音频解码模块看过来,福利福利,VS1003&1053音频解码模块
VS1003中文数据手册.pdf:
mp3文件的数据格式_中文:
单片机源程序:
- * MP3模块测试程序
- * 用途:MP3模块测试程序
- * vs1003 的硬件测试程序,主控芯片为STC12LE5A60S2
- * 其他的微处理器(带SPI接口的)只需稍加修改即可适用
- * 对于不带硬SPI接口的微处理器可以用IO进行SPI的时序模拟
- * 作者 日期 备注
- * Huafeng Lin 20010/09/10 新增
- * Huafeng Lin 20010/09/10 修改
- #include "vs1003.h"
- #include "MusicDataMP3.c"
- #include <intrins.h>
- #define uchar unsigned char
- #define uint unsigned int
- #define ulong unsigned long
- #define bool bit
- #define true 1
- #define flase 0
- //针对SD卡读写板调整引脚
- #define uint8 unsigned char
- sbit MP3_XRESET = P3^2;
- #define Mp3PutInReset() { MP3_XRESET = 0; }
- #define Mp3ReleaseFromReset() { MP3_XRESET =1; }
- sbit MP3_XCS = P3^3;
- #define Mp3SelectControl() { MP3_XCS = 0; }
- #define Mp3DeselectControl() { MP3_XCS = 1; }
- sbit MP3_XDCS = P3^4;
- #define Mp3SelectData() { MP3_XDCS = 0; }
- #define Mp3DeselectData() { MP3_XDCS = 1; }
- sbit MP3_DREQ = P3^5;
- sbit c_SPI_SI = P1^5;
- sbit c_SPI_SO = P1^6;
- sbit c_SPI_CLK = P1^7;
- #define Macro_Set_SI_High() c_SPI_SI = 1
- #define Macro_Set_SI_Low() c_SPI_SI = 0
- #define Macro_Set_CLK_High() c_SPI_CLK = 1
- #define Macro_Set_CLK_Low() c_SPI_CLK = 0
- void LCD_write_english_string(unsigned char X,unsigned char Y,char *s);
- //#define SPIWait() { while((S0SPSR & 0x80) == 0); }//等待SPI将数据发送完毕
- //#define SPI_RESULT_BYTE S0SPDR
- //extern long volatile timeval; //用于延时的全局变量
- //1ms Delayfunction
- //void Delay(uchar ucDelayCount)
- void wait(uchar ucDelayCount)
- uchar ucTempCount;
- uchar uci;
- for(ucTempCount=0; ucTempCount<ucDelayCount; ucTempCount++)
- // uci = 200; //Err
- // uci = 250; //OK
- uci = 230;
- while(uci--)
- _nop_();
- //#define wait(x) Delay(x)
- /* 函数名称 : MSPI_Init */
- /* 函数功能 : 初始化SPI接口,设置为主机。 */
- /* 参数 : 无 */
- /* 返回值 : 无 */
- void MSPI_Init(void)
- PINSEL0 = (PINSEL0 & 0xFFFF00FF) | 0x00005500; //选择 SPI
- S0SPCCR = 0x08; // SPI 时钟设置
- S0SPCR = (0 << 3) | // CPHA = 0,
- (0 << 4) | // CPOL = 0,
- (1 << 5) | // MSTR = 1,
- (0 << 6) | // LSBF = 0,
- (0 << 7); // SPIE = 0,
- c_SPI_SO = 1;
- MP3_DREQ = 1;
- /* 函数名称 : InitPortVS1003 */
- /* 函数功能 : MCU与vs1003接口的初始化 */
- /* 参数 : 无 */
- /* 返回值 : 无 */
- void InitPortVS1003(void)
- MSPI_Init();//SPI口的初始化
- // IODIR &= 0xfffeffff; //其他接口线的设置,其中dreq 为输入口
- // IODIR |= MP3_XRESET | MP3_XCS | MP3_XDCS;//xRESET,xCS,xDS均为输出口
- // IOSET |= MP3_XRESET | MP3_XCS | MP3_XDCS;//xRESET,xCS,xDS默认输出高电平
- MP3_DREQ = 1; //置为输入
- MP3_XRESET = 1;
- MP3_XCS = 1;
- MP3_XDCS = 1;
- //uint8 SD_SPI_ReadByte(void);
- //void SD_SPI_WriteByte(uint8 ucSendData);
- //#define SPI_RecByte() SD_SPI_ReadByte()
- //#define SPIPutChar(x) SD_SPI_WriteByte(x)
