需要的硬件:51单片机、IIC通信的0.96oled显示屏
使用4管脚IIC通信,让0.96寸oled显示屏显示数字、字符和汉字
硬件连接:
SCL——P1^0
SDA——P1^1
代码包含主函数、IIC通信模块、oled显示函数和font头文件(font用来存放常用的ASCII表和中文字模)
程序如下:
main.c
- #include "reg52.h"
- #include "iic.h"
- #include "oled.h"
- #define uchar unsigned char
- uchar data_byte;
- u8 RH,RL,TH,TL,U8FLAG;
- void delay(uchar ms) //延时模块//
- uchar i;
- while(ms--)
- for(i=0;i<100;i++);
- void main()
- OLED_Init();
- OLED_Clear();
- while(1)
- // OLED_ColorTurn(1); //颜色取反
- // OLED_DisplayTurn(0); //屏幕反转
- OLED_ShowCHinese(0,0,0);//这
- OLED_ShowCHinese(16,0,1);//是
- OLED_ShowCHinese(16*2,0,2);//一
- OLED_ShowCHinese(16*3,0,3);//个
- OLED_ShowCHinese(16*4,0,4);//汉
- OLED_ShowCHinese(16*5,0,5);//字
- OLED_ShowString(16*6,0,":",16);
- OLED_ShowNum(16*7,0,8,1,16);
iic.h
- #ifndef _IIC_H
- #define _IIC_H
- #include "REG52.h"
- #define u8 unsigned char
- #define u32 unsigned int
- sbit SCL=P1^0;//时钟 D0(SCLK?
- sbit SDIN=P1^1;//D1(MOSI) 数据
- #define SCLK_Clr() SCL=0
- #define SCLK_Set() SCL=1
- #define SDIN_Clr() SDIN=0
- #define SDIN_Set() SDIN=1
- void IIC_Start();
- void IIC_Stop();
- void Write_IIC_Command(unsigned char IIC_Command);
- void Write_IIC_Data(unsigned char IIC_Data);
- void Write_IIC_Byte(unsigned char IIC_Byte);
- void IIC_Wait_Ack();
- #endif
iic.c
- #include "iic.h"
- void IIC_Start()
- SCLK_Set() ;
- SDIN_Set();
- SDIN_Clr();
- SCLK_Clr();
- void IIC_Stop()
- SCLK_Set() ;
- // SCLK_Clr();
- SDIN_Clr();
- SDIN_Set();
- SCLK_Set() ;
- SCLK_Clr();
- unsigned char i;
- unsigned char m,da;
- da=IIC_Byte;
- SCLK_Clr();
- for(i=0;i<8;i++)
- m=da;
- // SCLK_Clr();
- m=m&0x80;
- if(m==0x80)
- {SDIN_Set();}
- else SDIN_Clr();
- da=da<<1;
- SCLK_Set();
- SCLK_Clr();
- IIC_Start();
- Write_IIC_Byte(0x78); //Slave address,SA0=0
- IIC_Wait_Ack();
- Write_IIC_Byte(0x00); //write command
- IIC_Wait_Ack();
- Write_IIC_Byte(IIC_Command);
- IIC_Wait_Ack();
- IIC_Stop();
- IIC_Start();
- Write_IIC_Byte(0x78); //D/C#=0; R/W#=0
- IIC_Wait_Ack();
- Write_IIC_Byte(0x40); //write data
- IIC_Wait_Ack();
- Write_IIC_Byte(IIC_Data);
- IIC_Wait_Ack();
- IIC_Stop();
oled.h
- #ifndef _OLED_H
- #define _OLED_H
- #define OLED_CMD 0 //写命令
- #define OLED_DATA 1 //写数据
- #define OLED_MODE 0
- #define OLED_CS_Clr() OLED_CS=0
- #define OLED_CS_Set() OLED_CS=1
- #define OLED_RST_Clr() OLED_RST=0
- #define OLED_RST_Set() OLED_RST=1
- #define OLED_DC_Clr() OLED_DC=0
- #define OLED_DC_Set() OLED_DC=1
- //OLED模式设置
- //0:4线串行模式
- //1:并行8080模式
- #define SIZE 16
- #define XLevelL 0x02
- #define XLevelH 0x10
- #define Max_Column 128
- #define Max_Row 64
- #define Brightness 0xFF
- #define X_WIDTH 128
- #define Y_WIDTH 64
- void delay_ms(unsigned int ms);
- //OLED控制用函数
- void OLED_WR_Byte(unsigned dat,unsigned cmd);
- void OLED_Display_On(void);
- void OLED_Display_Off(void);
- void OLED_Clear(void);
- //void OLED_DrawPoint(u8 x,u8 y,u8 t);
