查看: 5189|回复: 3
PCF8591 AD采集单片机程序 LCD1602显示
关于PCF8591 ad 转换程序源码
单片机源程序:
  1. #include<reg52.h>
  2. #include<intrins.h>
  4. #define uint unsigned int
  5. #define Delay4us(){_nop_();_nop_();_nop_();_nop_();}
  6. sbit LCD_RS=P2^2;
  7. sbit LCD_RW=P2^1;
  8. sbit LCD_EN=P2^0;
  9. sbit SCL=P1^0;                            //I2C时钟引脚
  10. sbit SDA=P1^1;                            //I2C数据输入输出引脚
  11. uchar Recv_Buffer[4];                     //数据接收缓冲
  12. uint Voltage[]={'0','0','0','0','0','0'};         //数据分解为电压x.xx
  13. bit bdata IIC_ERROR;                      //I2C错误标志位
  14. uchar LCD_Line_1[]={"DQ      .  ppm       "};
  15. //延时
  16. void delay(int ms)
  17. {
  18. uchar i;
  19. while(ms--) for(i=0;i<250;i++) Delay4us();
  20. }
  21. //LCD忙检测
  22. bit LCD_Busy_Check()
  23. {
  24. bit Result;
  25. LCD_RS=0;LCD_RW=1;
  26. LCD_EN=1;Delay4us();Result=(bit)(P0&0x80);
  27. LCD_EN=0;
  28. return Result;
  29. }
  30. //写指令
  31. void LCD_Write_Command(uchar cmd)
  32. {
  33. while(LCD_Busy_Check());
  34. LCD_RS=0;LCD_RW=0;LCD_EN=0;_nop_();_nop_();
  35. P0=cmd;Delay4us();
  36. LCD_EN=1;Delay4us();LCD_EN=0;
  37. }
  38. // 写数据
  39. void LCD_Write_Data(uchar dat)
  40. {
  41. while(LCD_Busy_Check());
  42. LCD_RS=1;LCD_RW=0;LCD_EN=0;P0=dat;Delay4us();
  43. LCD_EN=1;Delay4us();LCD_EN=0;
  44. }
  45. //初始化
  46. void LCD_Initialise()
  47. {
  48. LCD_Write_Command(0x38);delay(5);
  49. LCD_Write_Command(0x0c);delay(5);
  50. LCD_Write_Command(0x06);delay(5);
  51. LCD_Write_Command(0x01);delay(5);
  52. LCD_Write_Command(0x03);delay(5);
  53. LCD_Write_Command(0x02);delay(5);
  54. }
  55. //设置显示位置
  56. void LCD_Set_Position(uchar pos)
  57. {
  58. LCD_Write_Command(pos|0x80);
  59. }
  60. //显示一行
  61. void LCD_Display_A_Line(uchar Line_Addr,uchar s[])
  62. {
  63. uchar i;
  64. LCD_Set_Position(Line_Addr);
  65. for(i=0;i<16;i++)LCD_Write_Data(s[i]);
  66. }
  67. // 将模数转换后得到的值分解存入缓存
  68. void Convert_To_Voltage(uchar val)
  69. {
  70. uchar Tmp;                       //最大值为255,对应5V
  71. Voltage[2]=val/100+'0';           //整数部分
  72. Voltage[3]=val/10%10+'0' ;
  73. Voltage[4]=val%10+'0' ;
  74. Tmp=val*10;                   // 第一位小数
  75. Voltage[1]=Tmp%10+'0';
  76. Tmp=Tmp*10;
  77. Voltage[0]=Tmp%10+'0';
  78. }
  79. //启动I2C总线
  80. void IIC_Start()
  81. {
  82. SDA=1;SCL=1;Delay4us();SDA=0;Delay4us();SCL=0;
  83. }
  84. //停止I2C总线
  85. void IIC_Stop()
  86. {
  87. SDA=0;SCL=1;Delay4us();SDA=1; Delay4us();SCL=0;
  88. }
  89. // 从机发送应答位
  90. void Slave_ACK()
  91. {
  92. SDA=0;SCL=1;Delay4us();SCL=0;SDA=1;
  93. }
  94. // 从机发送非应答位
  95. void Slave_NOACK()
  96. {
  97. SDA=1;SCL=1;Delay4us();SCL=0;SDA=0;
  98. }
  99. //发送一字节
  100. void IIC_SendByte(uchar wd)
  101. {
  102. uchar i;
  103. for(i=0;i<8;i++) //循环移入8位
  104. {
  105. SDA=(bit)(wd&0x80);_nop_();_nop_();
  106. SCL=1;Delay4us();SCL=0;wd<<=1;
  107. }
  108. Delay4us();
  109. SDA=1;                                 //释放总线并准备读取应答
  110. SCL=1;
  111. Delay4us();
  112. IIC_ERROR=SDA;                        //IIC_ERROR=1表示无应答
  113. SCL=0;
  114. Delay4us();
  115. }
  116. //接收一字节
  117. uchar IIC_ReceiveByte()
  118. {
  119. uchar i,rd=0x00;
  120. for(i=0;i<8;i++)
  121. {
  122. SCL=1;rd<<=1;rd|=SDA;Delay4us();SCL=0;Delay4us();
  123. }
  124. SCL=0;Delay4us();
  125. return rd;
  126. }
  127. //连续读入4路通道的A/D转换结果并保存到Recv_Buffer
  128. void ADC_PCF8591(uchar CtrlByte)
  129. {
  130. uchar i;
  131. IIC_Start();
  132. IIC_SendByte(0x90);                         // 发送写地址
  133. if(IIC_ERROR==1)return;
  134. // IIC_SendByte(CtrlByte);                  //发送控制字节
  135. //if(IIC_ERROR==1)return;
  136. IIC_Start();                               //重新发送开始命令
  137. IIC_SendByte(0x91);                        // 发送读地址
  138. if(IIC_ERROR==1)return;
  139. IIC_ReceiveByte();                        //空读一次,调整读顺序
  140. Slave_ACK();                             //收到一字节后发送一个应答位
  141. for(i=0;i<4;i++)
  142. {
  143. Recv_Buffer[i++]=IIC_ReceiveByte();
  144. Slave_ACK();                          //收到一个字节后发送一个应答位
  145. }
  146. Slave_NOACK();
  147. IIC_Stop();                          //收到一个字节后发送一个非应答位
  148. }
  149. …………限于本文篇幅 余下代码请从51黑下载附件…………
下载:
PCF8591 LCD1602AD采集程序.zip (32.77 KB, 下载次数: 177)
收藏收藏2 分享淘帖 顶 踩
ID:316572 发表于 2018-5-9 20:03 | 只看该作者
66666666666666666666666666666666
ID:326117 发表于 2018-5-10 21:27 | 只看该作者
你好,我想问下你这个测得是什么
ID:462433 发表于 2019-4-18 20:06 | 只看该作者
没有接线图吗?
