查看: 3579|回复: 4
GPS 51单片机源程序 GPS信息获取(LCD1602显示)UTC转换
GPS 51源程序
部分源码预览:
  1. #include "main.h"
  2. #include "LCD1602.h"
  3. #include "GPS.h"
  4. //定义变量
  5. unsigned char KEY_NUM = 0;
  6. bit Page = 0;
  7. unsigned char xdata Display_GPGGA_Buffer[68];
  8. unsigned char xdata Display_GPRMC_Buffer[68];
  9. bit Flag_OV = 0;
  10. bit Flag_Calc_GPGGA_OK = 0;
  11. bit Flag_Calc_GPRMC_OK = 0;
  12. //****************************************************
  13. //主函数
  14. //****************************************************
  15. void main()
  16. {
  17.         unsigned char i = 0;
  18.         Init_LCD1602();
  19.         LCD1602_write_com(0x80);                                                //指针设置
  20.         LCD1602_write_word("Welcome to use!");
  21.         Delay_ms(1000);
  22.         Uart_Init();
  23.         while(1)
  24.         {
  25.                 Scan_Key();
  26.                 if(Flag_GPS_OK == 1 && RX_Buffer[4] == 'G' && RX_Buffer[6] == ',' && RX_Buffer[13] == '.')                        //确定是否收到"GPGGA"这一帧数据
  27.                 {
  28.                         for( i = 0; i < 68 ; i++)
  29.                         {
  30.                                 Display_GPGGA_Buffer[i] = RX_Buffer[i];
  31.                         }
  32.                         Hour = (Display_GPGGA_Buffer[7]-0x30)*10+(Display_GPGGA_Buffer[8]-0x30)+8;                        //UTC时间转换到北京时间                UTC+8
  33.        //0x30为ASCII转换为数字
  34.                         if( Hour >= 24)                                //溢出
  35.                         {
  36.                                 Hour %= 24;                                //获取当前Hour
  37.                                 Flag_OV = 1;                        //日期进位
  38.                         }
  39.                         else
  40.                         {
  41.                                 Flag_OV = 0;
  42.                         }
  43.                         Min_High = Display_GPGGA_Buffer[9];
  44.                         Min_Low = Display_GPGGA_Buffer[10];
  45.
  46.                         Sec_High = Display_GPGGA_Buffer[11];
  47.                         Sec_Low = Display_GPGGA_Buffer[12];
  48.                         Flag_Calc_GPGGA_OK = 1;
  49.                 }
  50.                 if(Page == 0 && Flag_Calc_GPGGA_OK == 1)
  51.                 {
  52.                         LED1 = ~LED1;
  53.                         Flag_Calc_GPGGA_OK = 0;
  54.                         LCD1602_write_com(0x80);                        //设置指针
  55.                         LCD1602_write_data(Hour/10+0x30);
  56.                         LCD1602_write_data(Hour%10+0x30);
  57.                         LCD1602_write_data(':');
  58.                         LCD1602_write_data(Min_High);
  59.                         LCD1602_write_data(Min_Low);
  60.                         LCD1602_write_data(':');
  61.
  62.                         LCD1602_write_data(Sec_High);
  63.                         LCD1602_write_data(Sec_Low);
  64.                         LCD1602_write_word("  ");
  65.
  66.                         LCD1602_write_data(Display_GPGGA_Buffer[54]);
  67.                         LCD1602_write_data(Display_GPGGA_Buffer[55]);
  68.                         LCD1602_write_data(Display_GPGGA_Buffer[56]);
  69.                         LCD1602_write_data(Display_GPGGA_Buffer[57]);
  70.                         LCD1602_write_word("m");
  71.
  72.                         LCD1602_write_com(0x80+0x40);                        //设置指针
  73.