- #if 1
- /* 函数名称 : SPIPutChar */
- /* 函数功能 : 通过SPI发送一个字节的数据 */
- /* 参数 : 待发送的字节数据 */
- /* 返回值 : 无 */
- void SPIPutChar(unsigned char ucSendData)
- // S0SPDR = c;
- // while((S0SPSR & 0x80) == 0); //等待SPI将数据发送完毕
- uchar ucCount;
- uchar ucMaskCode;
- ucMaskCode = 0x80;
- for(ucCount=0; ucCount<8; ucCount++)
- Macro_Set_CLK_Low();
- if(ucMaskCode & ucSendData)
- Macro_Set_SI_High();
- else
- Macro_Set_SI_Low();
- Macro_Set_CLK_High();
- ucMaskCode >>= 1;
- ** 函数名称: INT8U SPI_RecByte() Name: INT8U SPI_RecByte()
- ** 功能描述: 从SPI接口接收一个字节 Function: receive a byte from SPI interface
- ** 输 入: 无 Input: NULL
- ** 输 出: 收到的字节 Output: the byte that be received
- static uchar SPI_RecByte(void)
- uchar ucReadData;
- uchar ucCount;
- ucReadData = 0;
- ucReadData <<= 1;
- //降低时钟频率
- if(c_SPI_SO)
- ucReadData |= 0x01;
- return(ucReadData);
- #endif
- /* 函数名称 : Mp3WriteRegister */
- /* 函数功能 : 写vs1003寄存器 */
- /* 参数 : 寄存器地址,待写数据的高8位,待写数据的低8位 */
- /* 返回值 : 无 */
- void Mp3WriteRegister(unsigned char addressbyte, unsigned char highbyte, unsigned char lowbyte)
- Mp3DeselectData();
- Mp3SelectControl();//XCS = 0
- SPIPutChar(VS_WRITE_COMMAND); //发送写寄存器命令
- SPIPutChar(addressbyte); //发送寄存器的地址
- SPIPutChar(highbyte); //发送待写数据的高8位
- SPIPutChar(lowbyte); //发送待写数据的低8位
- Mp3DeselectControl();
- /* 函数名称 : Mp3ReadRegister */
- /* 参数 : 寄存器地址 */
- /* 返回值 : vs1003的16位寄存器的值 */
- unsigned int Mp3ReadRegister(unsigned char addressbyte)
- unsigned int resultvalue = 0;
- uchar ucReadValue;
- SPIPutChar(VS_READ_COMMAND); //发送读寄存器命令
- SPIPutChar((addressbyte)); //发送寄存器的地址
- // SPIPutChar(0xff); //发送读时钟
- // resultvalue = (SPI_RESULT_BYTE) << 8;//读取高8位数据
- ucReadValue = SPI_RecByte();
- resultvalue = ucReadValue<<8;
- // resultvalue |= (SPI_RESULT_BYTE); //读取低8位数据
- resultvalue |= ucReadValue;
- return resultvalue; //返回16位寄存器的值
- /* 函数名称 : Mp3SoftReset */
- /* 函数功能 : vs1003软件复位 */
- /* 参数 : 无 */
- /* 返回值 : 无 */
- void Mp3SoftReset(void)
- Mp3WriteRegister (SPI_MODE, 0x08, 0x04); //软件复位
- wait(1); //延时1ms
- while (MP3_DREQ == 0); //等待软件复位结束
- Mp3WriteRegister(SPI_CLOCKF, 0x98, 0x00);//设置vs1003的时钟,3倍频
- Mp3WriteRegister (SPI_AUDATA, 0xBB, 0x81); //采样率48k,立体声
- Mp3WriteRegister(SPI_BASS, 0x00, 0x55);//设置重音
- Mp3SetVolume(10,10);//设置音量
- wait(1); //延时1ms
- //向vs1003发送4个字节无效数据,用以启动SPI发送
- Mp3SelectData();
- SPIPutChar(0);
- SPIPutChar(0);
- SPIPutChar(0);
- SPIPutChar(0);
- /* 函数名称 : Mp3Reset */
- /* 函数功能 : vs1003硬件复位 */
- /* 参数 : 无 */
- /* 返回值 : 无 */
- void Mp3Reset(void)
- Mp3PutInReset();//xReset = 0 复位vs1003
- wait(200);//延时100ms
- SPIPutChar(0xff);//发送一个字节的无效数据,启动SPI传输
- Mp3DeselectControl(); //xCS = 1
- Mp3DeselectData(); //xDCS = 1
