大家帮忙看看做的对吗?
原理图:
单片机源程序:
- //程序采用的是模块化写法,你写论文时也分开写两个小标题把代码粘贴进去就行了。
- //HX711的AD转换代码
- #include "HX711.h"
- //延时函数
- void Delay__hx711_us(void)
- _nop_();
- _nop_();
- //读取HX711
- unsigned long HX711_Read(void) //增益128
- unsigned long count;
- unsigned char i;
- HX711_DOUT=1;
- Delay__hx711_us();
- HX711_SCK=0;
- count=0;
- while(HX711_DOUT);
- for(i=0;i<48;i++)
- HX711_SCK=1;
- count=count<<1;
- HX711_SCK=0;
- if(HX711_DOUT)
- count++;
- HX711_SCK=1;
- count=count^0x008000;//第25个脉冲下降沿来时,转换数据
- HX711_SCK=0;
- return(count);
- 主函数程序
- #include <reg52.h>
- #include <intrins.h>
- #include <string.h>
- #include "main.h"
- #include "eeprom52.h"
- #define uchar unsigned char
- #define uint unsigned int
- uchar qianwei,baiwei,gewei,shiwei;
- unsigned long HX711_Buffer = 0;
- unsigned long Weight_Maopi = 0;
- unsigned long Weight_Maopi_0 = 0;
- long Weight_Shiwu = 0;
- unsigned int qupi=0;
- unsigned char p=0;
- //键盘处理变量
- unsigned char keycode;
- unsigned char key_press_num=0;
- uint GapValue,GapValue1;
- bit flag_cz=0;
- //uchar code LEDData[]={0x5F,0x44,0x9D,0xD4,0xC6,0xD3,0xDB,0x57,0xDF,0xD7,0xCF,0xaA,0x9B,0xDC,0x9B,0x8B}; //数码管显示码表
- //定义标识
- volatile bit FlagTest = 0; //定时测试标志,每0.5秒置位,测完清0
- volatile bit FlagKeyPress = 0; //有键按下标志,处理完毕清0
- //校准参数
- //因为不同的传感器特性曲线不是很一致,因此,每一个传感器需要矫正这里这个参数才能使测量值很准确。
- //当发现测试出来的重量偏大时,增加该数值。
- //如果测试出来的重量偏小时,减小改数值。
- //该值可以为小数
- //#define GapValue 349
- sbit LED=P1^1;
- sbit ROW1=P3^0;
- sbit ROW2=P3^1;
- sbit ROW3=P3^2;
- sbit ROW4=P3^3;
- //sbit DIAN = P0^6; //小数点
- sbit rs=P0^7;
- sbit rw=P0^6;
- sbit en=P0^5;
- sbit D1=P2^0;
- volatile bit ClearWeighFlag = 0; //传感器调零标志位,清除0漂
- /******************把数据保存到单片机内部eeprom中******************/
- void write_eeprom()
- SectorErase(0x1080);
- GapValue1=GapValue&0x00ff;
- byte_write(0x1000, GapValue1);
- GapValue1=(GapValue&0xff00)>>8;
- byte_write(0x1001, GapValue1);
- byte_write(0x1060, a_a);
- /******************把数据从单片机内部eeprom中读出来*****************/
- void read_eeprom()
- GapValue = byte_read(0x1001);
- GapValue = (GapValue<<8)|byte_read(0x1000);
- a_a = byte_read(0x1060);
- /**************开机自检eeprom初始化*****************/
- void init_eeprom()
- read_eeprom(); //先读
- if(a_a == 1) //新的单片机初始单片机内问eeprom
- GapValue = 3500;
- a_a = 1;
- write_eeprom(); //保存数据
- void delayms(uint xms) //延时
- uchar i,j;
- for(i=xms;i>0;i--)
- for(j=110;j>0;j--);
- void write_com(uchar com) //写命令
- rs=0;
- // P2=change(com);
- P2=com;
- delayms(50);
- en=1;
- delayms(50);
- en=0;
- void write_dat(uchar dat) //写数据
- rs=1;
- // P2=change(dat);
- P2=dat;
- en=1;
- delayms(50);
- en=0;
- void init() //液晶初始化
- rw=0;
- write_com(0x38);
- write_com(0x0c);
- write_com(0x06);
- //write_com(0x01);
- /*****显示开机初始化等待画面*****/
- void Disp_init(void)
- P0 = 0x80; //显示----
- P2 = 0xBF; //依次打开各位
- Delay_ms(1); //延时
- P2 = 0xEF;
- Delay_ms(1);