  74.                         LCD1602_write_data(Display_GPGGA_Buffer[28]);                        //N 或者 S
  75.                         LCD1602_write_data(Display_GPGGA_Buffer[17]);                        //纬度
  76.                         LCD1602_write_data(Display_GPGGA_Buffer[18]);                        //纬度
  77.                         LCD1602_write_data(0xdf);        //度
  78.                         LCD1602_write_data(Display_GPGGA_Buffer[19]);                        //纬度
  79.                         LCD1602_write_data(Display_GPGGA_Buffer[20]);                        //纬度
  80.                         LCD1602_write_word("'");        //秒
  81.
  82.                         LCD1602_write_data(Display_GPGGA_Buffer[42]);                        //E 或者 W
  83.                         LCD1602_write_data(Display_GPGGA_Buffer[30]);                        //经度
  84.                         LCD1602_write_data(Display_GPGGA_Buffer[31]);
  85.                         LCD1602_write_data(Display_GPGGA_Buffer[32]);
  86.                         LCD1602_write_data(0xdf);
  87.                         LCD1602_write_data(Display_GPGGA_Buffer[33]);
  88.                         LCD1602_write_data(Display_GPGGA_Buffer[34]);
  89.                         LCD1602_write_word("'");
  90.
  91.                 }
  92.
  93.                 if(Flag_GPS_OK == 1 && RX_Buffer[4] == 'M' && RX_Buffer[52] == ',' && RX_Buffer[59] == ',')                        //确定是否收到"GPRMC"这一帧数据
  94.                 {
  95.                         for( i = 0; i < 68 ; i++)
  96.                         {
  97.                                 Display_GPRMC_Buffer[i] = RX_Buffer[i];
  98.                         }
  99.                         Year_High = Display_GPRMC_Buffer[57];
  100.                         Year_Low = Display_GPRMC_Buffer[58];
  101.                         Month_High = Display_GPRMC_Buffer[55];
  102.                         Month_Low = Display_GPRMC_Buffer[56];
  103.                         Day_High = Display_GPRMC_Buffer[53];
  104.                         Day_Low = Display_GPRMC_Buffer[54];
  105.                         if(Flag_OV == 1)                        //有进位
  106.                         {
  107.                                 UTCDate2LocalDate();                        //UTC日期转换为北京时间
  108.                         }
  109.                         Flag_Calc_GPRMC_OK = 1;
  110.                 }
  111.                 if(Page == 1 && Flag_Calc_GPRMC_OK == 1)
  112.                 {
  113.                         LED1 = ~LED1;
  114.                         Flag_Calc_GPRMC_OK = 0;
  115.                         LCD1602_write_com(0x80);                        //设置指针
  116.                         LCD1602_write_word("20");
  117.                         LCD1602_write_data(Year_High);
  118.                         LCD1602_write_data(Year_Low);
  119.                         LCD1602_write_data('-');
  120.
  121.                         LCD1602_write_data(Month_High);
  122.                         LCD1602_write_data(Month_Low);
  123.                         LCD1602_write_data('-');
  124.
  125.                         LCD1602_write_data(Day_High);
  126.                         LCD1602_write_data(Day_Low);
  127.
  128.
  129.                         LCD1602_write_com(0x80+0x40);                        //设置指针
  130.                         LCD1602_write_word("Speed:");                                //显示内容
  131.                         LCD1602_write_data(Display_GPRMC_Buffer[46]);
  132.                         LCD1602_write_data(Display_GPRMC_Buffer[47]);
  133.                         LCD1602_write_data(Display_GPRMC_Buffer[48]);
  134.                         LCD1602_write_data(Display_GPRMC_Buffer[49]);
  135.                         LCD1602_write_data(Display_GPRMC_Buffer[50]);
  136.
  137.                         LCD1602_write_word("m/s");
  138.                 }
  139.         }
  140. }
  141. //****************************************************
  142. //UTC日期与当地日期转换
  143. //****************************************************
  144. void UTCDate2LocalDate(void)
  145. {
  146.         Day = (Day_High - 0x30) * 10 + (Day_Low-0x30) + 1;                //日  加一
  147.         Month = (Month_High - 0x30) * 10 + (Month_Low - 0x30);
  148.         Year = 2000 + (Year_High - 0x30) * 10 + (Year_Low - 0x30);
  149.
