查看: 45764|回复: 104
基于STM32的智能循迹小车源程序
毕业设计,自己做了一个多月,希望有用  附加一些自己写的程序。
  1. /* Includes ------------------------------------------------------------------*/
  2. #include "stm32f10x.h"
  3. #include "stm32f10x_tim.h"
  4. #include "stm32f10x_flash.h"
  5. #include "stm32f10x_exti.h"
  6. #include "stm32f10x_rcc.h"
  7. #include "systick.h"
  8. #include "stdio.h"
  9. #include "misc.h"
  10. #define infra1 GPIO_ReadInputDataBit(GPIOC, GPIO_Pin_7);
  11. #define infra2 GPIO_ReadInputDataBit(GPIOC, GPIO_Pin_8);
  12. #define tube1 GPIO_ReadInputDataBit(GPIOC, GPIO_Pin_0);
  13. #define tube2 GPIO_ReadInputDataBit(GPIOC, GPIO_Pin_1);
  14. #define tube3 GPIO_ReadInputDataBit(GPIOC, GPIO_Pin_2);
  15. #define tube4 GPIO_ReadInputDataBit(GPIOC, GPIO_Pin_3);
  16.
  17. TIM_OCInitTypeDef  TIM1_OCInitStructure;
  18. extern FlagStatus  Status;
  19. extern u16 TIM1Compare1[3] = {0,0x3FFF,0x1FFF};
  20. extern u16 TIM1Compare2[3] = {0x7FFF,0x3FFF,0x1FFF};
  21. extern u16 TIM1Compare3[3] = {0,0x3FFF,0x1FFF};
  22. extern u16 TIM1Compare4[3] = {0x7FFF,0x3FFF,0x1FFF};
  23. extern u16 tubecnt;
  24. extern u16 flag;
  25. extern int add;
  26. void GPIO_Configuration(void);
  27. void TIM_Configuration(void);
  28. void tim2_Configuration(void);
  29. void exti_Configuration(void);
  30. void nvic_Configuration(void);
  31. void zhi1(void);
  32. void zhi2(void);
  33. void zhi3(void);
  34. void zuoxiao(void);
  35. void zuoda(void);
  36. void youxiao(void);
  37. void youda(void);
  38. void xunji(void);
  39. u16 ceju(void);
  40. int main(void)
  41. {
  42.
  43.         RCC_Configuration();
  44.         GPIO_Configuration();
  45.         TIM_Configuration();
  46.         delay_init();
  47.         while(1)
  48.         {
  49.          GPIO_ResetBits(GPIOE,GPIO_Pin_15);
  50.          GPIO_ResetBits(GPIOB,GPIO_Pin_11);
  51.         }
  52.
  53. }
  54. void GPIO_Configuration(void)
  55. {
  56.   GPIO_InitTypeDef GPIO_InitStructure;
  57. /*TIM1  PWM  输出:A9:CH1/A10:CH2                */
  58.   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10|GPIO_Pin_9;
  59.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  60.   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  61.   GPIO_Init(GPIOA, &GPIO_InitStructure);
  62. /*LED显示:LED5:PE15 / LED6:PB11 / LED7:PE14 / LED8:PB10         */
  63.   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10|GPIO_Pin_11;
  64.   GPIO_InitStructure.GPIO_Mode =GPIO_Mode_Out_PP;
  65.   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  66.   GPIO_Init(GPIOB, &GPIO_InitStructure);
  67.                  GPIO_SetBits(GPIOB,GPIO_Pin_10);
  68.                 GPIO_SetBits(GPIOB,GPIO_Pin_11);
  69.   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_14|GPIO_Pin_15;
  70.   GPIO_InitStructure.GPIO_Mode =GPIO_Mode_Out_PP;
  71.   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  72.   GPIO_Init(GPIOE, &GPIO_InitStructure);
  73.                   GPIO_SetBits(GPIOE,GPIO_Pin_14);
  74.                 GPIO_SetBits(GPIOE,GPIO_Pin_15);
  75.
