如图所示,本人使用的江协科技的51单片机,烧录成功后单片机没有按照程序运行。蜂鸣器持续响起,LED全亮。
本人排查了好久都没有找到问题,望各位专家解答。
部分代码如下:
main.c:
- #include <REGX52.H>
- #include "Delay.h"
- #include "ADC0832.h"
- #include<stdio.h>
- #include "uart.h"
- #define uchar unsigned char
- #define uint unsigned int
- #define false 0
- #define true 1
- unsigned int AD_X;
- unsigned int AD_Y;
- //Unicode
- char Unicode_latitude[10*latitude_Length]='0';
- char Unicode_N_S[10*N_S_Length];
- char Unicode_longitude[10*longitude_Length];
- char Unicode_E_W[10*E_W_Length];
- void errorLog(int num)//解析错误
- while (1)
- Uart1Sends("ERROR");
- Uart1Send(num+0x30);
- Uart1Sends("\r\n");
- void parseGpsBuffer()//获得GPS数据
- char *subString;
- char *subStringNext;
- char i = 0;
- if (Save_Data.isGetData)
- Save_Data.isGetData = false;
- //Uart1Sends("**************\r\n");
- //Uart1Sends(Save_Data.GPS_Buffer);
- for (i = 0 ; i <= 6 ; i++)
- if (i == 0)
- if ((subString = strstr(Save_Data.GPS_Buffer, ",")) == NULL)
- errorLog(1); //解析错误
- else
- subString++;
- if ((subStringNext = strstr(subString, ",")) != NULL)
- char usefullBuffer[2];
- switch(i)
- case 1:memcpy(Save_Data.UTCTime, subString, subStringNext - subString);break; //获取UTC时间
- case 2:memcpy(usefullBuffer, subString, subStringNext - subString);break; //获取UTC时间
- case 3:memcpy(Save_Data.latitude, subString, subStringNext - subString);break; //获取纬度信息
- case 4:memcpy(Save_Data.N_S, subString, subStringNext - subString);break; //获取N/S
- case 5:memcpy(Save_Data.longitude, subString, subStringNext - subString);break; //获取经度信息
- case 6:memcpy(Save_Data.E_W, subString, subStringNext - subString);break; //获取E/W
- default:break;
- subString = subStringNext;
- Save_Data.isParseData = true;
- if(usefullBuffer[0] == 'A')
- Save_Data.isUsefull = true;
- else if(usefullBuffer[0] == 'V')
- Save_Data.isUsefull = false;
- else
- errorLog(2); //解析错误
- void printGpsBuffer()//输出GPS数据
- if (Save_Data.isParseData)
- Save_Data.isParseData = false;
- Uart1Sends("Save_Data.UTCTime = ");
- Uart1Sends(Save_Data.UTCTime);
- if(Save_Data.isUsefull)
- Uart1Sends("Save_Data.latitude = ");
- Uart1Sends(Save_Data.latitude);
- Uart1Sends("Save_Data.N_S = ");
- Uart1Sends(Save_Data.N_S);
- Uart1Sends("Save_Data.longitude = ");
- Uart1Sends(Save_Data.longitude);
- Uart1Sends("Save_Data.E_W = ");
- Uart1Sends(Save_Data.E_W);
- else
- Uart1Sends("GPS DATA is not usefull!\r\n");
- //ASCLL-Unicode
- void ASCII_TO_Unicode(char *ASCII,char *Unicode)
- int length;
- int i = 0;
- int j = 0;
- memset(Unicode,'\0',sizeof(Unicode));
- length = strlen(ASCII);
- for(i=0;i<length;i++)
- Unicode[j++] = '0';
- Unicode[j++] = (ASCII[i] / 16) + 0x30;
- Unicode[j++] = (ASCII[i] % 16) + 0x30;
- void main()
- Uart_Init();
- Delay(10000);
- //clrStruct();
- while(1)
- AD_X=ADC0832(1);
- AD_Y=ADC0832(0);
- parseGpsBuffer();
- //ASCII_TO_Unicode(Save_Data.E_W,Unicode_E_W);
- //printGpsBuffer();
- if((AD_X<=47 || AD_X>=126) || (AD_Y>=141 || AD_Y<=57))
- //----------------为什么是下面这些AT指令呢,请看群共享文件SIM900A重要的信息指令文件------------
- ASCII_TO_Unicode(Save_Data.latitude,Unicode_latitude);
- ASCII_TO_Unicode(Save_Data.longitude,Unicode_longitude);
- Uart1Sends("AT\r\n");
- Delay(2000);//延时大约2秒
- //Uart1Sends("AT+CSCS=\"UCS2\"\r\n");
- //Delay(2000);//延时大约2秒
- Uart1Sends("AT+CMGF=1\r\n");
- Delay(2000);//延时2秒
- Uart1Sends("AT+CSCA?\n");
- Uart1Sends("AT+CSMP=17,167,0,25\r\n");
- //Uart1Sends("AT+CMGS=\"00310039003100360037003500340036003700320034\"\r\n");//此处修改为对方的电话号,电话话的UNICON编码,可使用我们配套的
- //资料包中的 中文转UNICON编码工具来获取。特别注意:那个软件
