查看: 1598|回复: 9
单片机6个IO口扫描数码管驱动,我单灯可以点亮,0-9跳转不成麻烦大神指教思路
各位大神,用IO口驱动数码管,单灯给值扫描正常,0~9数字跳转实现不了,是哪里逻辑错误了。。
  1. void LED_Init(void)
  2. {
  3.    PORTA = 0;
  4.    TRISA0 = 1;
  5.    TRISA1 = 1;
  6.    TRISA2 = 1;
  7.    TRISA3 = 1;
  8.    TRISA4 = 1;
  9.    TRISA5 = 1;
  10. }
  11. #define LED_NOP()       NOP();NOP();NOP();NOP();NOP()//;NOP();NOP();NOP();NOP();NOP();NOP();NOP()
  12. void LED_SHOW(void)//矩阵扫描
  13. {
  14.    LED_Init();
  15.    switch (LED_Num)
  16.    {
  17.       case 0x00:
  18.                   TRISA0 = 0;PA0 = 0;                 //PIN1=L
  19.                   if(K1_ON)   {TRISA3 = 0;PA3 = 1;LED_NOP();PA3 = 0;TRISA3 = 1;}   //1L 4H
  20.                   if(K2_ON)   {TRISA2 = 0;PA2 = 1;LED_NOP();PA2 = 0;TRISA2 = 1;}   //1L 3H
  21.                   if(G3_ON)   {TRISA4 = 0;PA4 = 1;LED_NOP();PA4 = 0;TRISA4 = 1;}   //1L 5H
  22.                   if(A3_ON)   {TRISA5 = 0;PA5 = 1;LED_NOP();PA5 = 0;TRISA5 = 1;}   //1L 6H
  23.                   LED_Num = 0x01;
  24.                   break;
  25.       case 0x01:
  26.                   TRISA1 = 0;PA1 = 0;
  27.                   if(B1_ON)   {TRISA3 = 0;PA3 = 1;LED_NOP();PA3 = 0;TRISA3 = 1;}
  28.                   if(A1_ON)   {TRISA2 = 0;PA2 = 1;LED_NOP();PA2 = 0;TRISA2 = 1;}
  29.                   if(E1_ON)   {TRISA4 = 0;PA4 = 1;LED_NOP();PA4 = 0;TRISA4 = 1;}
  30.                   if(D1_ON)   {TRISA5 = 0;PA5 = 1;LED_NOP();PA5 = 0;TRISA5 = 1;}
  31.                   if(P1_ON)   {TRISA0 = 0;PA0 = 1;LED_NOP();PA0 = 0;TRISA0 = 1;}
  32.                   LED_Num = 0x02;
  33.                   break;
  34.       case 0x02:
  35.                   TRISA2 = 0;PA2 = 0;
  36.                   if(D2_ON)   {TRISA3 = 0;PA3 = 1;LED_NOP();PA3 = 0;TRISA3 = 1;}
  37.                   if(B2_ON)   {TRISA4 = 0;PA4 = 1;LED_NOP();PA4 = 0;TRISA4 = 1;}
  38.                   if(B2_ON)   {TRISA5 = 0;PA5 = 1;LED_NOP();PA5 = 0;TRISA5 = 1;}
  39.                   if(P2_ON)   {TRISA0 = 0;PA0 = 1;LED_NOP();PA0 = 0;TRISA0 = 1;}
  40.                   if(F1_ON)   {TRISA1 = 0;PA1 = 1;LED_NOP();PA1 = 0;TRISA1 = 1;}
  41.                   LED_Num = 0x03;
  42.                   break;
  43.       case 0x03:
  44.                   TRISA3= 0;PA3 = 0;
  45.                   if(F2_ON)   {TRISA2 = 0;PA2 = 1;LED_NOP();PA2 = 0;TRISA2 = 1;}
  46.                   if(C2_ON)   {TRISA4 = 0;PA4 = 1;LED_NOP();PA4 = 0;TRISA4 = 1;}
  47.                   if(E3_ON)   {TRISA5 = 0;PA5 = 1;LED_NOP();PA5 = 0;TRISA5 = 1;}
  48.                   if(G1_ON)   {TRISA1 = 0;PA1 = 1;LED_NOP();PA1 = 0;TRISA1 = 1;}
  49.                   LED_Num = 0x04;
  50.                   break;
  51.       case 0x04:
  52.                   TRISA4 = 0;PA4 = 0;
  53.                   if(A2_ON)   {TRISA3 = 0;PA3 = 1;LED_NOP();PA3 = 0;TRISA3 = 1;}
  54.                   if(G2_ON)   {TRISA2 = 0;PA2 = 1;LED_NOP();PA2 = 0;TRISA2 = 1;}