  76. /*红外管:infra1-> PC7, infra2-> PC8         浮空输入  */
  77.   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7 | GPIO_Pin_8 ;
  78.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
  79.   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  80.   GPIO_Init(GPIOC, &GPIO_InitStructure);
  81. /*光电管:tube1-> PC0, tube2-> PC1, tube3-> PC2, tube4-> PC3        浮空输入*/
  82.   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1|GPIO_Pin_2 | GPIO_Pin_3;
  83.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
  84.   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  85.   GPIO_Init(GPIOC, &GPIO_InitStructure);
  86. /*超声波:Trig:PB9                Echo:PB8   */
  87.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
  88.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  89.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  90.         GPIO_Init(GPIOB, &GPIO_InitStructure);
  91.         GPIO_ResetBits( GPIOB, GPIO_Pin_9);
  92.
  93.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
  94.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;            //PB1接受采集上升沿 PB6低电平
  95.         GPIO_Init(GPIOB, &GPIO_InitStructure);
  96.         GPIO_ResetBits(GPIOB,GPIO_Pin_8);
  97. }
  98. void TIM_Configuration(void)
  99. {
  100.         TIM_TimeBaseInitTypeDef  TIM1_TimeBaseStructure;
  101.         TIM_OCInitTypeDef  TIM1_OCInitStructure;
  102.
  103.           TIM_DeInit(TIM1);
  104.          /* Time Base configuration */
  105.           TIM1_TimeBaseStructure.TIM_Prescaler = 0x0; //设置了用来作为TIMx时钟频率除数的预分频值
  106.         TIM1_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;         //选择了计数器模式
  107.         TIM1_TimeBaseStructure.TIM_Period = 0xFFFF;  //设置了在下一个更新事件装入活动的自动重装载寄存器周期  ARR
  108.         TIM1_TimeBaseStructure.TIM_ClockDivision = 0x0;  //设置了时钟分割
  109.         TIM1_TimeBaseStructure.TIM_RepetitionCounter = 0x0;         //设置了周期计数器值
  110.         TIM_TimeBaseInit(TIM1,&TIM1_TimeBaseStructure);//根据TIM_TimeBaseInitStruct中指定的参数初始化TIMx的时间基数单位(5个参数)
  111.        //TIM1基本计数器设置(设置PWM频率) //频率=TIM1_CLK/(ARR+1)
  112.         /* Channel 1, 2,3 and 4 Configuration in PWM mode */
  113.         TIM1_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2;
  114.         TIM1_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  115.         TIM1_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable;
  116.         TIM1_OCInitStructure.TIM_Pulse = 0x0;
  117.         TIM1_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;
  118.         TIM1_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_Low;
  119.         TIM1_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set;
  120.         TIM1_OCInitStructure.TIM_OCNIdleState = TIM_OCIdleState_Reset;
  121.
  122.         TIM_OC1Init(TIM1,&TIM1_OCInitStructure);          //同TimeBaseStructure        (8个参数)        //TIM1_OC1模块设置(设置1通道占空比)
  123.
  124.         TIM1_OCInitStructure.TIM_Pulse = 0x7fff;
  125.         TIM_OC2Init(TIM1,&TIM1_OCInitStructure);         //同TimeBaseStructure
  126.
  127.         TIM1_OCInitStructure.TIM_Pulse = 0x0;
  128.         TIM_OC3Init(TIM1,&TIM1_OCInitStructure);         //同TimeBaseStructure
  129.
  130.         TIM1_OCInitStructure.TIM_Pulse = 0x7fff;
  131.         TIM_OC4Init(TIM1,&TIM1_OCInitStructure);         //同TimeBaseStructure
  132.
  133.         TIM_Cmd(TIM1,ENABLE);                  //先设置好了TimeBase、OC、BDTR  使能或者失能TIM1外设
  134.
