基于51单片机的秒表系统设计。包含KEIL工程文件和PROTEUS仿真文件
- #include<reg51.h>
- #define uchar unsigned char
- sbit dula=P2^6;
- sbit wela=P2^7;
- sbit beep=P2^3;
- sbit key0=P1^0;
- sbit key1=P1^1;
- sbit key2=P1^2;
- sbit key3=P1^3;
- sbit led=P1^6;
- unsigned char j,k,c5,c4,c3,c2,c1,c0,m,n=255,a,b,c,stop;
- unsigned char m1,m2,m3,m4,m5;
- unsigned char pp;
- unsigned char trigger=5;
- unsigned char code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,
- 0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
- void delay(unsigned char i)
- for(j=i;j>0;j--)
- for(k=125;k>0;k--);
- void display(uchar a,uchar b,uchar c,uchar d,uchar e,uchar f)
- P0=table[a];
- dula=1;
- dula=0;
- P0=0xfe;
- wela=1;
- wela=0;
- delay(5);
- P0=0;
- dula=1;
- dula=0;
- P0=0xfe;
- wela=1;
- wela=0;
- P0=table[b];
- dula=1;
- dula=0;
- P0=0xfd;
- wela=1;
- wela=0;
- delay(5);
- P0=0;
- dula=1;
- dula=0;
- P0=0xfd;
- wela=1;
- wela=0;
- P0=table[c];
- dula=1;
- dula=0;
- P0=0xfb;
- wela=1;
- wela=0;
- delay(5);
- P0=0;
- dula=1;
- dula=0;
- P0=0xfb;
- wela=1;
- wela=0;
- P0=table[d];
- dula=1;
- dula=0;
- P0=0xf7;
- wela=1;
- wela=0;
- delay(5);
- P0=0;
- dula=1;
- dula=0;
- P0=0xf7;
- wela=1;
- wela=0;
- P0=table[e];
- dula=1;
- dula=0;
- P0=0xef;
- wela=1;
- wela=0;
- delay(5);
- P0=0;
- dula=1;
- dula=0;
- P0=0xef;
- wela=1;
- wela=0;
- P0=table[f];
- dula=1;
- dula=0;
- P0=0xdf;
- wela=1;
- wela=0;
- delay(5);
- P0=0;
- dula=1;
- dula=0;
- P0=0xdf;
- wela=1;
- wela=0;
- void hurry()//秒声
- uchar i;
- for(i=8;i>0;i--)
- beep=1;
- delay(5);
- beep=0;
- delay(5);
- void baojin()//报警
- uchar i;
- for(i=100;i>0;i--)
- beep=1;
- delay(5);
- beep=0;
- delay(5);
- void main()
- TMOD=0x01; //模式设置,00000001,可见采用的是定时器0,工作与模式1(M1=0,M0=1)。
- // TR0=1; //打开定时器
- TH0=(65536-4608)/256;// 由于晶振为11.0592,故所记次数应为4608,计时器每隔5000微秒发起一次中断。
- TL0=(65536-4608)%256;//4608的来历,为5000*11.0592/12
- ET0=1; //开定时器0中断
- EA=1; //开总中断
- while(1)
- //stop-go on
- if(key0==0)
- delay(5);
- if(key0==0)
- while(!key0);
- TR0=~TR0;
- //clear
- if(key1==0)
- if(key1==0)
- while(!key1);
- c5=0;c4=0;c3=0;
- c2=0;c1=0;c0=0;
- m1=0;m2=0;m3=0;m4=0;m5=0;
- TR0=0;led=0;
- //show
- display(c5,c4,c3,c2,c1,c0);
- void TIME0()interrupt 1
- uchar i;
- TH0=(65535-4608)/256;
- TL0=(65535-4608)%256;
- i++;
- if(i==20)
- m1++;
- if(m1==10)
- m1=0;
- m2++;
- hurry();
- if(m2==60)
- m2=0;
- m3++;
- if(m3==60)
- m3=0;
- m4++;
- if(m4==10)
- baojin();
- c0=m2%10;
- c1=m2/10;
- c2=m3%10;
- c3=m3/10;
- c4=m4%10;
- c5=m4/10;
- i=0;
1_秒表系统√.rar
(139.5 KB, 下载次数: 86)