- Mp3ReleaseFromReset(); //xRESET = 1
- wait(200); //延时100ms
- while (MP3_DREQ == 0);//等待DREQ为高
- Mp3SetVolume(50,50);
- Mp3SoftReset();//vs1003软复位
- bool CheckVS1003B_DRQ(void)
- bool bResult;
- bResult =MP3_DREQ;
- return(bResult);
- /* 函数名称 : VsSineTest */
- /* 函数功能 : vs1003正弦测试,将该函数放在while循环中, */
- /* 如果能持续听到一高一低的声音,证明测试通过 */
- /* 参数 : 无 */
- /* 返回值 : 无 */
- void VsSineTest(void)
- Mp3PutInReset(); //xReset = 0 复位vs1003
- wait(200);
- Mp3WriteRegister(SPI_MODE,0x08,0x20);//进入vs1003的测试模式
- while (MP3_DREQ == 0); //等待DREQ为高
- Mp3SelectData(); //xDCS = 1,选择vs1003的数据接口
- //向vs1003发送正弦测试命令:0x53 0xef 0x6e n 0x00 0x00 0x00 0x00
- //其中n = 0x24, 设定vs1003所产生的正弦波的频率值,具体计算方法见vs1003的datasheet
- SPIPutChar(0x53);
- SPIPutChar(0xef);
- SPIPutChar(0x6e);
- SPIPutChar(0x24);
- SPIPutChar(0x00);
- SPIPutChar(0x00);
- SPIPutChar(0x00);
- SPIPutChar(0x00);
- // wait(500);
- wait(250);
- wait(250);
- Mp3DeselectData();//程序执行到这里后应该能从耳机听到一个单一频率的声音
- //退出正弦测试
- Mp3SelectData();
- SPIPutChar(0x45);
- SPIPutChar(0x78);
- SPIPutChar(0x69);
- SPIPutChar(0x74);
- SPIPutChar(0x00);
- SPIPutChar(0x00);
- SPIPutChar(0x00);
- SPIPutChar(0x00);
- // wait(500);
- wait(250);
- wait(250);
- //再次进入正弦测试并设置n值为0x44,即将正弦波的频率设置为另外的值
- Mp3SelectData();
- SPIPutChar(0x53);
- SPIPutChar(0xef);
- SPIPutChar(0x6e);
- SPIPutChar(0x44);
- SPIPutChar(0x00);
- SPIPutChar(0x00);
- SPIPutChar(0x00);
- SPIPutChar(0x00);
- // wait(500);
- wait(250);
- wait(250);
- //退出正弦测试
- Mp3SelectData();
- SPIPutChar(0x45);
- SPIPutChar(0x78);
- SPIPutChar(0x69);
- SPIPutChar(0x74);
- SPIPutChar(0x00);
- SPIPutChar(0x00);
- SPIPutChar(0x00);
- SPIPutChar(0x00);
- // wait(500);
- wait(250);
- wait(250);
- void test_1003_PlayMP3File();
- void TestVS1003B(void)
- Mp3Reset();
- VsSineTest();
- Mp3SoftReset();
- test_1003_PlayMP3File();
- //写寄存器,参数,地址和数据
- void VS1003B_WriteCMD(unsigned char addr, unsigned int dat)
- VS1003B_XDCS_H();
- VS1003B_XCS_L();
- VS1003B_WriteByte(0x02);
- //delay_Nus(20);
- VS1003B_WriteByte(addr);
- VS1003B_WriteByte(dat>>8);
- VS1003B_WriteByte(dat);
- //delay_Nus(200);
- VS1003B_XCS_H();
- Mp3WriteRegister(addr,dat>>8,dat);
- //读寄存器,参数 地址 返回内容
- unsigned int VS1003B_ReadCMD(unsigned char addr)
- unsigned int temp;
- unsigned char temp1;
- VS1003B_XDCS_H();
- VS1003B_XCS_L();
- VS1003B_WriteByte(0x03);
- //delay_Nus(20);
- temp= VS1003B_ReadByte();
- temp=temp<<8;
- temp1= VS1003B_ReadByte();
- temp=temp|temp1;;
- VS1003B_XCS_H();
- return temp;
- return(Mp3ReadRegister(addr));
- //写数据,音乐数据
- void VS1003B_WriteDAT(unsigned char dat)
- // VS1003B_XDCS_L();
- // VS1003B_WriteByte(dat);
- // VS1003B_XDCS_H();