- //void OLED_Fill(u8 x1,u8 y1,u8 x2,u8 y2,u8 dot);
- void OLED_ShowChar(u8 x,u8 y,u8 chr,u8 Char_Size);
- void OLED_ShowNum(u8 x,u8 y,u32 num,u8 len,u8 size);
- void OLED_ShowString(u8 x,u8 y, u8 *p,u8 Char_Size);
- void OLED_Set_Pos(unsigned char x, unsigned char y);
- void OLED_ShowCHinese(u8 x,u8 y,u8 no);
- void OLED_ColorTurn(u8 i);
- void OLED_DisplayTurn(u8 i);
- void oled_showpictues(unsigned char x0,unsigned char y0,unsigned char x1,unsigned char y1,unsigned char BMP[]);
- //void OLED_DrawBMP(unsigned char x0, unsigned char y0,unsigned char x1, unsigned char y1,unsigned char BMP[]);
- //void Delay_50ms(unsigned int Del_50ms);
- //void Delay_1ms(unsigned int Del_1ms);
- //void fill_picture(unsigned char fill_Data);
- //void Picture();
- void OLED_Init(void);
- #endif
oled.c
- #include "oled.h"
- #include "iic.h"
- #include "font.h"
- unsigned int a;
- while(ms)
- a=1800;
- while(a--);
- ms--;
- return;
- if(cmd)
- Write_IIC_Data(dat);
- else {
- Write_IIC_Command(dat);
- //反显函数
- if(i==0)
- OLED_WR_Byte(0xA6,OLED_CMD);//正常显示
- if(i==1)
- OLED_WR_Byte(0xA7,OLED_CMD);//反色显示
- //屏幕旋转180度
- if(i==0)
- OLED_WR_Byte(0xC8,OLED_CMD);//正常显示
- OLED_WR_Byte(0xA1,OLED_CMD);
- if(i==1)
- OLED_WR_Byte(0xC0,OLED_CMD);//反转显示
- OLED_WR_Byte(0xA0,OLED_CMD);
- //坐标设置
- { OLED_WR_Byte(0xb0+y,OLED_CMD);
- OLED_WR_Byte(((x&0xf0)>>4)|0x10,OLED_CMD);
- OLED_WR_Byte((x&0x0f),OLED_CMD);
- //开启OLED显示
- OLED_WR_Byte(0X8D,OLED_CMD); //SET DCDC命令
- OLED_WR_Byte(0X14,OLED_CMD); //DCDC ON
- OLED_WR_Byte(0XAF,OLED_CMD); //DISPLAY ON
- //关闭OLED显示
- OLED_WR_Byte(0X10,OLED_CMD); //DCDC OFF
- OLED_WR_Byte(0XAE,OLED_CMD); //DISPLAY OFF
- //清屏函数,清完屏,整个屏幕是黑色的!和没点亮一样!!!
- u8 i,n;
- for(i=0;i<8;i++)
- OLED_WR_Byte (0xb0+i,OLED_CMD); //设置页地址(0~7)
- OLED_WR_Byte (0x00,OLED_CMD); //设置显示位置—列低地址
- OLED_WR_Byte (0x10,OLED_CMD); //设置显示位置—列高地址
- for(n=0;n<128;n++)OLED_WR_Byte(0,OLED_DATA);
- } //更新显示
- void OLED_On(void)
- u8 i,n;
- for(i=0;i<8;i++)
- for(n=0;n<128;n++)OLED_WR_Byte(1,OLED_DATA);
- } //更新显示
- //在指定位置显示一个字符,包括部分字符
- //x:0~127
- //y:0~63
- //mode:0,反白显示;1,正常显示
- //size:选择字体 16/12
- unsigned char c=0,i=0;
- c=chr-' ';//得到偏移后的值
- if(x>Max_Column-1){x=0;y=y+2;}
- if(Char_Size ==16)
- OLED_Set_Pos(x,y);
- for(i=0;i<8;i++)
- OLED_WR_Byte(F8X16[c*16+i],OLED_DATA);
- OLED_Set_Pos(x,y+1);
- for(i=0;i<8;i++)
- OLED_WR_Byte(F8X16[c*16+i+8],OLED_DATA);
- else {
- for(i=0;i<6;i++)
- OLED_WR_Byte(F6x8[c][i],OLED_DATA);
- //m^n函数
- u32 oled_pow(u8 m,u8 n)
- u32 result=1;
- while(n--)result*=m;
- return result;
- //显示2个数字
- //x,y :起点坐标
- //len :数字的位数
- //size:字体大小
- //mode:模式 0,填充模式;1,叠加模式
- //num:数值(0~4294967295);
- void OLED_ShowNum(u8 x,u8 y,u32 num,u8 len,u8 size2)
- u8 t,temp;
- u8 enshow=0;
- for(t=0;t<len;t++)
- temp=(num/oled_pow(10,len-t-1))%10;
- if(enshow==0&&t<(len-1))
- if(temp==0)
- OLED_ShowChar(x+(size2/2)*t,y,' ',size2);
- continue;
