void wr_lcd(uchar a,b)
rs=a;
rw=0;
en=1;
P0=b;
en=0;
void disp(uchar x,y,x1,y1,line,rom,uchar *str)
uchar a,b,c,d,e;
wr_lcd(0,0x3f);
for(a=0;a<line;a++)
for(b=0;b<rom;b++)
for(c=0;c<x1;c++)
wr_lcd(0,0xb8+x+a*x1+c);
wr_lcd(0,0xc0);
wr_lcd(0,0x40+y+b*y1);
d=a*x1*y1*rom+b*x1*y1+c*y1;
for(e=0;e<y1;e++)
wr_lcd(1,str[d+e]);
void qpin()
static uchar a,b;
for(a=0;a<8;a++)
for(b=0;b<64;b++)
cs1=cs2=1;
disp(a,b,1,1,1,1,0x00);
void tpxsh()
cs1=1;cs2=0;
disp1(0,0,1,64,1,1,tp1);
disp1(1,0,1,64,1,1,tp1+64*2);
disp1(2,0,1,64,1,1,tp1+64*4);
disp1(3,0,1,64,1,1,tp1+64*6);
disp1(4,0,1,64,1,1,tp1+64*8);
disp1(5,0,1,64,1,1,tp1+64*10);
disp1(6,0,1,64,1,1,tp1+64*12);
disp1(7,0,1,64,1,1,tp1+64*14);
cs1=0;cs2=1;
disp1(0,0,1,64,1,1,tp1+64);
disp1(1,0,1,64,1,1,tp1+64*3);
disp1(2,0,1,64,1,1,tp1+64*5);
disp1(3,0,1,64,1,1,tp1+64*7);
disp1(4,0,1,64,1,1,tp1+64*9);
disp1(5,0,1,64,1,1,tp1+64*11);
disp1(6,0,1,64,1,1,tp1+64*13);
disp1(7,0,1,64,1,1,tp1+64*15);
uchar code tp1[]={
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0xE0,0xF0,0xF8,
0xFC,0xFC,0xFE,0xFE,0xFE,0xFE,0xFE,0xFE,0xFE,0xFC,0xFC,0xF8,0xF0,0x60,0x00,0x00,
0x40,0xE0,0xF0,0xF8,0xFC,0xFC,0xFE,0xFE,0xFE,0xFE,0xFE,0xFE,0xFE,0xFC,0xFC,0xF8,
0xF0,0xE0,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7E,0xFF,0xFF,0xFF,0xFF,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x3F,0x0F,0x07,0x03,0x00,0x00,0x00,0x00,
0x00,0x00,0x01,0x03,0x07,0x0F,0x3F,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
0xFF,0xFF,0xFF,0x3E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x07,0x0F,0x1F,
0x3F,0x7F,0xFF,0x7F,0x1F,0x07,0x01,0x00,0x00,0x00,0x00,0x60,0x62,0x34,0x1C,0x1C,
0x9C,0xBC,0xF8,0x78,0x70,0x70,0x60,0x20,0x08,0x00,0x30,0x38,0x30,0x30,0x78,0xF8,
0xFC,0x1C,0x1C,0x1C,0x14,0x36,0x76,0x66,0x66,0x64,0x64,0xE8,0x68,0x60,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x07,0x1F,0xFF,0xFF,0x7F,0x3F,0x1F,
0x0F,0x07,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x81,0x83,
0x41,0x21,0x21,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x01,0x61,0x43,0xC3,0x82,0x02,0x02,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0xC0,0xE0,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x59,0x9D,0x0C,0x04,
0x82,0x83,0x82,0x82,0x86,0x86,0x84,0x84,0x84,0x8C,0xBC,0x94,0x86,0x86,0x80,0x80,
0x80,0x80,0x80,0x80,0x80,0xC3,0x42,0x6E,0x1C,0x1C,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x08,0xC0,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFC,0xFE,0xFF,0xFF,0xFF,0xFF,0xFF,0xF0,
0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0C,0x1F,0x1F,0x00,
0x00,0x08,0x19,0x31,0x61,0x61,0x61,0x60,0x60,0x60,0x61,0x21,0x10,0x00,0x00,0x0C,
0x0C,0x04,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0xFE,0xFF,0xFF,
0xFE,0xF8,0xF0,0xE0,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
0xFF,0xFE,0xFC,0xF8,0xF0,0xE0,0xC0,0xC0,0x80,0x80,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x80,0x80,0xC0,0xE0,0xF0,0xF8,0xFE,0xFF,0xFF,0xFF,0xFF,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFC,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0xFE,0xFC,0xFC,
0xF8,0xF8,0xF8,0xF8,0xF0,0xF0,0xF0,0xE0,0xE0,0xE0,0xE0,0xE0,0xE0,0xE0,0xE0,0xE0,
0xE0,0xE0,0xE0,0xE0,0xE0,0xF0,0xF0,0xF0,0xF0,0xF0,0xF8,0xF8,0xF8,0xF8,0xFC,0xFC,
0xFC,0xFE,0xFE,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
自己去定义端口,我写得有点简单 |
