基于单片机的火灾报警器,进行烟雾和温度检测。
单片机程序如下:
- #include <reg52.h>
- #include "intrins.h"
- #define u8 unsigned char
- #define u16 unsigned int
- #define uchar unsigned char
- #define uint unsigned int
- uchar yushe_wendu=50;
- uchar yushe_yanwu=100;
- uint wendu;
- uchar yanwu;
- uchar Mode=0;
- sbit Led_Reg =P2^2;
- sbit Led_Yellow =P2^4;
- sbit Buzzer =P2^0;
- sbit Fan =P3^3;
- * ?? : delay_1ms()
- * ?? : ??1ms??
- * ?? : q
- void delay_ms(uint q)
- uint i,j;
- for(i=0;i<q;i++)
- for(j=0;j<110;j++);
- LCD1602????
- //LCD??
- sbit LCDRS = P2^7;
- sbit LCDEN = P2^6;
- sbit D0 = P0^0;
- sbit D1 = P0^1;
- sbit D2 = P0^2;
- sbit D3 = P0^3;
- sbit D4 = P0^4;
- sbit D5 = P0^5;
- sbit D6 = P0^6;
- sbit D7 = P0^7;
- //LCD
- void LCDdelay(uint z)
- uint x,y;
- for(x=z;x>0;x--)
- for(y=10;y>0;y--);
- void LCD_WriteData(u8 dat)
- if(dat&0x01)D0=1;else D0=0;
- if(dat&0x02)D1=1;else D1=0;
- if(dat&0x04)D2=1;else D2=0;
- if(dat&0x08)D3=1;else D3=0;
- if(dat&0x10)D4=1;else D4=0;
- if(dat&0x20)D5=1;else D5=0;
- if(dat&0x40)D6=1;else D6=0;
- if(dat&0x80)D7=1;else D7=0;
- void write_com(uchar com)
- LCDRS=0;
- LCD_WriteData(com);
- // DAT=co
- LCDdelay(5);
- LCDEN=1;
- LCDdelay(5);
- LCDEN=0;
- void write_data(uchar date)
- LCDRS=1;
- LCD_WriteData(date);
- // DAT=dat
- LCDdelay(5);
- LCDEN=1;
- LCDdelay(5);
- LCDEN=0;
- void SelectPosition(unsigned char x,unsigned char y)
- if (x == 0)
- write_com(0x80 + y);
- else
- write_com(0xC0 + y);
- void LCD_Write_String(unsigned char x,unsigned char y,unsigned char *s)
- SelectPosition(x,y) ;
- while (*s)
- write_data( *s);
- s ++;
- // ??: void LCD_Write_Char(u8 x,u8 y,u16 s,u8
- // ??: LCD_Write_Char(0,1,366,4)
- // ??: ??0??????????366??4?,????? 03
- // ??: x:?,y:?,s:?????,l:???
- // ??: non
- // ??: VER1
- // ??: 2013-4
- // ??: ????655
- void LCD_Write_Char(u8 x,u8 y,u16 s,u8 l)
- if(l>=5)
- write_data(0x30+s/10000%10);
- if(l>=4)
- write_data(0x30+s/1000%10);
- if(l>=3)
- write_data(0x30+s/100%10);
- if(l>=2)
- write_data(0x30+s/10%10);
- if(l>=1)
- write_data(0x30+s%10);
- /*1602????
- write_com(0x38);
- write_com(0x0c);
- write_com(0x0d);
- write_com(0x0d);
- //1602?
- void Init1602()
- uchar i=0;
- write_com(0x38);
- write_com(0x0c);
- write_com(0x06);
- write_com(0x01);
- void Display_1602(yushe_wendu,yushe_yanwu,c,temp)
- LCD_Write_Char(0,6,yushe_wendu,2) ;
- LCD_Write_Char(0,13,yushe_yanwu,3) ;
- LCD_Write_Char(1,6,c/10,2) ;
- write_data('.');
- LCD_Write_Char(1,9,c%10,1) ;
- LCD_Write_Char(1,13,temp,3) ;
- ADC0832????
- sbit ADCS =P1^5;
- sbit ADCLK =P1^2;
- sbit ADDI =P1^3; //ADC0832 ???? /*????????????,?ADC0832????????????,
- sbit ADDO =P1^3; //ADC0832 ???? /*????????,???????????????????
- // ??: unsigned int Adc0832(unsigned char channel)
- // ??: temp=Adc0832(0);
- // ??: ??0???AD?
- // ??: channel:??0???1??
- // ??: ?????AD?
- // ??: VER1.0
- // ??: 2015-05-29
- unsigned int Adc0832(unsigned char channel)
- uchar i=0;
- uchar j;
- uint dat=0;
- uchar ndat=0;
- uchar Vot=0;
- if(channel==0)channel=2;
- if(channel==1)channel=3;
- ADDI=1;
- _nop_();
- _nop_();
- ADCS=0;//??CS?
- _nop_();
- _nop_();
- ADCLK=1;//??CLK?
- _nop_();
- _nop_();
- ADCLK=0;//??CLK?,?????1
- _nop_();
- _nop_();
- ADCLK=1;//??CLK?