- }else enshow=1;
- OLED_ShowChar(x+(size2/2)*t,y,temp+'0',size2);
- //显示一个字符号串
- void OLED_ShowString(u8 x,u8 y,u8 *chr,u8 Char_Size)
- unsigned char j=0;
- while (chr[j]!='\0')
- { OLED_ShowChar(x,y,chr[j],Char_Size);
- x+=8;
- if(x>120){x=0;y+=2;}
- j++;
- //显示汉字
- u8 t,adder=0;
- for(t=0;t<16;t++)
- OLED_WR_Byte(Hzk[2*no][t],OLED_DATA);
- adder+=1;
- for(t=0;t<16;t++)
- OLED_WR_Byte(Hzk[2*no+1][t],OLED_DATA);
- adder+=1;
- unsigned int i=0;
- unsigned char x,y;
- //if(y1%8==0) y=y1/8;
- //else y=y1/8+1;
- y1/=8;
- for(y=y0;y<y1;y++)
- OLED_Set_Pos(x0,y);
- for(x=x0;x<x1;x++)
- {Write_IIC_Data(BMP[i++]);}
- OLED_WR_Byte(0xAE,OLED_CMD);//--display off
- OLED_WR_Byte(0x00,OLED_CMD);//---set low column address
- OLED_WR_Byte(0x10,OLED_CMD);//---set high column address
- OLED_WR_Byte(0x40,OLED_CMD);//--set start line address
- OLED_WR_Byte(0xB0,OLED_CMD);//--set page address
- OLED_WR_Byte(0x81,OLED_CMD); // contract control
- OLED_WR_Byte(0xFF,OLED_CMD);//--128
- OLED_WR_Byte(0xA1,OLED_CMD);//set segment remap
- OLED_WR_Byte(0xA6,OLED_CMD);//--normal / reverse
- OLED_WR_Byte(0xA8,OLED_CMD);//--set multiplex ratio(1 to 64)
- OLED_WR_Byte(0x3F,OLED_CMD);//--1/32 duty
- OLED_WR_Byte(0xC8,OLED_CMD);//Com scan direction
- OLED_WR_Byte(0xD3,OLED_CMD);//-set display offset
- OLED_WR_Byte(0xD5,OLED_CMD);//set osc division
- OLED_WR_Byte(0x80,OLED_CMD);//
- OLED_WR_Byte(0xD8,OLED_CMD);//set area color mode off
- OLED_WR_Byte(0x05,OLED_CMD);//
- OLED_WR_Byte(0xD9,OLED_CMD);//Set Pre-Charge Period
- OLED_WR_Byte(0xF1,OLED_CMD);//
- OLED_WR_Byte(0xDA,OLED_CMD);//set com pin configuartion
- OLED_WR_Byte(0x12,OLED_CMD);//
- OLED_WR_Byte(0xDB,OLED_CMD);//set Vcomh
- OLED_WR_Byte(0x30,OLED_CMD);//
- OLED_WR_Byte(0x8D,OLED_CMD);//set charge pump enable
- OLED_WR_Byte(0x14,OLED_CMD);//
- OLED_WR_Byte(0xAF,OLED_CMD);//--turn on oled panel
font.h
- #ifndef _FONT_H
- #define _FONT_H
- //常用ASCII表
- //偏移量32
- //ASCII字符集: !"#$%&'()*+,-./0123456789:;<=>?@ABCDEFGHIJKLMNOPQRSTUVWXYZ[\]^_`abcdefghijklmnopqrstuvwxyz{|}~
- //偏移量32
- //总共:3个字符集(12*12、16*16和24*24),用户可以自行新增其他分辨率的字符集。
- /************************************6*8的点阵************************************/
- const unsigned char code F6x8[][6] =
- 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,// sp
- 0x00, 0x00, 0x00, 0x2f, 0x00, 0x00,// !
- 0x00, 0x00, 0x07, 0x00, 0x07, 0x00,// "
- 0x00, 0x14, 0x7f, 0x14, 0x7f, 0x14,// #
- 0x00, 0x24, 0x2a, 0x7f, 0x2a, 0x12,// $
- 0x00, 0x62, 0x64, 0x08, 0x13, 0x23,// %
- 0x00, 0x36, 0x49, 0x55, 0x22, 0x50,// &
- 0x00, 0x00, 0x05, 0x03, 0x00, 0x00,// '
- 0x00, 0x00, 0x1c, 0x22, 0x41, 0x00,// (
- 0x00, 0x00, 0x41, 0x22, 0x1c, 0x00,// )
- 0x00, 0x14, 0x08, 0x3E, 0x08, 0x14,// *
- 0x00, 0x08, 0x08, 0x3E, 0x08, 0x08,// +
- 0x00, 0x00, 0x00, 0xA0, 0x60, 0x00,// ,
- 0x00, 0x08, 0x08, 0x08, 0x08, 0x08,// -
- 0x00, 0x00, 0x60, 0x60, 0x00, 0x00,// .
