基于STM32F103VET6的无刷直流电机控制程序和资料还有原理图
压缩包内部文件:
压缩包+程序
PCB正面
PCB正面
PCB反面
PCB反面
无感无刷直流电机之电调设计全攻略
无感无刷直流电机之电调设计全攻略
内部文件:
压缩包
Cortex-M3架构
采用FOS
MAIN.C
- /******************** (C) COPYRIGHT 2008 STMicroelectronics ********************
- * File Name : main.c
- * Author : MCD Application Team
- * Version : V2.0.1
- * Date : 06/13/2008
- * Description : Main program body
- * THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
- * WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE TIME.
- * AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY DIRECT,
- * INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING FROM THE
- * CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE CODING
- * INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
- /* Includes ------------------------------------------------------------------*/
- #include "stm32f10x_lib.h"
- #include "main.h"
- #include "CAN\can.h"
- #define ADC1_DR_Address ((u32)0x4001244C)
- /* Private typedef -----------------------------------------------------------*/
- /* Private define ------------------------------------------------------------*/
- /* Private macro -------------------------------------------------------------*/
- /* Private variables ---------------------------------------------------------*/
- static vu32 TimingDelay = 0;
- volatile struct {
- unsigned Key : 1;
- unsigned CalSpeed : 1;
- unsigned Sec : 1;
- unsigned Fault : 1;
- }Flags;
- unsigned int DesiredSpeed=500;
- unsigned int ActualSpeed;
- unsigned int pwm=500;
- unsigned int T3Count;
- unsigned int ActualSpeed5[3];
- vu16 ADC_DMABUF;
- unsigned int AveActualSpeed;
- unsigned char AveNum;
- unsigned char j;
- float kp=0.50,ki=0.08,kd=0.0;
- //float ABC[3]={0.8,0.08,0.0};
- int ek=0,ek1=0,ek2=0;
- float duk;
- int du;
- int ekSpeed=0;
- unsigned char LED_Code[16]={0x5f,0x44,0x9d,0xd5,0xc6,0xd3,0xdb,0x45,0xdf,0xd7,0xcf,0xda,0x1b,0xdc,0x9b,0x8b};
- int LED_Dis;
- u16 motor_statue=0;
- extern u16 My_PWM;
- extern bool Direction;
- extern CanRxMsg tmp_CanRxMessage;
- extern CanTxMsg tmp_TxMessage;
- int state,state1,state2,state3,counter1,counter2,counter3,speed_1,aim_speed,check_run,speed_code;
- short ADC_ConvertedValue[5]={0,0,0,0,0};
- u8 *Row0[10]={"Set Speed:"};
- u8 *Row1[10]={"Now Speed:"};
- u8 *Clear[16]={" "};
- TIM_BDTRInitTypeDef TIM_BDTRInitStructure;
- TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
- TIM_OCInitTypeDef TIM_OCInitStructure;
- EXTI_InitTypeDef EXTI_InitStructure;
- ErrorStatus HSEStartUpStatus;
- /* Private function prototypes -----------------------------------------------*/
- void RCC_Configuration(void);
- void GPIO_Configuration(void);
- void NVIC_Configuration(void);
- void CalculateDC(int u,int y);
- void TIM3_Configuration1(void);
- void TIM2_Configuration1(void);
- void TIM4_Configuration1(void);
- void SysTick_Configuration(void);
- void DMA_Configuration1(void);
- void ADC_Configuration1(void);
- int pid(int nonce,int aim);
- /* Private functions ---------------------------------------------------------*/
- * Function Name : main
- * Description : Main program.