- //获得的unicon 编码待有空格,实际中要去掉,否则模块会报错
- Uart1Sends("AT+CMGS=\"19167546724\"\r\n");
- Uart1Sends("4F7F7528800553EF80FD64545012FF0C8BF7524D5F8063075B9A573070B9655152A9FF01");//修改信息内容,内容可为中文、英文和数字,但都是对应的unicon 编码。
- Uart1Sends(Unicode_latitude);
- Uart1Sends("004E0053");
- Uart1Sends(Unicode_longitude);
- Uart1Sends("00450057");
- Uart1Sends("使用者可能摔倒,请前往");
- Uart1Sends("进行救助!");
- Uart1Send(0x1a);
- Delay(8000);//延时10秒
- Delay(100);
复制代码 uart.c:
- #include "uart.h"
- //以下是开机后发送到手机的内容,发送的号码在程序中修改。
- unsigned int rec_data_len_uart=0; //标记Buffer_Uart0接收数组
- unsigned char idata Buffer_Uart0_Rec[25]={0}; //Uart0中断接收数组
- //注意,无论接收到信号还是发送完信号,都会进中断服务程序的
- char idata gpsRxBuffer[gpsRxBufferLength];
- unsigned char RX_Count = 0;
- _SaveData Save_Data;
- void Uart_Init()
- SCON = 0X50; //UART方式1;8位UART
- REN = 1; //允许串行口接收数据
- PCON = 0x00; //SMOD=0;波特率不加倍
- TMOD = 0x20; //T1方式2,用于产生波特率
- TH1 = 0xFD; //装初值
- TL1 = 0xFD;
- TR1 = 1; //启动定时器1
- EA = 1; //打开全局中断控制
- ES = 1; //打开串行口中断
- void Uart1Sends(unsigned char *p) //·¢?í×?·?′?
- while(*p)
- SBUF=*(p++);
- while(TI==0)
- TI=0;
- void Uart1Send(unsigned char c) //·¢?íò???×?·?
- TI=0;
- SBUF=c;
- while(TI==0);
- TI=0;
- void Serial_interrupt() interrupt 4
- unsigned char temp_rec_data_uart0;
- temp_rec_data_uart0 = SBUF;//读取接收数据
- RI=0;//接收中断信号清零,表示将继续接收
- Buffer_Uart0_Rec[rec_data_len_uart]=temp_rec_data_uart0; //接收数据
- rec_data_len_uart++;
- if(rec_data_len_uart>24)
- rec_data_len_uart=0; //从头开始接收数据
- /*串行通讯中断,收发完成将进入该中断*/
- void RECEIVE_DATA(void) interrupt 4 using 3
- unsigned char temp = 0;
- char i = 0;
- ES=0;
- temp = SBUF;
- RI = 0;
- if(temp == ')
- RX_Count = 0;
- if(RX_Count <= 5)
- gpsRxBuffer[RX_Count++] = temp;
- if(temp == '\n')
- memset(Save_Data.GPS_Buffer, 0, GPS_Buffer_Length); //=?||
- memcpy(Save_Data.GPS_Buffer, gpsRxBuffer, RX_Count); // mph||
- Save_Data.isGetData = true;
- RX_Count = 0;
- memset(gpsRxBuffer, 0, gpsRxBufferLength); //??Σ
- if(RX_Count >= 75)
- RX_Count = 75;
- gpsRxBuffer[RX_Count] = '\0';//ìí?ó?áê?·?
- ES=1;
- void clrStruct()
- memset(Save_Data.GPS_Buffer, 0, GPS_Buffer_Length); //清空
- memset(Save_Data.UTCTime, 0, UTCTime_Length);
- memset(Save_Data.latitude, 0, latitude_Length);
- memset(Save_Data.N_S, 0, N_S_Length);
- memset(Save_Data.longitude, 0, longitude_Length);
- memset(Save_Data.E_W, 0, E_W_Length);
uart.h:
- 作者:神秘藏宝室
- 最终解释权归原作者所有,鄙视其他店铺不劳而获的抄行为!
- #ifndef __UART_H__
- #define __UART_H__
- #include <stdio.h>
- #include <stdlib.h>
- #include <string.h>
- #define false 0
- #define true 1
- //定义数组长度
- #define GPS_Buffer_Length 80
- #define UTCTime_Length 11
- #define latitude_Length 11
- #define N_S_Length 2
- #define longitude_Length 12
- #define E_W_Length 2
- typedef struct SaveData
- char GPS_Buffer[GPS_Buffer_Length];
- char isGetData; //是否获取到GPS数据
- char isParseData; //是否解析完成
- char UTCTime[UTCTime_Length]; //UTC时间
- char latitude[latitude_Length]; //纬度
- char N_S[N_S_Length]; //N/S
- char longitude[longitude_Length]; //经度
- char E_W[E_W_Length]; //E/W
- char isUsefull; //定位信息是否有效
- } xdata _SaveData;
- //函数或者变量声明
- extern void Uart_Init();
- extern void Uart1Sends(unsigned char *p);
- extern void Uart1Send(unsigned char c);
- extern void clrStruct();
- #define gpsRxBufferLength 76
- extern char idata gpsRxBuffer[gpsRxBufferLength];
- extern unsigned char RX_Count;
- extern _SaveData Save_Data;
- extern unsigned int rec_data_len_uart; //标记Buffer_Uart0接收数组
- extern unsigned char idata Buffer_Uart0_Rec[25];
- #endif
复制代码 |
