- #include <reg51.h>
- #define uint unsigned int
- #define uchar unsigned char
- #define HALFF 460800 //11.9652MHZ晶振的半频率
- #define MAX 65536 //16位计数器最大计数次数
- #define LED P3 //小灯 P0
- #define input P1 //键盘 P1
- #define soo 784//中音'5'
- #define dao 523 //宏定义高音‘1’频率为1047Hz
- #define re 587
- #define mi 659
- #define fa 698
- #define so 784
- #define la 880
- #define xi 988
- sbit SPEAK = P2^3; //蜂鸣器声音不怎么样,我们使用扬声器,接P2.3口
- sbit S1 = P3^3;
- uint C; //定时器初始值定义
- bit flag=0; //功能切换标志位
- uchar STH0;
- uchar STL0;
- uchar code lab[] = {dao,re,mi,fa,so,la,xi,soo,0XFF};
- void delay()
- uint i,j;
- for(i=0; i<1000; i++)
- for(j=0; j<120; j++); //1ms
- void DelayMs(uint n) //误差 0us ,延时n毫秒
- uint a,b,c;
- for(c=n; c>0; c--)
- for(b=199; b>0; b--)
- for(a=1; a>0; a--);
- /******************************频率发生函数 定时器T0*******************/
- void t0() interrupt 1 using 1
- TH0 =STH0;
- TL0 =STL0;
- SPEAK = ~SPEAK;
- void INT0_init(void) //定时器0初始化
- TMOD = 0x01; //定时器T0用工作方式1(16位计数器)
- EA = 1; //开总中断
- ET0 = 1; //开定时器T0中断
- TR0 = 0; //T0停止运行状态
- void play_song() //《两只老虎》编曲
- uchar i,j;
- uint code song[] = {dao,re,mi,dao,
- dao,re,mi,dao,
- mi,fa,so,
- mi,fa,so,
- so,la,so,fa,mi,dao,
- re,soo,dao,
- re,soo,dao,
- 0xff}; //以0xff为音符结束标志
- //以下为每个音符节拍,4个延时单位为1拍
- //'4'对应4个延时单位,'2'对应2个延时单位,'1'对应1个
- uchar code JP[] = {4,4,4,4,
- 4,4,4,4,
- 4,4,8,
- 4,4,8,
- 3,1,3,1,4,4,
- 3,1,3,1,4,4,
- 4,4,8,
- 4,4,8
- EA = 1; //开总中断
- while(!flag)
- i = 0;
- while(song[i] != 0xff)
- C = HALFF/song[i];
- STH0 = (MAX - C) / 256; // 高8位
- STL0 = (MAX - C) % 256; // 低8位
- TR0 = 1; //启动定时器
- for(j=0; j<JP[i]; j++) //控制节拍
- delay(); //延时1个延时单位
- TR0 = 0; //关闭定时器
- i++; //播放下一个音符
- void key_play()
- uchar temp;
- uchar num;
- input = 0xff;
- if(input!=0xff) //按键输入P1口
- DelayMs(5);
- if(input!=0xff)
- temp = input;
- switch(temp)
- case 0xfe:
- num=0;
- break;
- case 0xfd:
- num=1;
- break;
- case 0xfb:
- num=2;
- break;
- case 0xf7:
- num=3;
- break;
- case 0xef:
- num=4;
- break;
- case 0xdf:
- num=5;
- break;
- case 0xbf:
- num=6;
- break;
- case 0x7f:
- num=7;
- break;
- default:
- num=8;
- break;
- C = lab[num]; //定时器0的初值
- if( C == 0XFF )
- TR0 = 1;
设计一 电子琴.rar
(1014.66 KB, 下载次数: 56)