- * Input : None
- * Output : None
- * Return : None
- int main(void)
- #ifdef DEBUG
- debug();
- #endif
- int i,j,k;
- /* System Clocks Configuration */
- RCC_Configuration();
- /* NVIC configuration */
- NVIC_Configuration();
- CAN_Config();
- DMA_Configuration1();
- ADC_Configuration1();
- TIM3_Configuration1();
- TIM2_Configuration1();
- TIM4_Configuration1();
- GPIO_Configuration();
- SysTick_Configuration();
- SysTick_CounterCmd(SysTick_Counter_Enable);
- /* Configure the systick */
- //SysTick_Config();
- /* Configure the GPIO ports */
- GPIO_SetBits(GPIOC, GPIO_Pin_11);
- //DisplayNumber(5,0,325);
- aim_speed=2000;
- //My_PWM=100;
- //EXTI_GenerateSWInterrupt(EXTI_Line1);
- //for(i=0;i<500;i++);
- while (1)
- //motor_statue=0;
- //Direction=FALSE;
- LED_Dis=speed_1;
- if(speed_code!=((GPIO_ReadInputData(GPIOE)>>1)&0x07))
- speed_code=(GPIO_ReadInputData(GPIOE)>>1)&0x07;
- tmp_TxMessage.StdId = 0x0f;
- tmp_TxMessage.RTR = CAN_RTR_DATA;
- tmp_TxMessage.IDE = CAN_ID_STD;
- tmp_TxMessage.DLC = 8;
- tmp_TxMessage.Data[0] = speed_code;
- CAN_Send_Message(&tmp_TxMessage);
- //aim_speed=speed_code*1000;
- if(state1>5)
- if(check_run<3&&aim_speed>300)
- { GPIO_ResetBits(GPIOC, GPIO_Pin_11);
- for(i=0;i<5000;i++);
- My_PWM=200;
- EXTI_GenerateSWInterrupt(EXTI_Line0);
- for(i=0;i<500;i++);
- EXTI_GenerateSWInterrupt(EXTI_Line1);
- EXTI_GenerateSWInterrupt(EXTI_Line2);
- state1=0;
- check_run=0;
- for(i=0;i<100000;i++);
- My_PWM+=pid(speed_1,aim_speed)/((speed_1/My_PWM)+1);
- if(My_PWM<0)
- My_PWM=0;
- if(My_PWM>5000)
- My_PWM=5000;
- if((speed_1-aim_speed)<3)
- My_PWM+=10;
- if((aim_speed-speed_1)<3)
- My_PWM-=10;
- for(j=10;j<90;j++)
- for(k=0;k<5;k++)
- for(i=0;i<50000;i++);
- My_PWM=j*10;
- for(k=0;k<100;k++)
- for(j=90;j>10;j--)
- for(k=0;k<5;k++)
- My_PWM=j*10;
- Direction=TRUE;
- for(k=0;k<50;k++)
- My_PWM=100;
- for(k=0;k<5;k++)
- My_PWM=j*10;
- for(k=0;k<5;k++)
- My_PWM=j*10;
- static int ek_2=0;
- static int ek_1=0;
- static int ek=0;
- // int ec;
- int uk;
- ek=aim-nonce;
- // ec=ek/T;
- uk=kp*(ek-ek_1+ki*ek+kd*(ek-2*ek_1+ek_2));
- ek_2=ek_1;
- ek_1=ek;
- return (uk);
- * Function Name : RCC_Configuration
- * Description : Configures the different system clocks.
- * Input : None
- * Output : None
- * Return : None
- // RCC system reset(for debug purpose)
- RCC_DeInit();
- // Enable HSE
- RCC_HSEConfig(RCC_HSE_ON);
- // Wait till HSE is ready
- HSEStartUpStatus = RCC_WaitForHSEStartUp();
- if(HSEStartUpStatus == SUCCESS)
- // Enable Prefetch Buffer
- FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
- // Flash 2 wait state
- FLASH_SetLatency(FLASH_Latency_2);
- // HCLK = SYSCLK
- RCC_HCLKConfig(RCC_SYSCLK_Div1);
- // PCLK2 = HCLK
- RCC_PCLK2Config(RCC_HCLK_Div1);
- // PCLK1 = HCLK/2
- RCC_PCLK1Config(RCC_HCLK_Div2);
- // PLLCLK = 8MHz * 9 = 72 MHz
- RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
- // Enable PLL
- RCC_PLLCmd(ENABLE);
- // Wait till PLL is ready
- while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
- // Select PLL as system clock source
- RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
- // Wait till PLL is used as system clock source
- while(RCC_GetSYSCLKSource() != 0x08)
- else
- // If HSE fails to start-up, the application will have wrong clock configuration.