  55.                   if(C3_ON)   {TRISA5 = 0;PA5 = 1;LED_NOP();PA5 = 0;TRISA5 = 1;}
  56.                   if(C1_ON)   {TRISA1 = 0;PA1 = 1;LED_NOP();PA1 = 0;TRISA1 = 1;}
  57.                   LED_Num = 0x05;
  58.                   break;
  59.       case 0x05:
  60.                   TRISA5 = 0;PA5 = 0;
  61.                   if(D3_ON)   {TRISA3=0;PA3 = 1;LED_NOP();PA3 = 0;TRISA3 = 1;}
  62.                   if(E3_ON)   {TRISA2=0;PA2 = 1;LED_NOP();PA2 = 0;TRISA2 = 1;}
  63.                   if(F3_ON)   {TRISA4=0;PA4 = 1;LED_NOP();PA4 = 0;TRISA4 = 1;}
  64.                   LED_Num = 0;
  65.                   break;
  66.         default:LED_Num = 0x00;
  67.       break;
  68.    }
  69. }
  70. void Dis_value (void)
  71. {
  72.    // PORTA = 0;
  73.    // TRISA=0xff;
  74.     if(temp >2 )
  75.     {
  76.         temp = 0;
  77.         Dis_value_B++;
  78.     }
  79.    switch (Dis_value_B)//百位
  80.    {
  81.       case 0x00 :A1_ON = 1;B1_ON = 1;C1_ON = 1; D1_ON= 1;E1_ON = 1;F1_ON = 1;          break;
  82.       case 0x01 :B1_ON = 1;C1_ON = 1;                                                  break;
  83.       case 0x02 :A1_ON = 1;B1_ON = 1;D1_ON = 1;E1_ON= 1;G1_ON = 1;                     break;
  84.       case 0x03 :A1_ON = 1;B1_ON = 1;C1_ON = 1;D1_ON= 1;G1_ON = 1;                     break;
  85.       case 0x04 :B1_ON = 1;C1_ON = 1;F1_ON = 1;G1_ON = 1;                              break;
  86.       case 0x05 :A1_ON = 1;C1_ON = 1;D1_ON = 1;F1_ON= 1;G1_ON = 1;                     break;
  87.       case 0x06 :A1_ON = 1;C1_ON = 1;D1_ON = 1;E1_ON= 1;F1_ON = 1;G1_ON = 1;           break;
  88.       case 0x07 :A1_ON = 1;B1_ON = 1;C1_ON = 1;                                        break;
  89.       case 0x08 :A1_ON = 1;B1_ON = 1;C1_ON = 1;D1_ON = 1;E1_ON= 1;F1_ON = 1;G1_ON = 1; break;
  90.       case 0x09 :A1_ON = 1;B1_ON = 1;C1_ON = 1;D1_ON = 1;F1_ON= 1;G1_ON = 1;           break;
  91.      default:{}
  92. }
  93.    switch (Dis_value_S)//十位
  94.    {
  95.       case 0x00 :A2_ON = 1;B2_ON = 1;C2_ON = 1; D2_ON= 1;E2_ON = 1;F2_ON = 1;           break;
  96.       case 0x01 :B2_ON = 1;C2_ON = 1;                                                   break;
  97.       case 0x02 :A2_ON = 1;B2_ON = 1;D2_ON = 1;E2_ON= 1;G2_ON = 1;                      break;
  98.       case 0x03 :A2_ON = 1;B2_ON = 1;C2_ON = 1;D2_ON= 1;G2_ON = 1;                      break;
  99.       case 0x04 :B2_ON = 1;C2_ON = 1;F2_ON = 1;G2_ON = 1;                               break;
  100.       case 0x05 :A2_ON = 1;C2_ON = 1;D2_ON = 1;F2_ON= 1;G2_ON = 1;                      break;
  101.       case 0x06 :A2_ON = 1;C2_ON = 1;D2_ON = 1;E2_ON= 1;F2_ON = 1;G2_ON = 1;            break;
  102.       case 0x07 :A2_ON = 1;B2_ON = 1;C2_ON = 1;                                         break;