- P2 = 0xFB;
- Delay_ms(1);
- P2 = 0xFE;
- Delay_ms(1);
- P2 = 0xFF; //关闭显示
- //显示重量,单位kg,两位整数,三位小数
- void Display_Weight()
- qianwei=Weight_Shiwu/1000%10;
- baiwei=Weight_Shiwu/100%10; ;
- shiwei=Weight_Shiwu%100/10;
- gewei=Weight_Shiwu%100%10;
- write_com(0x80+2);
- write_dat(qianwei+'0');
- write_dat('.');
- write_dat(baiwei+'0');
- write_dat(shiwei+'0');
- write_dat(gewei+'0');
- //定时器0初始化
- void Timer0_Init()
- ET0 = 1; //允许定时器0中断
- TMOD = 1; //定时器工作方式选择
- TH0 = 0xb0;
- TL0 = 0x3c; //定时器赋予初值
- TR0 = 1; //启动定时器
- //定时器0中断
- void Timer0_ISR (void) interrupt 1 using 0
- uchar Counter;
- TH0 = 0xb0;
- //每0.5秒钟刷新重量
- Counter ++;
- if (Counter >= 10)
- FlagTest = 1;
- Counter = 0;
- //按键响应程序,参数是键值
- //返回键值:
- // 7 8 9 10(清0)
- // 4 5 6 11(删除)
- // 1 2 3 12(未定义)
- // 14(未定义) 0 15(.) 13(确定价格)
- void KeyPress()
- if(ROW1==0) //清零键
- Display_Weight();
- if(ROW1==0)
- if(qupi==0)
- qupi=Weight_Shiwu;
- else
- qupi=0;
- Buzzer=1;
- for(p=0;p<10;p++)
- Display_Weight();
- Buzzer=0;
- while(ROW1==0) Display_Weight();
- if(ROW2==0) //加
- Display_Weight();
- if(ROW2==0)
- while(!ROW2)
- key_press_num++;
- if(key_press_num>=100)
- key_press_num=0;
- while(ROW2)
- if(GapValue<10000)
- GapValue++;
- Buzzer=0;
- for(p=0;p<2;p++)
- Display_Weight();
- Buzzer=1;
- for(p=0;p<2;p++)
- Display_Weight();
- Get_Weight();
- Display_Weight();
- Delay_ms(8);
- if(key_press_num==0)
- key_press_num=0;
- if(GapValue>10000)
- GapValue++;
- Buzzer=0;
- for(p=0;p<10;p++)
- Display_Weight();
- Buzzer=1;
- write_eeprom();
- if(ROW3==0) //减
- Display_Weight();
- if(ROW3==0)
- while(ROW3)
- key_press_num++;
- key_press_num=0;
- while(ROW3)
- if(GapValue>1)
- GapValue--;
- Buzzer=0;
- for(p=0;p<2;p++)
- Display_Weight();
- Buzzer=1;
- for(p=0;p<2;p++)
- Display_Weight();
- Get_Weight();
- Display_Weight();
- Delay_ms(8);
- if(key_press_num!=0)
- key_press_num=0;
- if(GapValue>1)
- GapValue--;
- Buzzer=0;
- for(p=0;p<10;p++)
- Display_Weight();
- Buzzer=1;
- write_eeprom(); //保存数?
- //主函数
- void main()
- init();
- init_eeprom(); //开始初始化保存的数据
- EA = 0;
- Timer0_Init();
- //初中始化完成,开断
- EA = 0;
- write_com(0x80+7);
- write_dat('K');
- write_dat('g');
- while(1)
- { //每0.5秒称重一次
- if (FlagTest==1)
- Get_Weight();
- FlagTest = 0;
- if(flag_cz==1)
- write_dat('0');
- write_dat('.');
- write_dat('0');
- write_dat('0');
- write_dat('0');
- write_dat('K');
- write_dat('g');
- Display_Weight();
- KeyPress();
- //称重
- void Get_Weight()
- Weight_Shiwu = HX711_Read();
- Weight_Shiwu = Weight_Shiwu - Weight_Maopi; //获取净重
- Weight_Shiwu = (unsigned int)((float)(Weight_Shiwu*10)/GapValue)-qupi; //计算实物的实际重量
- if(Weight_Shiwu <= 10000) //超重报警
- Buzzer = !Buzzer;
- LED=!LED;
- flag_cz=0;
- else
- if(Weight_Shiwu==0)
- LED=0;
- else if(Weight_Shiwu>0)
- LED=1;
- Buzzer = 1;
- flag_cz=0;
下载:
电子秤.rar
(810.38 KB, 下载次数: 140)