- // User can add here some code to deal with this error
- // Go to infinite loop
- while (1)
- #ifdef _GPIOA
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
- #endif
- #ifdef _GPIOB
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
- #endif
- #ifdef _GPIOC
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);
- #endif
- #ifdef _GPIOD
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD, ENABLE);
- #endif
- #ifdef _GPIOE
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOE, ENABLE);
- #endif
- #ifdef _GPIOF
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOF, ENABLE);
- #endif
- #ifdef _GPIOG
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOG, ENABLE);
- #endif
- #ifdef _AFIO
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE);
- #endif
- #ifdef _CAN
- RCC_APB1PeriphClockCmd(RCC_APB1Periph_CAN, ENABLE);
- #endif
- #ifdef _USART1
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE);
- #endif
- #ifdef _SPI1
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_SPI1, ENABLE);
- #endif
- #ifdef _FSMC
- RCC_AHBPeriphClockCmd(RCC_AHBPeriph_FSMC, ENABLE);
- #endif
- #ifdef _USART2
- RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2, ENABLE);
- #endif
- #ifdef _PWR
- RCC_APB1PeriphClockCmd(RCC_APB1Periph_PWR, ENABLE);
- #endif
- #ifdef _BKP
- RCC_APB1PeriphClockCmd(RCC_APB1Periph_BKP, ENABLE);
- #endif
- #ifdef _TIM2
- RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
- #endif
- #ifdef _DMA1
- RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
- #endif
- #ifdef _ADC1
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE);
- #endif
- * Function Name : GPIO_Configuration
- * Description : Configures the different GPIO ports.
- * Input : None
- * Output : None
- * Return : None
- GPIO_InitTypeDef GPIO_InitStructure;
- /*PE4£¬PE5£¬PE6ÎaLED*/
- GPIO_InitStructure.GPIO_Pin =GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_6;
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
- GPIO_Init(GPIOE, &GPIO_InitStructure);
- /*PD8-PD15 ÎaêyÂë1ü¶ÎÑ¡*/
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8| GPIO_Pin_9 | GPIO_Pin_10 | GPIO_Pin_11| GPIO_Pin_12 | GPIO_Pin_13 | GPIO_Pin_14| GPIO_Pin_15;
- GPIO_Init(GPIOD, &GPIO_InitStructure);
- /*PB12-PB15 ÎaêyÂë1üλѡ*/
- GPIO_InitStructure.GPIO_Pin =GPIO_Pin_12 | GPIO_Pin_13 | GPIO_Pin_14 | GPIO_Pin_15;
- GPIO_Init(GPIOB, &GPIO_InitStructure);
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPD;
- /*PE2,PE3ÎaêäèëéÏà- °′¼ü */
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2|GPIO_Pin_3;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
- /* ÅäÖÃHall½ó¿úIO */
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
- /*»ô¶ûDÅoÅÏßÖD¶ÏÅäÖÃ*/
- GPIO_EXTILineConfig(GPIO_PortSourceGPIOD,GPIO_PinSource0);
- GPIO_EXTILineConfig(GPIO_PortSourceGPIOD,GPIO_PinSource1);
- GPIO_EXTILineConfig(GPIO_PortSourceGPIOD,GPIO_PinSource2);
- EXTI_InitStructure.EXTI_Line = EXTI_Line0|EXTI_Line1|EXTI_Line2;
- EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
- EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Rising_Falling;
- EXTI_InitStructure.EXTI_LineCmd = ENABLE;
- EXTI_Init(&EXTI_InitStructure);
- /*PC4,PC5,PC6 ÎaéÏ°ëÇÅ±Û PC11ÎaÇy¶ˉê1Äü*/
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4| GPIO_Pin_5 | GPIO_Pin_6 | GPIO_Pin_11;
- GPIO_Init(GPIOC, &GPIO_InitStructure);
- /*PC7,PC8,PC9 ÎaÏ°ëÇűÛ£¬¸′óÃÎaPWMêä3ö*/
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7 | GPIO_Pin_8 | GPIO_Pin_9 ;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
- GPIO_PinRemapConfig(GPIO_FullRemap_TIM3,ENABLE);
- //GPIO_PinRemapConfig(GPIO_PartialRemap_TIM3, ENABLE);
- //±Õ»·¼ÆËã×ó3ìDò
- ek=u-y;
- if(ek>1||ek<-1)
- duk=kp*(ek-ek1)+ki*ek+kd*(ek+ek2-ek1*2);
- du=(int)duk;
- if(duk>1)duk=1;
- if(duk<-1)duk=-1;
- if(du>10)du=10;
- if(du<-5)du=-5;
- pwm+=du;
- if(pwm<60)
- pwm=60;
- if(pwm>0x7FE)
- //pwm=2398;
- pwm=0x7FE;
- //TIM1->CCR1 = pwm;
- //TIM1->CCR2 = pwm;
- //TIM1->CCR3 = pwm;
- ek2=ek1;
- ek1=ek;
- * Function Name : NVIC_Configuration
- * Description : Configure the nested vectored interrupt controller.
