[c];
        if(xianshi==14)
                DIG=shuzi[c];
                delay(50000);
                 if(xianshi==15)
                DIG=shuzi[c];
                delay(50000);
