查看: 5400|回复: 6
关于单片机+lcd1602在proteus仿真中亮了但无显示问题
根据原理图在proteus中仿真,但是代码在实物上可以跑,仿真就没有显示了
原理图和proteus图
单片机代码如下,纯小白,希望帮帮
#include <reg52.h>
#define LCD1602_DB P2//lcd相关端口
#define state_wait 0 //系统等待按键信号状态
#define state_temp_choose 1//等待光电传感器信号,选择温度状态
/***lcd相关端口***/
sbit LCD1602_RS = P0^7;
sbit LCD1602_RW = P0^6;
sbit LCD1602_E = P0^5;
sbit key_start = P3^5;//启动按键
sbit temp_up = P2^4;//继电器开关
sbit temp_set = P3^4;//光电传感器读取
void InitLcd1602();//lcd初始化
void LcdShowStr(unsigned char x, unsigned char y, unsigned char *str);//lcd显示函数
int        readtemp();//读取温度传感器值,实际温度*10
int now_time = 0;
int state = state_wait;//系统状态
int set_temp = 0;//设定温度
char my_char[11] = "temp = 00.0";
char my_time[10] = "time = 000";
int show_flag = 0;//防止lcd刷新过于频繁,1秒刷新一次
        LcdShowStr(1, 0, "System ready");//lcd显示系统准备完成
        /***定时器相关配置,定时50ms,方便计算***/
        TMOD = 0x01;//启动定时器0
        TH0 = (65535-45872)/256;
        TL0 = (65535-45872)%256;
        EA = 1;
        ET0 = 1;
        while(state == state_wait)//检测启动按键
                if(key_start == 0)
                        state = state_temp_choose;
                        TR0 = 1;//启动定时器
        LcdShowStr(1, 0, "             ");//lcd显示系统启动
        while(state == state_temp_choose)//检测光电传感器数据
                if(temp_set == 0)
                        set_temp = readtemp();
                        TR0 = 0;//停止计时
        my_char[7] = (int)(set_temp%1000/100) + '0';//提取温度十位并转换
        my_char[8] = (int)(set_temp%100/10) + '0';//提取温度个位并转换
        my_char[10] = (int)(set_temp%10) + '0';//显示小数点后一位
        LcdShowStr(1, 1, my_char);//lcd显示系统确定温度成功
        while(1);
void T0_time() interrupt 1 //50ms中断,每1秒(20次进入)刷新时间与温度显示
        show_flag ++;
        if(show_flag >= 20)
                show_flag = 0;
                now_time++;
                my_time[7] = (int)(now_time/100) + '0';//提取时间百位并转换
                my_time[8] = (int)(now_time%100/10) + '0';//提取时间十位并转换
                my_time[9] = (int)(now_time%10) + '0';//提取时间个位并转换
                LcdShowStr(1, 0, my_time);//lcd显示时间
                my_char[7] = (int)(set_temp/100) + '0';//提取温度十位并转换
                LcdShowStr(1, 1, my_char);//lcd显示温度
int readtemp()
        return 345;
void LcdWaitReady()//lcd等待
        unsigned char sta;
        LCD1602_DB = 0xFF;
        LCD1602_RS = 0;
        LCD1602_RW = 1;
        do{
                LCD1602_E = 1;
                sta = LCD1602_DB;
                LCD1602_E = 0;
        } while (sta & 0x80);
void LcdWriteCmd(unsigned char cmd)//lcd写指令
        LcdWaitReady();
        LCD1602_RS = 0;
        LCD1602_RW = 0;
        LCD1602_DB = cmd;
        LCD1602_E = 1;
        LCD1602_E = 0;
void LcdWriteDat(unsigned char dat)//lcd写数据
        LcdWaitReady();
        LCD1602_RS = 1;
        LCD1602_RW = 0;
        LCD1602_DB = dat;
        LCD1602_E = 1;
        LCD1602_E = 0;
void LcdSetCursor(unsigned char x, unsigned char y)//设定坐标
        unsigned char addr;
        if (y == 0)
        addr = 0x00 + x;
        addr = 0x40 + x;
        LcdWriteCmd(addr | 0x80);
void LcdShowStr(unsigned char x, unsigned char y, unsigned char *str)//字符串显示代码
        LcdSetCursor(x, y);
        while (*str != '\0')
                LcdWriteDat(*str++);
void InitLcd1602()//lcd初始化
        LcdWriteCmd(0x38);
        LcdWriteCmd(0x0C);
        LcdWriteCmd(0x06);
        LcdWriteCmd(0x01);
原理图
原理图
proteus
proteus
ID:1026277 发表于 2022-5-13 19:30 | 只看该作者
仿真图是这样的
ID:96682 发表于 2022-5-14 07:08 | 只看该作者
只因 RP1 引脚①没接  Vcc 相当于没接上拉电阻,以AT 89C 的特点,LCD 是不会显示任何信息的
ID:390416 发表于 2022-5-14 08:08 | 只看该作者
LCD1602液晶最新资料 说明了具体的时间要求 http://www.51hei.com/bbs/dpj-205768-1.html
ID:824490 发表于 2022-5-14 09:01 | 只看该作者
P0口的上拉剩接了个寂寞!
ID:149451 发表于 2022-5-14 18:29 | 只看该作者
P2是数据、命令口,proteus仿真图错了!
ID:161164 发表于 2022-5-16 11:31 | 只看该作者
部分版本的Proteus LCD1602不会传回查忙
程序会在LcdWaitReady()中死循环