- * Input : None
- * Output : None
- * Return : None
- NVIC_InitTypeDef NVIC_InitStructure;
- #ifdef VECT_TAB_RAM
- /* Set the Vector Table base location at 0x20000000 */
- NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
- #else /* VECT_TAB_FLASH */
- /* Set the Vector Table base location at 0x08000000 */
- NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
- #endif
- /* Configure one bit for preemption priority */
- NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
- /* Enable the EXTI9_5 Interrupt */
- NVIC_InitStructure.NVIC_IRQChannel = EXTI0_IRQChannel;
- NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
- NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
- NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
- NVIC_Init(&NVIC_InitStructure);
- NVIC_InitStructure.NVIC_IRQChannel = EXTI1_IRQChannel;
- NVIC_InitStructure.NVIC_IRQChannelSubPriority = 2;
- NVIC_InitStructure.NVIC_IRQChannel = EXTI2_IRQChannel;
- NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3;
- NVIC_InitStructure.NVIC_IRQChannel = USB_LP_CAN_RX0_IRQChannel;
- NVIC_InitStructure.NVIC_IRQChannelSubPriority = 4;
- NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQChannel;
- NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
- NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQChannel;
- NVIC_InitStructure.NVIC_IRQChannel = TIM4_IRQChannel;
- //NVIC_InitStructure.NVIC_IRQChannel = EXTI3_IRQChannel;
- //NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
- //NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
- //NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
- //NVIC_Init(&NVIC_InitStructure);
- /* Configure and enable ADC interrupt */
- //NVIC_InitStructure.NVIC_IRQChannel = ADC1_2_IRQChannel;
- //NVIC_InitStructure.NVIC_IRQChannelSubPriority = 4;
- //Step3.ê1ÄüTIM1μÄêä3ö±è½ÏÆ¥ÅäÖD¶Ï
- //NVIC_InitStructure.NVIC_IRQChannel = TIM3_CC_IRQChannel;
- //NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
- //NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
- #ifdef DEBUG
- * Function Name : assert_failed
- * Description : Reports the name of the source file and the source line number
- * where the assert_param error has occurred.
- * Input : - file: pointer to the source file name
- * - line: assert_param error line source number
- * Output : None
- * Return : None
- void assert_failed(u8* file, u32 line)
- /* User can add his own implementation to report the file name and line number,
- ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
- /* Infinite loop */
- while (1)
- #endif
- * Function Name : SysTick_Config
- * Description : Configure a SysTick Base time to 10 ms.
- * Input : None
- * Output : None
- * Return : None
- /* Select AHB clock(HCLK) as SysTick clock source */
- SysTick_CLKSourceConfig(SysTick_CLKSource_HCLK_Div8);
- /* Set SysTick Priority to 3 */
- NVIC_SystemHandlerPriorityConfig(SystemHandler_SysTick, 5, 0);
- /* SysTick interrupt each 1ms with HCLK equal to 72MHz */
- SysTick_SetReload(900000);
- /* Enable the SysTick Interrupt */
- SysTick_ITConfig(ENABLE);
- * Function Name : Delay
- * Description : Inserts a delay time.
- * Input : nCount: specifies the delay time length (time base 10 ms).
- * Output : None
- * Return : None
- void Delay(u32 nCount)
- TimingDelay = nCount;
- /* Enable the SysTick Counter */
- //SysTick_CounterCmd(SysTick_Counter_Enable);
- while(TimingDelay != 0)
- /* Disable the SysTick Counter */
- //SysTick_CounterCmd(SysTick_Counter_Disable);
- /* Clear the SysTick Counter */
- SysTick_CounterCmd(SysTick_Counter_Clear);
- * Function Name : Decrement_TimingDelay
- * Description : Decrements the TimingDelay variable.
- * Input : None
- * Output : TimingDelay
- * Return : None
- void Decrement_TimingDelay(void)
- if (TimingDelay != 0x00)
- TimingDelay--;
- /******************* (C) COPYRIGHT 2008 STMicroelectronics *****END OF FILE****/
复制代码 全部资料51hei下载地址:
STM32+BLDC+2012.7.22+新版+资料.7z
(711.38 KB, 下载次数: 115)
BLDC MC 00957a_cn.pdf
758.74 KB, 下载次数: 30, 下载积分: 黑币 -5
无感无刷直流电机之电调设计全攻略.pdf
4.58 MB, 下载次数: 35, 下载积分: 黑币 -5
无传感器PSMS马达FOC控制算法详解.pdf
2.12 MB, 下载次数: 33, 下载积分: 黑币 -5
基于STM32的PMSM_FOC软件库培训.pdf
738.56 KB, 下载次数: 32, 下载积分: 黑币 -5
BLDC 2012.7.22.pdf
1.18 MB, 下载次数: 35, 下载积分: 黑币 -5