- ADDI=channel&0x1;
- _nop_();
- _nop_();
- ADCLK=0;//??CLK?,?????2
- _nop_();
- _nop_();
- ADCLK=1;//??CLK?
- ADDI=(channel>>1)&0x1;
- _nop_();
- _nop_();
- ADCLK=0;//??CLK?,?????3
- ADDI=1;//??????
- _nop_();
- _nop_();
- dat=0;
- for(i=0;i<8;i++)
- dat|=ADDO;//???
- ADCLK=1;
- _nop_();
- _nop_();
- ADCLK=0;//????????
- _nop_();
- _nop_();
- dat<<=1;
- if(i==7)dat|=ADDO;
- for(i=0;i<8;i++)
- j=0;
- j=j|ADDO;//???
- ADCLK=1;
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- j=j<<7;
- ndat=ndat|j;
- if(i<7)ndat>>=1;
- ADCS=1;//??CS?
- ADCLK=0;//??CLK?
- ADDO=1;//?????,??????
- dat<<=8;
- dat|=ndat;
- return(dat); //return ad data
- DS18B20????
- sbit DQ = P1^0;
- /*****?????:???????ds18b20??*****/
- void Delay_DS18B20(int num)
- while(num--) ;
- /*****???DS18B20*****/
- void Init_DS18B20(void)
- unsigned char x=0;
- DQ = 1;
- Delay_DS18B20(8);
- DQ = 0;
- Delay_DS18B20(80);
- DQ = 1;
- Delay_DS18B20(14);
- x = DQ;
- Delay_DS18B20(20);
- unsigned char ReadOneChar(void)
- unsigned char i=0;
- unsigned char dat = 0;
- for (i=8;i>0;i--)
- DQ = 0;
- dat>>=1;
- DQ = 1;
- if(DQ)
- dat|=0x80;
- Delay_DS18B20(4);
- return(dat);
- void WriteOneChar(unsigned char dat)
- for (i=8; i>0; i--)
- DQ = 0;
- DQ = dat&0x01;
- Delay_DS18B20(5);
- DQ = 1;
- dat>>=1;
- unsigned int ReadTemperature(void)
- unsigned char a=0;
- unsigned char b=0;
- unsigned int t=0;
- float tt=0;
- Init_DS18B20();
- WriteOneChar(0xCC);
- WriteOneChar(0x44);
- Init_DS18B20();
- WriteOneChar(0xBE);
- a=ReadOneChar();
- b=ReadOneChar();
- t=b;
- t<<=8;
- t=t|a;
- tt=t*0.0625;
- t= tt*10+0.5;
- return(t);
- u16 check_wendu(void)
- u16 c;
- c=ReadTemperature()-5;
- if(c<1) c=0;
- if(c>=999) c=999;
- return c;
- sbit Key1=P1^6;
- sbit Key2=P1^7;
- sbit Key3=P3^2;
- #define KEY_SET 1
- #define KEY_ADD 2
- #define KEY_MINUS 3
- // ??: u8 Key_Scan
- // ??: temp=u8 Key_Scan(
- // ??: NO
- // ??: VER1
- // ??: 2015-05-
- // ??: ????????,????????????0,???????
- u8 Key_Scan()
- static u8 key_up=1;
- if(key_up&&(Key1==0||Key2==0||Key3==0))
- delay_ms(10);
- key_up=0;
- if(Key1==0) return 1;
- else if(Key2==0)return 2;
- else if(Key3==0)return 3;
- else if(Key1==1&&Key2==1&&Key3==1)
- key_up=1;
- return 0;
- void main (void)
- u8 key;
- wendu=check_wendu();
- Init1602();
- LCD_Write_String(0,0,"SET T:00 E:000");
- LCD_Write_String(1,0,"NOW T:00.0 E:000");
- delay_ms(1000);
- while (1)
- key=Key_Scan();
- yanwu=Adc0832(0);
- if(key==KEY_SET)
- Mode++;
- switch(Mode)
- case 0:
- Display_1602(yushe_wendu,yushe_yanwu,wendu,yanwu);
- if(yanwu>=yushe_yanwu)
- Led_Reg=0;
- Fan=0;
- Buzzer=0;
- else
- Led_Reg=1;
- Fan=1;
- if(wendu>=(yushe_wendu*10))
- Buzzer=0;
- Led_Yellow=0;
- else
- Led_Yellow=1;
- if((yanwu<yushe_yanwu)&&(wendu<(yushe_wendu*10)))
- Buzzer=1;
- break;
- case 1:
- SelectPosition(0,5) ;
- write_com(0x0d);
- if(key==KEY_ADD)
- yushe_wendu++;
- if(yushe_wendu>=99)
- yushe_wendu=99;
- if(key==KEY_MINUS)
- if(yushe_wendu<=1)
- yushe_wendu=1;
- yushe_wendu--;
- break;
- case 2:
- SelectPosition(0,12) ;
- write_com(0x0d);
- if(key==KEY_ADD)
- if(yushe_yanwu>=255)
- yushe_yanwu=254;
- yushe_yanwu++;
- if(yushe_yanwu<=1)
- yushe_yanwu=1;
- yushe_yanwu--;
- break;
- default :
- write_com(0x38);
- write_com(0x0c);
- Mode=0;
- break;