  135.         /* Main Output Enable */
  136.         TIM_CtrlPWMOutputs(TIM1,DISABLE);        //TIM1_CtrlPWMOutputs(ENABLE); 使能或者失能TIM1的主输出
  137. }
  138. void zhi1(void)                //直走速度1
  139. {
  140.         TIM_SetCompare1(TIM1,TIM1Compare1[0]);
  141.         TIM_SetCompare2(TIM1,TIM1Compare2[0]);
  142.         TIM_SetCompare3(TIM1,TIM1Compare3[0]);
  143.         TIM_SetCompare4(TIM1,TIM1Compare4[0]);
  144.         TIM_CtrlPWMOutputs(TIM1,ENABLE);
  145. }
  146. void zhi2(void)                //直走速度2(慢)
  147. {
  148.         TIM_SetCompare1(TIM1,TIM1Compare1[0]);
  149.         TIM_SetCompare2(TIM1,TIM1Compare2[1]);
  150.         TIM_SetCompare3(TIM1,TIM1Compare3[0]);
  151.         TIM_SetCompare4(TIM1,TIM1Compare4[1]);
  152.         TIM_CtrlPWMOutputs(TIM1,ENABLE);
  153. }
  154. void zhi(void)                //直走速度3(很慢)
  155. {
  156.         TIM_SetCompare1(TIM1,TIM1Compare1[0]);
  157.         TIM_SetCompare2(TIM1,TIM1Compare2[2]);
  158.         TIM_SetCompare3(TIM1,TIM1Compare3[0]);
  159.         TIM_SetCompare4(TIM1,TIM1Compare4[2]);
  160.         TIM_CtrlPWMOutputs(TIM1,ENABLE);
  161. }
  162. void zuoxiao(void)                   //左小转
  163. {
  164.         TIM_SetCompare1(TIM1,TIM1Compare1[0]);
  165.         TIM_SetCompare2(TIM1,TIM1Compare2[1]);
  166.         TIM_SetCompare3(TIM1,TIM1Compare3[0]);
  167.         TIM_SetCompare4(TIM1,TIM1Compare4[0]);
  168.         TIM_CtrlPWMOutputs(TIM1,ENABLE);
  169. }
  170. void zuoda(void)                   //左大转
  171. {
  172.         TIM_SetCompare1(TIM1,TIM1Compare1[0]);
  173.         TIM_SetCompare2(TIM1,0);
  174.         TIM_SetCompare3(TIM1,TIM1Compare3[0]);
  175.         TIM_SetCompare4(TIM1,TIM1Compare4[0]);
  176.         TIM_CtrlPWMOutputs(TIM1,ENABLE);
  177. }
  178. void youxiao(void)                   //右小转
  179. {
  180.         TIM_SetCompare1(TIM1,TIM1Compare1[0]);
  181.         TIM_SetCompare2(TIM1,TIM1Compare2[1]);
  182.         TIM_SetCompare3(TIM1,TIM1Compare3[0]);
  183.         TIM_SetCompare4(TIM1,TIM1Compare4[0]);
  184.         TIM_CtrlPWMOutputs(TIM1,ENABLE);
  185. }
  186. void youda(void)                   //右大转
  187. {
  188.         TIM_SetCompare1(TIM1,TIM1Compare1[0]);
  189.         TIM_SetCompare2(TIM1,0);
  190.         TIM_SetCompare3(TIM1,TIM1Compare3[0]);
  191.         TIM_SetCompare4(TIM1,TIM1Compare4[0]);
  192.         TIM_CtrlPWMOutputs(TIM1,ENABLE);
  193. }
  194. void xunji(void)                           //循迹
  195. {
  196.         zhi1();
  197.         if(GPIO_ReadInputDataBit(GPIOC, GPIO_Pin_7)) youxiao();
  198.         if(GPIO_ReadInputDataBit(GPIOC, GPIO_Pin_8)) zuoxiao();
  199.         if(1)
  200.         {
  201.                 tubecnt++;
  202.                 zhi1();
  203.                 delay_ms(100);
  204.                 zuoda();
  205.                 delay_ms(100);
  206.         }
  207.
  208. }
  209. u16 ceju(void)
  210. {
  211.         u16 juli;
  212.         flag=0;
  213.         GPIO_SetBits( GPIOB, GPIO_Pin_9);
  214.         TIM_Cmd(TIM2,ENABLE);
  215.         while(juli==0);
  216.         juli=add*3.4;;
  217.         flag=0;
  218.         return juli;
  219. }
  220. void tim2_Configuration(void)
  221. {
  222.         TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
  223.         RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2|RCC_APB1Periph_TIM3, ENABLE);
  224.
  225. ……………………
  226. …………限于本文篇幅 余下代码请从51黑下载附件…………
STM32_小车_V1.zip (3.82 MB, 下载次数: 1086)
参与人数 12黑币 +83 收起 理由
薛易 + 4 淡定,想要一个51的。
__myth丶 + 4 很给力!
无敌的小黑 + 5 很给力!
非你不爱 + 5 绝世好帖!
123321123456 + 5
HEY1800 + 5 赞一个!
夜斗 + 5
yanyuwei + 30 绝世好帖!
wifirr + 5 很给力!