  103.       case 0x08 :A2_ON = 1;B2_ON = 1;C2_ON = 1;D2_ON = 1;E2_ON= 1;F2_ON = 1;G2_ON = 1;  break;
  104.       case 0x09 :A2_ON = 1;B2_ON = 1;C2_ON = 1;D2_ON = 1;F2_ON= 1;G2_ON = 1;            break;
  105.      default:{}
  106.      break;
  107.    }
  108.    switch (Dis_value_G)//个位
  109.    {
  110.       case 0x00 :A3_ON = 1;B3_ON = 1;C3_ON = 1; D3_ON= 1;E3_ON = 1;F3_ON = 1;           break;
  111.       case 0x01 :B3_ON = 1;C3_ON = 1;                                                   break;
  112.       case 0x02 :A3_ON = 1;B3_ON = 1;D3_ON = 1;E3_ON= 1;G3_ON = 1;                      break;
  113.       case 0x03 :A3_ON = 1;B3_ON = 1;C3_ON = 1;D3_ON= 1;G3_ON = 1;                      break;
  114.       case 0x04 :B3_ON = 1;C3_ON = 1;F3_ON = 1;G3_ON = 1;                               break;
  115.       case 0x05 :A3_ON = 1;C3_ON = 1;D3_ON = 1;F3_ON= 1;G3_ON = 1;                      break;
  116.       case 0x06 :A3_ON = 1;C3_ON = 1;D3_ON = 1;E3_ON= 1;F3_ON = 1;G3_ON = 1;            break;
  117.       case 0x07 :A3_ON = 1;B3_ON = 1;C3_ON = 1;                                         break;
  118.       case 0x08 :A3_ON = 1;B3_ON = 1;C3_ON = 1;D3_ON = 1;E3_ON= 1;F3_ON = 1;G3_ON = 1;  break;
  119.       case 0x09 :A3_ON = 1;B3_ON = 1;C3_ON = 1;D3_ON = 1;F3_ON= 1;G3_ON = 1;            break;
  120.      default:{}
  121.     // break;
  122.    }
  123.    P2_ON = 1;//显示小数点
  124. //    if((Sys_Status == Mode_Vin)||(Sys_Status == Mode_Va)||(Sys_Status == Mode_Vc))
  125. //    {
  126.       K1_ON = 1;
  127. //    }
  128. //    else if((Sys_Status == MODE_Wa)||(Sys_Status == MODE_Wc))
  129. //    {
  130. //       K2_ON = 1;
  131. //    }
  132.     PORTA = 0;
  133.     TRISA = 0xFF;
  134. }
ID:213173 发表于 2022-12-1 09:19 | 只看该作者
这类数码管的驱动码编写有点麻烦,首先要选择有高阻输出模式的MCU,采用查理复用的方法编写驱动码,共有25个笔段。小数点DP1、DP2只需2选1就能满足运用。空出的码位让给k2。这就得到24个实际使用笔段。最简单的应用是单管逐一显示,由于每个笔段只能显示1/25时间,可能视觉亮度不够。要减小限流电阻阻值。 查理复用IO驱动数码管.docx (92.31 KB, 下载次数: 15)
ID:344646 发表于 2022-12-1 09:49 | 只看该作者
wulin 发表于 2022-12-1 09:19
这类数码管的驱动码编写有点麻烦,首先要选择有高阻输出模式的MCU,采用查理复用的方法编写驱动码,共有25 ...
感谢指点,我目前是按查理复用设定的扫描方式去处理的,就是亮下一个灯的时候,上一个不论怎么配置不知道为什么灭不掉。
ID:161164 发表于 2022-12-1 09:49 | 只看该作者
代码不全
可以用Excel 算出段值用来比较,就可以简化代码
以下的Disp()函数放到1ms中断里运行
Dat1/Dat2/Dat3的值是共阴数码管的码,k1k2对应bit0,bit1
ID:712493 发表于 2022-12-1 10:17 | 只看该作者
declansang 发表于 2022-12-1 09:49
感谢指点,我目前是按查理复用设定的扫描方式去处理的,就是亮下一个灯的时候,上一个不论怎么配置不知道 ...
这个复用模式,需要单片机的高阻模式不漏电,因为现在LED很小的驱动电流就会发亮1mA以下都可以,你要单独试个点,一IO高电平一次  低电平一次 另一IO一直高阻开漏模式  测试所处的点是否发亮,如发亮你怎么弄也不能有效关闭LED了
ID:18297 发表于 2022-12-1 11:39 | 只看该作者
这个灯需要一个定时器对他IO口进行定时循环扫描,在数据的处理上要化点时间。
处理过2个这样的LED程序。
ID:213173 发表于 2022-12-1 12:28 | 只看该作者
查理复用是需要软件、硬件配合。不能有效关闭LED多数是代码不对。
ID:123289 发表于 2022-12-1 17:22 | 只看该作者
不急:
弄懂显示的原理。
建议先画个显示0-9的真值表。按表写驱动程序就可以了。
ID:344646 发表于 2022-12-1 19:57 | 只看该作者
处理过2个这样的LED程序。
好的,是这样的思路,谢谢~
ID:344646 发表于 2022-12-1 19:58 | 只看该作者
yzwzfyz 发表于 2022-12-1 17:22
不急:
弄懂显示的原理。
好的,按照上面两位的思路整理了下程序,基本可以了
