查看: 3415|回复: 8
请各位朋友帮忙测试一下串口程序,谢谢。
       我的串口2程序调不通(用STC12C5A60S2),怀疑是我的Keil  C,版本为UV4设置可能有问题。测试STC-ISP串口范例程序,串口1范例可正常执行,输出了字符串,串口2范例没有字符串输出,进入了死循环,不知何解?请朋友帮忙测试一下,究竟是何原因。
程序一:串口1例程(从STC-ISP烧写软件的范例中复制)
/* --- STC MCU Limited ---------------------------------------------*/
/* --- STC12C5Axx Series MCU UART (8-bit/9-bit)Demo ----------------*/
/* --- Mobile: (86)13922805190 -------------------------------------*/
/* --- Fax: 86-0513-55012956,55012947,55012969 ---------------------*/
/* --- Tel: 86-0513-55012928,55012929,55012966----------------------*/
/* If you want to use the program or the program referenced in the  */
/* article, please specify in which data and procedures from STC    */
#include "reg51.h"
#include "intrins.h"
typedef unsigned char BYTE;
typedef unsigned int WORD;
#define FOSC 11059200L      //System frequency
#define BAUD 9600           //UART baudrate
/*Define UART parity mode*/
#define NONE_PARITY     0   //None parity
#define ODD_PARITY      1   //Odd parity
#define EVEN_PARITY     2   //Even parity
#define MARK_PARITY     3   //Mark parity
#define SPACE_PARITY    4   //Space parity
#define PARITYBIT EVEN_PARITY   //Testing even parity
sbit bit9 = P2^2;           //P2.2 show UART data bit9
bit busy;
void SendData(BYTE dat);
void SendString(char *s);
#if (PARITYBIT == NONE_PARITY)
    SCON = 0x50;            //8-bit variable UART
#elif (PARITYBIT == ODD_PARITY) || (PARITYBIT == EVEN_PARITY) || (PARITYBIT == MARK_PARITY)
    SCON = 0xda;            //9-bit variable UART, parity bit initial to 1
#elif (PARITYBIT == SPACE_PARITY)
    SCON = 0xd2;            //9-bit variable UART, parity bit initial to 0
#endif
    TMOD = 0x20;            //Set Timer1 as 8-bit auto reload mode
    TH1 = TL1 = -(FOSC/12/32/BAUD); //Set auto-reload vaule
    TR1 = 1;                //Timer1 start run
    ES = 1;                 //Enable UART interrupt
    EA = 1;                 //Open master interrupt switch
    SendString("STC12C5A60S2\r\nUart Test !\r\n");
    while(1);
UART interrupt service routine
void Uart_Isr() interrupt 4 using 1
    if (RI)
        RI = 0;             //Clear receive interrupt flag
        P0 = SBUF;          //P0 show UART data
        bit9 = RB8;         //P2.2 show parity bit
    if (TI)
        TI = 0;             //Clear transmit interrupt flag
        busy = 0;           //Clear transmit busy flag
Send a byte data to UART
Input: dat (data to be sent)
Output:None
    while (busy);           //Wait for the completion of the previous data is sent
    ACC = dat;              //Calculate the even parity bit P (PSW.0)
    if (P)                  //Set the parity bit according to P
#if (PARITYBIT == ODD_PARITY)
        TB8 = 0;            //Set parity bit to 0
#elif (PARITYBIT == EVEN_PARITY)
        TB8 = 1;            //Set parity bit to 1
#endif
#endif
    busy = 1;
    SBUF = ACC;             //Send data to UART buffer
Send a string to UART
Input: s (address of string)
Output:None
    while (*s)              //Check the end of the string
        SendData(*s++);     //Send current char and increment string ptr
程序二:串口2例程(从STC-ISP烧写软件的范例中复制)
/* --- STC12C5Axx Series MCU UART2 (8-bit/9-bit)Demo ---------------*/
/* --- Web: www.STCMCU.com -----------------------------------------*/
/* --- Web: www.GXWMCU.com -----------------------------------------*/
#include "reg51.h"
#define BAUD 115200         //UART baudrate
/*Declare SFR associated with the UART2 */
sfr AUXR  = 0x8e;           //Auxiliary register
sfr S2CON = 0x9a;           //UART2 control register
sfr S2BUF = 0x9b;           //UART2 data buffer
sfr BRT   = 0x9c;           //Baudrate generator
sfr IE2   = 0xaf;           //Interrupt control 2
#define S2RI  0x01          //S2CON.0
#define S2TI  0x02          //S2CON.1
#define S2RB8 0x04          //S2CON.2
#define S2TB8 0x08          //S2CON.3
bit busy;
    S2CON = 0x50;           //8-bit variable UART
    S2CON = 0xda;           //9-bit variable UART, parity bit initial to 1
    S2CON = 0xd2;           //9-bit variable UART, parity bit initial to 0
#endif
    BRT = -(FOSC/32/BAUD);  //Set auto-reload vaule of baudrate generator
    AUXR = 0x14;            //Baudrate generator work in 1T mode
    IE2 = 0x01;             //Enable UART2 interrupt
    SendString("STC12C5A60S2\r\nUart2 Test !\r\n");
    while(1);
UART2 interrupt service routine
void Uart2() interrupt 8 using 1
    if (S2CON & S2RI)
        S2CON &= ~S2RI;     //Clear receive interrupt flag
        P0 = S2BUF;         //P0 show UART data
        P2 = (S2CON & S2RB8);//P2.2 show parity bit
    if (S2CON & S2TI)
        S2CON &= ~S2TI;     //Clear transmit interrupt flag
Output:None
        S2CON &= ~S2TB8;    //Set parity bit to 0
        S2CON |= S2TB8;     //Set parity bit to 1
#endif
#endif
    busy = 1;
    S2BUF = ACC;            //Send data to UART2 buffer
Output:None
ID:119239 发表于 2016-5-11 23:34 | 只看该作者
怎么没人回复?烦请各位帮忙花几分钟测试,回复测试结果,先谢了。
ID:119239 发表于 2016-5-12 17:31 | 只看该作者
请帮忙测试程序2是否能正常运行,谢谢。
ID:444191 发表于 2018-12-11 16:16 | 只看该作者
其实STC-ISP有范例程序。。。。。
ID:280876 发表于 2018-12-11 19:55 | 只看该作者
自己调试一下,看一下相关寄存器的值
ID:414093 发表于 2018-12-17 16:12 | 只看该作者
你这个程序好复杂,不用这么复杂的吧
ID:875095 发表于 2021-9-14 22:18 | 只看该作者
OK的,之前我跑过
ID:161164 发表于 2021-9-15 15:13 | 只看该作者
在Protues上仿真有串口讯号输出,但时序很慢
Tx/Rx脚是TxD2/RxD2(P1.1/P1.0)
ID:94031 发表于 2021-9-15 18:49 | 只看该作者
软件问题不大重点查硬件。