- 0x00, 0x20, 0x10, 0x08, 0x04, 0x02,// /
- 0x00, 0x3E, 0x51, 0x49, 0x45, 0x3E,// 0
- 0x00, 0x00, 0x42, 0x7F, 0x40, 0x00,// 1
- 0x00, 0x42, 0x61, 0x51, 0x49, 0x46,// 2
- 0x00, 0x21, 0x41, 0x45, 0x4B, 0x31,// 3
- 0x00, 0x18, 0x14, 0x12, 0x7F, 0x10,// 4
- 0x00, 0x27, 0x45, 0x45, 0x45, 0x39,// 5
- 0x00, 0x3C, 0x4A, 0x49, 0x49, 0x30,// 6
- 0x00, 0x01, 0x71, 0x09, 0x05, 0x03,// 7
- 0x00, 0x36, 0x49, 0x49, 0x49, 0x36,// 8
- 0x00, 0x06, 0x49, 0x49, 0x29, 0x1E,// 9
- 0x00, 0x00, 0x36, 0x36, 0x00, 0x00,// :
- 0x00, 0x00, 0x56, 0x36, 0x00, 0x00,// ;
- 0x00, 0x08, 0x14, 0x22, 0x41, 0x00,// <
- 0x00, 0x14, 0x14, 0x14, 0x14, 0x14,// =
- 0x00, 0x00, 0x41, 0x22, 0x14, 0x08,// >
- 0x00, 0x02, 0x01, 0x51, 0x09, 0x06,// ?
- 0x00, 0x32, 0x49, 0x59, 0x51, 0x3E,// @
- 0x00, 0x7C, 0x12, 0x11, 0x12, 0x7C,// A
- 0x00, 0x7F, 0x49, 0x49, 0x49, 0x36,// B
- 0x00, 0x3E, 0x41, 0x41, 0x41, 0x22,// C
- 0x00, 0x7F, 0x41, 0x41, 0x22, 0x1C,// D
- 0x00, 0x7F, 0x49, 0x49, 0x49, 0x41,// E
- 0x00, 0x7F, 0x09, 0x09, 0x09, 0x01,// F
- 0x00, 0x3E, 0x41, 0x49, 0x49, 0x7A,// G
- 0x00, 0x7F, 0x08, 0x08, 0x08, 0x7F,// H
- 0x00, 0x00, 0x41, 0x7F, 0x41, 0x00,// I
- 0x00, 0x20, 0x40, 0x41, 0x3F, 0x01,// J
- 0x00, 0x7F, 0x08, 0x14, 0x22, 0x41,// K
- 0x00, 0x7F, 0x40, 0x40, 0x40, 0x40,// L
- 0x00, 0x7F, 0x02, 0x0C, 0x02, 0x7F,// M
- 0x00, 0x7F, 0x04, 0x08, 0x10, 0x7F,// N
- 0x00, 0x3E, 0x41, 0x41, 0x41, 0x3E,// O
- 0x00, 0x7F, 0x09, 0x09, 0x09, 0x06,// P
- 0x00, 0x3E, 0x41, 0x51, 0x21, 0x5E,// Q
- 0x00, 0x7F, 0x09, 0x19, 0x29, 0x46,// R
- 0x00, 0x46, 0x49, 0x49, 0x49, 0x31,// S
- 0x00, 0x01, 0x01, 0x7F, 0x01, 0x01,// T
- 0x00, 0x3F, 0x40, 0x40, 0x40, 0x3F,// U
- 0x00, 0x1F, 0x20, 0x40, 0x20, 0x1F,// V
- 0x00, 0x3F, 0x40, 0x38, 0x40, 0x3F,// W
- 0x00, 0x63, 0x14, 0x08, 0x14, 0x63,// X
- 0x00, 0x07, 0x08, 0x70, 0x08, 0x07,// Y
- 0x00, 0x61, 0x51, 0x49, 0x45, 0x43,// Z
- 0x00, 0x00, 0x7F, 0x41, 0x41, 0x00,// [
- 0x00, 0x55, 0x2A, 0x55, 0x2A, 0x55,// 55
- 0x00, 0x00, 0x41, 0x41, 0x7F, 0x00,// ]
- 0x00, 0x04, 0x02, 0x01, 0x02, 0x04,// ^
- 0x00, 0x40, 0x40, 0x40, 0x40, 0x40,// _
- 0x00, 0x00, 0x01, 0x02, 0x04, 0x00,// '
- 0x00, 0x20, 0x54, 0x54, 0x54, 0x78,// a
- 0x00, 0x7F, 0x48, 0x44, 0x44, 0x38,// b
- 0x00, 0x38, 0x44, 0x44, 0x44, 0x20,// c
- 0x00, 0x38, 0x44, 0x44, 0x48, 0x7F,// d
- 0x00, 0x38, 0x54, 0x54, 0x54, 0x18,// e
- 0x00, 0x08, 0x7E, 0x09, 0x01, 0x02,// f
- 0x00, 0x18, 0xA4, 0xA4, 0xA4, 0x7C,// g
- 0x00, 0x7F, 0x08, 0x04, 0x04, 0x78,// h
- 0x00, 0x00, 0x44, 0x7D, 0x40, 0x00,// i
- 0x00, 0x40, 0x80, 0x84, 0x7D, 0x00,// j
- 0x00, 0x7F, 0x10, 0x28, 0x44, 0x00,// k
- 0x00, 0x00, 0x41, 0x7F, 0x40, 0x00,// l
- 0x00, 0x7C, 0x04, 0x18, 0x04, 0x78,// m