  150.         MaxDay = GetMaxDay(Month,Year);                                //获取当月 天数 最大值
  151.         if(Day > MaxDay)                //溢出
  152.         {
  153.                 Day = 1;
  154.                 Month += 1;
  155.                 if(Month > 12)
  156.                 {
  157.                         Year+=1;
  158.                 }
  159.         }
  160.         Day_High = Day/10 + 0x30;                                //转换日期值为ASCII
  161.         Day_Low = Day%10 + 0x30;
  162.         Month_High = Month/10 + 0x30;                        //转换月份值为ASCII
  163.         Month_Low = Month%10 + 0x30;
  164.         Year_High = Year%100/10 + 0x30;                        //转换年份值为ASCII
  165.         Year_Low = Year%10 + 0x30;
  166. }
  167. //****************************************************
  168. //获取当月日期最大值
  169. //****************************************************
  170. unsigned char GetMaxDay(unsigned char Month_Value,unsigned int Year_Value)
  171. {
  172.         unsigned char iDays;
  173.         switch(Month_Value)
  174.         {
  175.                 case 1:
  176.                 case 3:
  177.                 case 5:
  178.                 case 7:
  179.                 case 8:
  180.                 case 10:
  181.                 case 12:
  182.                         {
  183.                                 iDays = 31;
  184.                         }
  185.                         break;
  186.                 case 2:
  187.                         {
  188.                                 //2月份比较特殊,需要根据是不是闰年来判断当月是28天还29天
  189.                                 iDays = IsLeapYear(Year_Value)?29:28;
  190.                         }
  191.                         break;
  192.                 case 4:
  193.                 case 6:
  194.                 case 9:
  195.                 case 11:
  196.                         {
  197.                                 iDays = 30;
  198.                         }
  199.                         break;
  200.                 default : break;
  201.         }
  202.         return(iDays);
  203. }
  204. //****************************************************
  205. //闰年检测
  206. //****************************************************
  207. bit IsLeapYear(unsigned int uiYear)
  208. {
  209.         return (((uiYear%4)==0)&&((uiYear%100)!=0))||((uiYear%400)==0);
  210. }
  211. //****************************************************
  212. //按键扫描程序
  213. //****************************************************
  214. void Scan_Key()
  215. {
  216.         if( KEY4 == 0 )                                                 //按键1扫描
  217.         {
  218.                 Delay_ms(10);                                        //延时去抖
  219.                 if( KEY4 == 0 )
  220.                 {
  221.                         while(KEY4 == 0);                        //等待松手
  222.                         KEY_NUM = 3;
  223.                         Page = ~Page;
  224.                         LCD1602_write_com(0X01);        //清屏
  225.                 }
  226.         }
  227. }
  228. //****************************************************
  229. //MS延时函数(12M晶振下测试)
  230. //****************************************************
  231. void Delay_ms(unsigned int n)
  232. {
  233.         unsigned int  i,j;
  234.         for(i=0;i<n;i++)
  235.                 for(j=0;j<123;j++);
  236. }
GPS信息获取(LCD1602显示)UTC转换.rar
170.84 KB, 下载次数: 47, 下载积分: 黑币 -5
GPS 51源程序
收藏收藏2 分享淘帖 顶 踩
ID:423051 发表于 2018-12-5 19:23 | 只看该作者
可以用吗
ID:337569 发表于 2018-12-11 23:32 | 只看该作者
我想问一下 这个程序为什么一直进不去中断函数?
ID:337569 发表于 2018-12-11 23:33 | 只看该作者
我想问一下 为什么进不去中断函数
ID:239793 发表于 2019-1-14 19:31 | 只看该作者
为什么和我的头文件冲突了
