//测试颜色识别模块TCS3200
const int s0 = 8;
const int s1 = 9;
const int s2 = 12;
const int s3 = 11;
const int out = 10;
//RGB颜色色值
int red = 0;
int green = 0;
int blue = 0;
//信号灯
int inforLED = 13;
String gifKey ="01020121010102";
byte keyCursor = 0; //核对密码的游标
byte currentColor = -1; //扫描得到的颜色
void setup()
pinMode(s0, OUTPUT);
pinMode(s1, OUTPUT);
pinMode(s2, OUTPUT);
pinMode(s3, OUTPUT);
pinMode(inforLED,OUTPUT);
pinMode(out, INPUT);
Serial.begin(9600);
digitalWrite(s0, HIGH);
digitalWrite(s1, HIGH);
void loop()
color();
//输出RGB各色值
Serial.print("Red:");
Serial.print(red, DEC);
Serial.print("Green:");
Serial.print(green, DEC);
Serial.print("Blue:");
Serial.print(blue, DEC);
Serial.println();
//检验结果是否红色
if (red < blue && red < green && red > 30 && red <1000)
// Serial.println("Red 0");
currentColor = 0;
} else if (blue < red && blue < green && blue > 30 && blue <1000) { //检验结果是否绿色
// Serial.println("Blue 2");
currentColor = 2;
} else if (green < red && green < blue && green > 30 && green <1000) { //检验结果是否蓝色
// Serial.println("Green 1");
currentColor = 1;
Serial.print("currentColor:");
Serial.print(currentColor);
Serial.print(" ");
if(currentColor == (byte(gifKey[keyCursor])-48) ) {
keyCursor ++;
} else {
if(keyCursor == 0) {
} else {
if(currentColor == (byte(gifKey[keyCursor-1])-48) ) {
} else {
keyCursor = 0;
// if(currentColor == gifKey[keyCursor+1]) {
// keyCursor ++;
// } else {
// if(keyCursor == -1) {
// } else {
// if(currentColor == gifKey[keyCursor]) {
// } else {
// keyCursor = -1;
Serial.print("keyCursor:");
Serial.println(keyCursor);
if(keyCursor == 14) {
digitalWrite(inforLED,HIGH);
Serial.println("open lock successfully!");
delay(3000);
digitalWrite(inforLED,LOW);
Serial.println();
//延时两秒后关闭所有LED
void color()
//设置好S2、S3端口,准备读取颜色值
digitalWrite(s2, LOW);
digitalWrite(s3, LOW);
//红色光RED
red = pulseIn(out, digitalRead(out) == HIGH ? LOW : HIGH);
digitalWrite(s3, HIGH);
//蓝色光BLUE
blue = pulseIn(out, digitalRead(out) == HIGH ? LOW : HIGH);
digitalWrite(s2, HIGH);
//绿色光GREEN
green = pulseIn(out, digitalRead(out) == HIGH ? LOW : HIGH);