- 0x00, 0x7C, 0x08, 0x04, 0x04, 0x78,// n
- 0x00, 0x38, 0x44, 0x44, 0x44, 0x38,// o
- 0x00, 0xFC, 0x24, 0x24, 0x24, 0x18,// p
- 0x00, 0x18, 0x24, 0x24, 0x18, 0xFC,// q
- 0x00, 0x7C, 0x08, 0x04, 0x04, 0x08,// r
- 0x00, 0x48, 0x54, 0x54, 0x54, 0x20,// s
- 0x00, 0x04, 0x3F, 0x44, 0x40, 0x20,// t
- 0x00, 0x3C, 0x40, 0x40, 0x20, 0x7C,// u
- 0x00, 0x1C, 0x20, 0x40, 0x20, 0x1C,// v
- 0x00, 0x3C, 0x40, 0x30, 0x40, 0x3C,// w
- 0x00, 0x44, 0x28, 0x10, 0x28, 0x44,// x
- 0x00, 0x1C, 0xA0, 0xA0, 0xA0, 0x7C,// y
- 0x00, 0x44, 0x64, 0x54, 0x4C, 0x44,// z
- 0x14, 0x14, 0x14, 0x14, 0x14, 0x14,// horiz lines
- /****************************************8*16的点阵************************************/
- const unsigned char code F8X16[]=
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,// 0
- 0x00,0x00,0x00,0xF8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x33,0x30,0x00,0x00,0x00,//! 1
- 0x00,0x10,0x0C,0x06,0x10,0x0C,0x06,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//" 2
- 0x40,0xC0,0x78,0x40,0xC0,0x78,0x40,0x00,0x04,0x3F,0x04,0x04,0x3F,0x04,0x04,0x00,//# 3
- 0x00,0x70,0x88,0xFC,0x08,0x30,0x00,0x00,0x00,0x18,0x20,0xFF,0x21,0x1E,0x00,0x00,//$ 4
- 0xF0,0x08,0xF0,0x00,0xE0,0x18,0x00,0x00,0x00,0x21,0x1C,0x03,0x1E,0x21,0x1E,0x00,//% 5
- 0x00,0xF0,0x08,0x88,0x70,0x00,0x00,0x00,0x1E,0x21,0x23,0x24,0x19,0x27,0x21,0x10,//& 6
- 0x10,0x16,0x0E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//' 7
- 0x00,0x00,0x00,0xE0,0x18,0x04,0x02,0x00,0x00,0x00,0x00,0x07,0x18,0x20,0x40,0x00,//( 8
- 0x00,0x02,0x04,0x18,0xE0,0x00,0x00,0x00,0x00,0x40,0x20,0x18,0x07,0x00,0x00,0x00,//) 9
- 0x40,0x40,0x80,0xF0,0x80,0x40,0x40,0x00,0x02,0x02,0x01,0x0F,0x01,0x02,0x02,0x00,//* 10
- 0x00,0x00,0x00,0xF0,0x00,0x00,0x00,0x00,0x01,0x01,0x01,0x1F,0x01,0x01,0x01,0x00,//+ 11
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0xB0,0x70,0x00,0x00,0x00,0x00,0x00,//, 12
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x01,0x01,0x01,0x01,0x01,0x01,//- 13
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x30,0x00,0x00,0x00,0x00,0x00,//. 14
- 0x00,0x00,0x00,0x00,0x80,0x60,0x18,0x04,0x00,0x60,0x18,0x06,0x01,0x00,0x00,0x00,/// 15
- 0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,0x00,0x0F,0x10,0x20,0x20,0x10,0x0F,0x00,//0 16
- 0x00,0x10,0x10,0xF8,0x00,0x00,0x00,0x00,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00,//1 17
- 0x00,0x70,0x08,0x08,0x08,0x88,0x70,0x00,0x00,0x30,0x28,0x24,0x22,0x21,0x30,0x00,//2 18
- 0x00,0x30,0x08,0x88,0x88,0x48,0x30,0x00,0x00,0x18,0x20,0x20,0x20,0x11,0x0E,0x00,//3 19
- 0x00,0x00,0xC0,0x20,0x10,0xF8,0x00,0x00,0x00,0x07,0x04,0x24,0x24,0x3F,0x24,0x00,//4 20
