蜂鸣器。。有用的
仿真原理图如下(proteus仿真工程文件可到本帖附件中下载):
- #include <reg52.h>
- #include <intrins.h>
- #define uchar unsigned char
- #define uint unsigned int
- #define NOP4() {_nop_();_nop_();_nop_();_nop_();}
- sbit SCL = P1^0;
- sbit SDA = P1^1;
- sbit SPK = P3^0;
- uchar code HI_LIST[] =
- 0,226,229,232,233,236,238,240,241,242,245,246,247,248
- uchar code LO_LIST[] =
- 0,4,13,10,20,3,8,6,2,23,5,26,1,4,3
- uchar code Song_24C04[] =
- 1,2,3,1,1,2,3,1,3,4,5,3,4,5
- uchar sidx;
- void DelayMS(uint x)
- uchar t;
- while(x--)
- for(t=120;t>0;t--);
- void Start()
- SDA=1;SCL=1;NOP4();SDA=0;NOP4();SCL=0;
- void Stop()
- SDA=0;SCL=0;NOP4();SCL=1;NOP4();SDA=1;
- void RACK()
- SDA=1;NOP4();SCL=1;NOP4();SCL=0;
- void NO_ACK()
- SDA=1;SCL=1;NOP4();SCL=0;SDA=0;
- void Write_A_Byte(uchar b)
- uchar i;
- for(i=0;i<8;i++)
- b<<=1;SDA=CY;_nop_();SCL=1;NOP4();SCL=0;
- RACK();
- void Write_IIC(uchar addr,uchar dat)
- Start();
- Write_A_Byte(0xa0);
- Write_A_Byte(addr);
- Write_A_Byte(dat);
- Stop();
- DelayMS(10);
- uchar Read_A_Byte()
- uchar i,b;
- for(i=0;i<8;i++)
- SCL=1;b<<=1;B|=SDA;SCL=0;
- return b;
- uchar Read_Current()
- uchar d;
- Start();
- Write_A_Byte(0xa1);
- d=Read_A_Byte();
- NO_ACK();
- Stop();
- return d;
- uchar Random_Read(uchar addr)
- Start();
- Stop();
- return Read_Current();
- void T0_INT() interrupt 1
- SPK=!SPK;
- TH0=HI_LIST[sidx];
- TL0=LO_LIST[sidx];
- void main()
- uchar i;
05 IIC-24C04与蜂鸣器.zip
(36.1 KB, 下载次数: 25)
