- #include "stm32f10x.h"
- u8 wd=0;
- u8 sd=0;
- unsigned char a[80] ;
- unsigned char DHT[5];
- float ADC_Data = 0 ;
- void ADC1_GPIO_Config(void){
- GPIO_InitTypeDef GPIO_InitStructure;
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_ADC1, ENABLE); //使能ADC1,GPIOC时钟
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1; //
- //GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;//为什么没有配置这个????
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN; //模拟输入
- GPIO_Init(GPIOA, &GPIO_InitStructure); //初始化PC4
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0; //
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;//为什么没有配置这个????
- void ADC_Config(void)
- ADC_InitTypeDef ADC_InitStructure;//ADC结构体变量//注意在一个语句快内变量的声明要放在可执行语句的前面,否则出错,因此要放在ADC1_GPIO_Config();前面
- ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;//ADC1和ADC2工作在独立模式
- ADC_InitStructure.ADC_ScanConvMode = DISABLE; //使能扫描
- ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;//ADC转换工作在连续模式
- ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;//由软件控制转换,不使用外部触发
- ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;//转换数据右对齐
- ADC_InitStructure.ADC_NbrOfChannel = 1;//转换通道为1
- ADC_Init(ADC1, &ADC_InitStructure); //初始化ADC
- ADC_RegularChannelConfig(ADC1, ADC_Channel_1, 1, ADC_SampleTime_55Cycles5);
- //ADC1选择信道14,音序等级1,采样时间55.5个周期
- // ADC_DMACmd(ADC1, ENABLE);//使能ADC1模块DMA
- ADC_Cmd(ADC1, ENABLE);//使能ADC1
- ADC_ITConfig(ADC1, ADC_IT_EOC, ENABLE);
- ADC_SoftwareStartConvCmd(ADC1, ENABLE);
- // ADC_ResetCalibration(ADC1); //重置.(复位).ADC1校准寄存器
- // while(ADC_GetResetCalibrationStatus(ADC1));//等待ADC1校准重置完成
- // ADC_StartCalibration(ADC1);//开始ADC1校准
- // while(ADC_GetCalibrationStatus(ADC1));//等待ADC1校准完成
- // ADC_SoftwareStartConvCmd(ADC1, ENABLE); //使能ADC1软件开始转换
- int main(void)
- int i = 0 ;
- delay_init() ;
- LCD_Init() ;
- Key_Init() ; //按键初始化
- NVIC_Config() ; //中断配置
- TIME3_init() ; //定时器配置
- ADC1_GPIO_Config() ;
- ADC_Config() ;
- while(1)
- GPIO_SetBits(GPIOA,GPIO_Pin_7) ;
- if(GPIO_ReadOutputDataBit(GPIOA, GPIO_Pin_8) == 1)
- ADC_Data = ADC_GetConversionValue(ADC1);
- Display(); //菜单显示
- }else
- LCD_Fill(0x00); //初始清屏
仿真.7z
(297.18 KB, 下载次数: 752)