- 0x00,0xF8,0x08,0x88,0x88,0x08,0x08,0x00,0x00,0x19,0x21,0x20,0x20,0x11,0x0E,0x00,//5 21
- 0x00,0xE0,0x10,0x88,0x88,0x18,0x00,0x00,0x00,0x0F,0x11,0x20,0x20,0x11,0x0E,0x00,//6 22
- 0x00,0x38,0x08,0x08,0xC8,0x38,0x08,0x00,0x00,0x00,0x00,0x3F,0x00,0x00,0x00,0x00,//7 23
- 0x00,0x70,0x88,0x08,0x08,0x88,0x70,0x00,0x00,0x1C,0x22,0x21,0x21,0x22,0x1C,0x00,//8 24
- 0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,0x00,0x00,0x31,0x22,0x22,0x11,0x0F,0x00,//9 25
- 0x00,0x00,0x00,0xC0,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x30,0x00,0x00,0x00,//: 26
- 0x00,0x00,0x00,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x60,0x00,0x00,0x00,0x00,//; 27
- 0x00,0x00,0x80,0x40,0x20,0x10,0x08,0x00,0x00,0x01,0x02,0x04,0x08,0x10,0x20,0x00,//< 28
- 0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x00,0x04,0x04,0x04,0x04,0x04,0x04,0x04,0x00,//= 29
- 0x00,0x08,0x10,0x20,0x40,0x80,0x00,0x00,0x00,0x20,0x10,0x08,0x04,0x02,0x01,0x00,//> 30
- 0x00,0x70,0x48,0x08,0x08,0x08,0xF0,0x00,0x00,0x00,0x00,0x30,0x36,0x01,0x00,0x00,//? 31
- 0xC0,0x30,0xC8,0x28,0xE8,0x10,0xE0,0x00,0x07,0x18,0x27,0x24,0x23,0x14,0x0B,0x00,//@ 32
- 0x00,0x00,0xC0,0x38,0xE0,0x00,0x00,0x00,0x20,0x3C,0x23,0x02,0x02,0x27,0x38,0x20,//A 33
- 0x08,0xF8,0x88,0x88,0x88,0x70,0x00,0x00,0x20,0x3F,0x20,0x20,0x20,0x11,0x0E,0x00,//B 34
- 0xC0,0x30,0x08,0x08,0x08,0x08,0x38,0x00,0x07,0x18,0x20,0x20,0x20,0x10,0x08,0x00,//C 35
- 0x08,0xF8,0x08,0x08,0x08,0x10,0xE0,0x00,0x20,0x3F,0x20,0x20,0x20,0x10,0x0F,0x00,//D 36
- 0x08,0xF8,0x88,0x88,0xE8,0x08,0x10,0x00,0x20,0x3F,0x20,0x20,0x23,0x20,0x18,0x00,//E 37
- 0x08,0xF8,0x88,0x88,0xE8,0x08,0x10,0x00,0x20,0x3F,0x20,0x00,0x03,0x00,0x00,0x00,//F 38
- 0xC0,0x30,0x08,0x08,0x08,0x38,0x00,0x00,0x07,0x18,0x20,0x20,0x22,0x1E,0x02,0x00,//G 39
- 0x08,0xF8,0x08,0x00,0x00,0x08,0xF8,0x08,0x20,0x3F,0x21,0x01,0x01,0x21,0x3F,0x20,//H 40
- 0x00,0x08,0x08,0xF8,0x08,0x08,0x00,0x00,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00,//I 41
- 0x00,0x00,0x08,0x08,0xF8,0x08,0x08,0x00,0xC0,0x80,0x80,0x80,0x7F,0x00,0x00,0x00,//J 42
- 0x08,0xF8,0x88,0xC0,0x28,0x18,0x08,0x00,0x20,0x3F,0x20,0x01,0x26,0x38,0x20,0x00,//K 43
- 0x08,0xF8,0x08,0x00,0x00,0x00,0x00,0x00,0x20,0x3F,0x20,0x20,0x20,0x20,0x30,0x00,//L 44
- 0x08,0xF8,0xF8,0x00,0xF8,0xF8,0x08,0x00,0x20,0x3F,0x00,0x3F,0x00,0x3F,0x20,0x00,//M 45
- 0x08,0xF8,0x30,0xC0,0x00,0x08,0xF8,0x08,0x20,0x3F,0x20,0x00,0x07,0x18,0x3F,0x00,//N 46
- 0xE0,0x10,0x08,0x08,0x08,0x10,0xE0,0x00,0x0F,0x10,0x20,0x20,0x20,0x10,0x0F,0x00,//O 47
- 0x08,0xF8,0x08,0x08,0x08,0x08,0xF0,0x00,0x20,0x3F,0x21,0x01,0x01,0x01,0x00,0x00,//P 48
- 0xE0,0x10,0x08,0x08,0x08,0x10,0xE0,0x00,0x0F,0x18,0x24,0x24,0x38,0x50,0x4F,0x00,//Q 49