- // VS1003B_XCS_H();
- Mp3SelectData();
- SPIPutChar(dat);
- //开启环绕声
- void VS1003B_SetVirtualSurroundOn(void)
- uchar ucRepeatCount;
- uint uiModeValue;
- ucRepeatCount =0;
- while(1)//写时钟寄存器
- uiModeValue = VS1003B_ReadCMD(0x00);
- if(uiModeValue & 0x0001)
- break;
- else
- uiModeValue |= 0x0001;
- VS1003B_WriteCMD(0,uiModeValue);
- ucRepeatCount++;
- if(ucRepeatCount++ >10 )break;
- //关闭环绕声
- void VS1003B_SetVirtualSurroundOff(void)
- uint uiModeValue;
- ucRepeatCount =0;
- while(1)//写时钟寄存器
- break;
- else
- ucRepeatCount++;
- //增强重音
- //入口参数 1.强度0-15
- // 2.频率0-15 (X10Hz)
- void VS1003B_SetBassEnhance(uchar ucValue, ucFrequencyID)
- uint uiWriteValue;
- uint uiReadValue;
- ucRepeatCount =0;
- uiWriteValue = VS1003B_ReadCMD(0x02);
- uiWriteValue &= 0xFF00;
- uiWriteValue |= ucValue<<4;
- uiWriteValue &= (ucFrequencyID & 0x0F);
- while(1)//写时钟寄存器
- VS1003B_WriteCMD(2,uiWriteValue);
- uiReadValue = VS1003B_ReadCMD(0x02);
- if(uiReadValue == uiWriteValue)
- break;
- ucRepeatCount++;
- uint uiVolumeCount; //当前音量值
- //VS1003初始化,0成功 1失败
- unsigned char VS1003B_Init()
- unsigned char retry;
- PORT_INI();
- DDRB|=0xa0;
- VS1003B_DDR &=~(1<<VS1003B_DREQ);
- //delay_Nus(50);
- VS1003B_XCS_H();
- VS1003B_XDCS_H();
- VS1003B_XRESET_L();
- VS1003B_Delay(0xffff);
- VS1003B_XRESET_H();//使能芯片
- VS1003B_SPI_Low();//先以低频操作
- VS1003B_Delay(0xffff);//延时
- Mp3Reset();
- retry=0;
- while(VS1003B_ReadCMD(0x00) != 0x0800)//写mode寄存器
- VS1003B_WriteCMD(0x00,0x0800);
- if(retry++ >10 )break;//{PORTB|=_BV(PB1);break;}
- retry=0;
- /*while(VS1003B_ReadCMD(0x02) != 0x75)//写mode寄存器
- VS1003B_WriteCMD(0x02,0x75);
- retry=0;
- while(VS1003B_ReadCMD(0x03) != 0x9800)//写时钟寄存器
- VS1003B_WriteCMD(0x03,0x9800);
- retry=0;
- // while(VS1003B_ReadCMD(0x0b) != 0x1111)//设音量
- // VS1003B_WriteCMD(0x0b,0x1111);
- // if(retry++ >10 )break;
- while(VS1003B_ReadCMD(0x0b) != uiVolumeCount)//设音量
- VS1003B_WriteCMD(0x0b,uiVolumeCount);
- // VS1003B_SPI_High();//提高速度,全速运行
- if(retry > 10)return 1;
- return 0;
- //VS1003软件复位
- void VS1003B_SoftReset()
- VS1003B_WriteCMD(0x00,0x0804);//写复位
- // VS1003B_Delay(0xffff);//延时,至少1.35ms
- wait(2);
- void VS1003B_Fill2048Zero()
- unsigned char i,j;
- for(i=0;i<64;i++)
- if(CheckVS1003B_DRQ())
- Mp3SelectData();
- for(j=0;j<32;j++)
- VS1003B_WriteDAT(0x00);
- unsigned int data_pointer;unsigned char i;
- unsigned int uiCount;
- uiCount = sizeof(MusicData);
- data_pointer=0;
- VS1003B_SoftReset();
- while(uiCount>0)
- for(i=0;i<32;i++)
- VS1003B_WriteDAT(MusicData[data_pointer]);
- data_pointer++;
- uiCount -= 32;
- VS1003B_Fill2048Zero();
下载:
VS1003B MP3解码模块 载咪头 STM32单片机开发板.rar
(6.28 MB, 下载次数: 65)
