主要代码
/*************** writer:shopping.w ******************/
#include <reg52.h>
#define uint unsigned int
uchar code FFW[]=
0x01,0x03,0x02,0x06,0x04,0x0c,0x08,0x09
uchar code REV[]=
0x09,0x08,0x0c,0x04,0x06,0x02,0x03,0x01
sbit K1 = P3^0;
sbit K2 = P3^1;
sbit K3 = P3^2;
void DelayMS(uint ms)
uchar i;
while(ms--)
for(i=0;i<120;i++);
void SETP_MOTOR_FFW(uchar n)
uchar i,j;
for(i=0;i<5*n;i++)
for(j=0;j<8;j++)
if(K3 == 0) break;
P1 = FFW[j];
DelayMS(25);
void SETP_MOTOR_REV(uchar n)
uchar i,j;
for(i=0;i<5*n;i++)
for(j=0;j<8;j++)
if(K3 == 0) break;
P1 = REV[j];
DelayMS(25);
uchar N = 3;
if(K1 == 0)
P0 = 0xfe;
SETP_MOTOR_FFW(N);
if(K3 == 0) break;
else if(K2 == 0)
P0 = 0xfd;
SETP_MOTOR_REV(N);
if(K3 == 0) break;
P0 = 0xfb;
P1 = 0x03;