- 0x08,0xF8,0x88,0x88,0x88,0x88,0x70,0x00,0x20,0x3F,0x20,0x00,0x03,0x0C,0x30,0x20,//R 50
- 0x00,0x70,0x88,0x08,0x08,0x08,0x38,0x00,0x00,0x38,0x20,0x21,0x21,0x22,0x1C,0x00,//S 51
- 0x18,0x08,0x08,0xF8,0x08,0x08,0x18,0x00,0x00,0x00,0x20,0x3F,0x20,0x00,0x00,0x00,//T 52
- 0x08,0xF8,0x08,0x00,0x00,0x08,0xF8,0x08,0x00,0x1F,0x20,0x20,0x20,0x20,0x1F,0x00,//U 53
- 0x08,0x78,0x88,0x00,0x00,0xC8,0x38,0x08,0x00,0x00,0x07,0x38,0x0E,0x01,0x00,0x00,//V 54
- 0xF8,0x08,0x00,0xF8,0x00,0x08,0xF8,0x00,0x03,0x3C,0x07,0x00,0x07,0x3C,0x03,0x00,//W 55
- 0x08,0x18,0x68,0x80,0x80,0x68,0x18,0x08,0x20,0x30,0x2C,0x03,0x03,0x2C,0x30,0x20,//X 56
- 0x08,0x38,0xC8,0x00,0xC8,0x38,0x08,0x00,0x00,0x00,0x20,0x3F,0x20,0x00,0x00,0x00,//Y 57
- 0x10,0x08,0x08,0x08,0xC8,0x38,0x08,0x00,0x20,0x38,0x26,0x21,0x20,0x20,0x18,0x00,//Z 58
- 0x00,0x00,0x00,0xFE,0x02,0x02,0x02,0x00,0x00,0x00,0x00,0x7F,0x40,0x40,0x40,0x00,//[ 59
- 0x00,0x0C,0x30,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x06,0x38,0xC0,0x00,//\ 60
- 0x00,0x02,0x02,0x02,0xFE,0x00,0x00,0x00,0x00,0x40,0x40,0x40,0x7F,0x00,0x00,0x00,//] 61
- 0x00,0x00,0x04,0x02,0x02,0x02,0x04,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//^ 62
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,//_ 63
- 0x00,0x02,0x02,0x04,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//` 64
- 0x00,0x00,0x80,0x80,0x80,0x80,0x00,0x00,0x00,0x19,0x24,0x22,0x22,0x22,0x3F,0x20,//a 65
- 0x08,0xF8,0x00,0x80,0x80,0x00,0x00,0x00,0x00,0x3F,0x11,0x20,0x20,0x11,0x0E,0x00,//b 66
- 0x00,0x00,0x00,0x80,0x80,0x80,0x00,0x00,0x00,0x0E,0x11,0x20,0x20,0x20,0x11,0x00,//c 67
- 0x00,0x00,0x00,0x80,0x80,0x88,0xF8,0x00,0x00,0x0E,0x11,0x20,0x20,0x10,0x3F,0x20,//d 68
- 0x00,0x00,0x80,0x80,0x80,0x80,0x00,0x00,0x00,0x1F,0x22,0x22,0x22,0x22,0x13,0x00,//e 69
- 0x00,0x80,0x80,0xF0,0x88,0x88,0x88,0x18,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00,//f 70
- 0x00,0x00,0x80,0x80,0x80,0x80,0x80,0x00,0x00,0x6B,0x94,0x94,0x94,0x93,0x60,0x00,//g 71
- 0x08,0xF8,0x00,0x80,0x80,0x80,0x00,0x00,0x20,0x3F,0x21,0x00,0x00,0x20,0x3F,0x20,//h 72
- 0x00,0x80,0x98,0x98,0x00,0x00,0x00,0x00,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00,//i 73
- 0x00,0x00,0x00,0x80,0x98,0x98,0x00,0x00,0x00,0xC0,0x80,0x80,0x80,0x7F,0x00,0x00,//j 74
- 0x08,0xF8,0x00,0x00,0x80,0x80,0x80,0x00,0x20,0x3F,0x24,0x02,0x2D,0x30,0x20,0x00,//k 75
- 0x00,0x08,0x08,0xF8,0x00,0x00,0x00,0x00,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00,//l 76
- 0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x00,0x20,0x3F,0x20,0x00,0x3F,0x20,0x00,0x3F,//m 77
- 0x80,0x80,0x00,0x80,0x80,0x80,0x00,0x00,0x20,0x3F,0x21,0x00,0x00,0x20,0x3F,0x20,//n 78