120057815 + 5 很给力!
362618281 + 5 很给力!
五元人民币 + 5 绝世好帖!
收藏收藏17 分享淘帖 顶15 踩
ID:199956 发表于 2017-5-12 21:53 | 只看该作者
谢谢楼主
ID:223338 发表于 2017-7-30 11:10 | 只看该作者
感谢楼主。。
ID:224558 发表于 2017-8-3 23:43 | 只看该作者
感谢楼主
ID:219788 发表于 2017-8-7 21:42 | 只看该作者
十分感谢!!!限于本文篇幅 余下代码请从51黑下载附件
ID:232175 发表于 2017-9-10 03:07 | 只看该作者
ID:235574 发表于 2017-9-25 19:54 | 只看该作者
非常好,十分有用
ID:87193 发表于 2017-9-27 10:39 | 只看该作者
具体的介绍多一点就好了,都不知道是不是自己在找的相关的
ID:238823 发表于 2017-10-12 11:41 | 只看该作者
感谢楼主
ID:234976 发表于 2017-10-18 20:12 | 只看该作者
确定没有问题吗?上传的文件不是最终的吧
ID:118238 发表于 2018-1-25 21:12 | 只看该作者
谢谢您的热心分享
ID:294445 发表于 2018-3-20 12:31 | 只看该作者
感谢,学习一下
ID:305235 发表于 2018-4-10 16:14 | 只看该作者
谢谢楼主
ID:317918 发表于 2018-4-27 17:02 | 只看该作者
感谢大大
ID:320677 发表于 2018-5-2 18:50 | 只看该作者
请问这些都需要用什么软件打开啊
ID:319662 发表于 2018-5-2 22:11 | 只看该作者
哎呀积分不够,先回复一下吧哈哈哈
ID:322018 发表于 2018-5-7 13:53 | 只看该作者
感谢楼主
ID:260557 发表于 2018-5-10 17:04 | 只看该作者
赞一个!
ID:332603 发表于 2018-5-17 22:58 | 只看该作者
感谢楼主
ID:225778 发表于 2018-5-19 16:46 | 只看该作者
正在学习,我试试行不行!
ID:225778 发表于 2018-5-19 16:47 | 只看该作者
多谢楼主
ID:325299 发表于 2018-5-20 09:40 | 只看该作者
试过了,很好!
ID:334594 发表于 2018-5-21 07:56 | 只看该作者
十分感谢,太厉害了
ID:335527 发表于 2018-5-22 11:27 | 只看该作者
.....按时间肯定会
ID:325548 发表于 2018-5-25 21:51 | 只看该作者
感谢楼楼
ID:340165 发表于 2018-5-28 21:59 | 只看该作者
谢谢楼主
ID:333890 发表于 2018-5-29 17:46 | 只看该作者
厉害喽,很给力
ID:292722 发表于 2018-6-29 08:39 | 只看该作者
很好的帖子,对自己的实验有很大帮助。
ID:366693 发表于 2018-7-8 09:22 | 只看该作者
好贴,谢谢!!!
ID:370530 发表于 2018-7-12 21:31 | 只看该作者
感谢楼主
ID:371003 发表于 2018-7-13 16:52 | 只看该作者
感谢感谢 谢谢
ID:372097 发表于 2018-7-15 18:26 | 只看该作者
感谢楼主
ID:371571 发表于 2018-7-16 15:49 | 只看该作者
虽然不知道说什么,但很棒
ID:371571 发表于 2018-7-16 15:50 | 只看该作者
虽然不知道说什么,但很棒,很有用
ID:373360 发表于 2018-7-17 15:53 | 只看该作者
谢谢楼主很给力
ID:374176 发表于 2018-7-18 16:06 | 只看该作者
妈耶,看着挺牛逼的,就是看不咋懂
ID:379921 发表于 2018-8-4 10:34 | 只看该作者
为什么我打开编译报错了呢,请问怎么办呢
ID:384238 发表于 2018-8-8 15:47 | 只看该作者
谢谢楼主
ID:209158 发表于 2018-8-11 09:03 | 只看该作者
感谢楼主分享
ID:383648 发表于 2018-8-19 10:18 | 只看该作者
x452044339 发表于 2018-5-2 18:50
请问这些都需要用什么软件打开啊
一个叫keil5的
