查看: 932|回复: 3
stm32关于ADC数模转换查询方式Proteus仿真的问题
不知道代码有什么问题,一开始仿真什么都不显示,但是将主函数中 ‘ADC_ResetCalibration(ADC1);’注释后,就开始显示一串0,后来就觉得是不是上拉电阻的问题,就加上了上拉电阻,然后就不是直接显示的一串0,而是闪烁着显示。也检测不到滑动变阻器的改变。求助大佬,不知道是哪的问题。
代码如下:
  1. #include "stm32f10x.h"
  2. void GPIO_Config(void);
  3. void ADC_Config(void);
  4. void Delay(void);
  5. void seven(uint16_t value);
  6. void Display(unsigned char * digit);
  7. unsigned char discode[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8, 0x80,0x90};
  8. unsigned char digit[4] = {0XC0,0XC0,0XC0,0XC0};
  9. int main(void)
  10. {
  11.                 uint16_t ad_v=0;  //存放转换值
  12.                 GPIO_Config();
  13.                 ADC_Config();
  14.           GPIO_ResetBits(GPIOA, GPIO_Pin_0 | GPIO_Pin_1 |GPIO_Pin_2 |GPIO_Pin_3);
  15.           GPIO_Write(GPIOB, 0xc0);
  16.                 ADC_Cmd(ADC1, ENABLE);
  17.
  18. //                ADC_ResetCalibration(ADC1);  //重置ADC1校准寄存器
  19.                 while(ADC_GetResetCalibrationStatus(ADC1));  //等待重置完成
  20.                 ADC_StartCalibration(ADC1);  //开始校准ADC1
  21.                 while(ADC_GetCalibrationStatus(ADC1));  //等待校准完成
  22.                 ADC_SoftwareStartConvCmd(ADC1, ENABLE);//开始软件触发转换
  23.                 while(1)
  24.                         {
  25.                                 Display(digit);
  26.                                 if(ADC_GetFlagStatus(ADC1, ADC_FLAG_EOC == SET))
  27.                                 {
  28.                                          ad_v = ADC_GetConversionValue(ADC1); //获取转换数值
  29.                                          ad_v&=0x0fff; //保留右对齐的12位}
  30.                                         seven(ad_v);
  31.                                 }
  32.                         }
  33.         }
  34. void GPIO_Config(void)
  35. {
  36.         //结构体
  37.         GPIO_InitTypeDef   GPIO_InitStructure;
  38.
  39.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC | RCC_APB2Periph_GPIOB | RCC_APB2Periph_GPIOA, ENABLE);
  40.
  41.         //七段数码管
  42.         GPIO_InitStructure.GPIO_Pin = (GPIO_Pin_0 | GPIO_Pin_1 |GPIO_Pin_2 |GPIO_Pin_3 |GPIO_Pin_4 |GPIO_Pin_5 |GPIO_Pin_6 |GPIO_Pin_7);
  43.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  44.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  45.         GPIO_Init(GPIOB, &GPIO_InitStructure);
  46.
  47.         GPIO_InitStructure.GPIO_Pin = (GPIO_Pin_0 | GPIO_Pin_1 |GPIO_Pin_2 |GPIO_Pin_3);
  48.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  49.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  50.         GPIO_Init(GPIOA, &GPIO_InitStructure);
  51.
  52.         //外部滑动变阻器
  53.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3;
  54.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
  55.         GPIO_Init(GPIOC, &GPIO_InitStructure);
  56.
  57. }
  58. void ADC_Config(void)
  59. {
  60.                 ADC_InitTypeDef ADC_InitStructure;
  61.                 RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE);
  62.                 ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;
  63.                 ADC_InitStructure.ADC_ScanConvMode = DISABLE;
  64.                 ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
  65.                 ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;
  66.                 ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
  67.                 ADC_InitStructure.ADC_NbrOfChannel = 1;
  68.                 ADC_Init(ADC1, &ADC_InitStructure);
  69.                 ADC_RegularChannelConfig(ADC1, ADC_Channel_13,1, ADC_SampleTime_55Cycles5);
  70. }
  71. void seven(uint16_t value){
  72.
  73.                          digit[0] = value % 10;  //个
  74.                 digit[1] = (value % 100) /10; //十
  75.                 digit[2] = (value % 1000)/100;  //百
  76.                 digit[3] = value / 1000 ;  //千
仿真如下:
ID:94031 发表于 2023-6-2 13:42 | 只看该作者
protus版本问题,参看http://www.51hei.com/bbs/dpj-158502-1.html
ID:1076644 发表于 2023-6-8 10:34 | 只看该作者
我换了8.8版本,发现还是不行,就刚打开那一瞬间亮了一下,然后也不闪烁了
ID:493026 发表于 2023-7-26 23:45 | 只看该作者
确实存在版本问题。我的AD程序在8.9上能运行,在8.13上跑不起来。