- 0x00,0x00,0x80,0x80,0x80,0x80,0x00,0x00,0x00,0x1F,0x20,0x20,0x20,0x20,0x1F,0x00,//o 79
- 0x80,0x80,0x00,0x80,0x80,0x00,0x00,0x00,0x80,0xFF,0xA1,0x20,0x20,0x11,0x0E,0x00,//p 80
- 0x00,0x00,0x00,0x80,0x80,0x80,0x80,0x00,0x00,0x0E,0x11,0x20,0x20,0xA0,0xFF,0x80,//q 81
- 0x80,0x80,0x80,0x00,0x80,0x80,0x80,0x00,0x20,0x20,0x3F,0x21,0x20,0x00,0x01,0x00,//r 82
- 0x00,0x00,0x80,0x80,0x80,0x80,0x80,0x00,0x00,0x33,0x24,0x24,0x24,0x24,0x19,0x00,//s 83
- 0x00,0x80,0x80,0xE0,0x80,0x80,0x00,0x00,0x00,0x00,0x00,0x1F,0x20,0x20,0x00,0x00,//t 84
- 0x80,0x80,0x00,0x00,0x00,0x80,0x80,0x00,0x00,0x1F,0x20,0x20,0x20,0x10,0x3F,0x20,//u 85
- 0x80,0x80,0x80,0x00,0x00,0x80,0x80,0x80,0x00,0x01,0x0E,0x30,0x08,0x06,0x01,0x00,//v 86
- 0x80,0x80,0x00,0x80,0x00,0x80,0x80,0x80,0x0F,0x30,0x0C,0x03,0x0C,0x30,0x0F,0x00,//w 87
- 0x00,0x80,0x80,0x00,0x80,0x80,0x80,0x00,0x00,0x20,0x31,0x2E,0x0E,0x31,0x20,0x00,//x 88
- 0x80,0x80,0x80,0x00,0x00,0x80,0x80,0x80,0x80,0x81,0x8E,0x70,0x18,0x06,0x01,0x00,//y 89
- 0x00,0x80,0x80,0x80,0x80,0x80,0x80,0x00,0x00,0x21,0x30,0x2C,0x22,0x21,0x30,0x00,//z 90
- 0x00,0x00,0x00,0x00,0x80,0x7C,0x02,0x02,0x00,0x00,0x00,0x00,0x00,0x3F,0x40,0x40,//{ 91
- 0x00,0x00,0x00,0x00,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0x00,0x00,0x00,//| 92
- 0x00,0x02,0x02,0x7C,0x80,0x00,0x00,0x00,0x00,0x40,0x40,0x3F,0x00,0x00,0x00,0x00,//} 93
- 0x00,0x06,0x01,0x01,0x02,0x02,0x04,0x04,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//~ 94
- unsigned char code Hzk[][32]={
- /*-- 文字0: 这 --*/
- /*-- 宋体12; 此字体下对应的点阵为:宽x高=16x16 --*/
- {0x40,0x40,0x42,0xCC,0x00,0x08,0x28,0x48,0x89,0x0E,0xC8,0x38,0x08,0x08,0x00,0x00},
- {0x00,0x40,0x20,0x1F,0x20,0x50,0x48,0x44,0x42,0x41,0x42,0x44,0x58,0x40,0x40,0x00},
- /*-- 文字1: 是 --*/
- {0x00,0x00,0x00,0x7F,0x49,0x49,0x49,0x49,0x49,0x49,0x49,0x7F,0x00,0x00,0x00,0x00},
- {0x81,0x41,0x21,0x1D,0x21,0x41,0x81,0xFF,0x89,0x89,0x89,0x89,0x89,0x81,0x81,0x00},
- /*-- 文字2: 一 --*/
- {0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x00},
- {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},
- /*-- 文字3: 个 --*/
- {0x80,0x80,0x40,0x20,0x10,0x08,0x04,0xC3,0x04,0x08,0x10,0x20,0x40,0x80,0x80,0x00},
- {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},
- /*-- 文字4: 汉 --*/
- {0x10,0x60,0x02,0x0C,0xC0,0x02,0x1E,0xE2,0x02,0x02,0x02,0xE2,0x1E,0x00,0x00,0x00},
- {0x04,0x04,0x7C,0x03,0x80,0x80,0x40,0x20,0x13,0x0C,0x13,0x20,0x40,0x80,0x80,0x00},
- /*-- 文字5: 字 --*/
- {0x10,0x0C,0x04,0x24,0x24,0x24,0x25,0x26,0xA4,0x64,0x24,0x04,0x04,0x14,0x0C,0x00},
- {0x02,0x02,0x02,0x02,0x02,0x42,0x82,0x7F,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x00},
- #endif
以上压缩包下载:
51单片机 IIC通信 0.96oled显示屏.7z
(293.94 KB, 下载次数: 509)
