查看: 2837|回复: 1
51单片机计算器
#include <reg52.H>
#include <intrins.h>
#include <lcd_drive.h>
#define        uchar        unsigned char
#define uint        unsigned int
void delayms(unsigned int x)
  unsigned char i;
while(x--)
   for(i = 0;i < 120;i++);
uint key()
        uchar h = 0,l = 0;//???h,?l
        uchar j_p;
        P1 = 0x0f;
        if(P1 != 0x0f)
                delayms( 2 );
                if(P1!=0x0f)
                        l = P1 & 0x0f        ;
                        P1 = 0xf0;
                        h = P1 & 0xf0;
        switch(l | h)
                case 0x7e:j_p=0;break;                //??0
                case 0x7d:j_p=1;break;                //??1
                case 0x7b:j_p=2;break;                //??2
                case 0x77:j_p=3;break;                //??3
                case 0xbe:j_p=4;break;                //??4
                case 0xbd:j_p=5;break;                //??5
                case 0xbb:j_p=6;break;                //??6
                case 0xb7:j_p=7;break;                //??7
                case 0xde:j_p=8;break;                //??8
                case 0xdd:j_p=9;break;                //??9
                case 0xdb:j_p='+';break;        //??a
                case 0xd7:j_p='-';break;        //??b
                case 0xee:j_p='=';break;        //??Enter
                case 0xed:j_p='*';break;        //??c
                case 0xeb:j_p='/';break;        //??e
                case 0xe7:j_p='c';break;        //????
                default:return -1;break;
        P1=0x0f;
        while(P1!=0x0f);
        return j_p;
void deplay(uchar j_p)
        if(j_p != -1)
                if(j_p >= 0 && j_p <= 9)
                        j_p+=48;
lcd_wdat(j_p);
void deplay_s(long a)
        int n[10];
        uint i=0;
        while(a)
                n[i]=a%10;
                a/=10;
                i++;
        while(i)
                deplay(n[--i]);
        uint key();
        void deplay(uchar j_p);
        void deplay_s(long a);
        uchar i=1;
        uchar jp=-1;
        uchar flat;
        uint  a,b;
        delayms(10);
        lcd_init();
        lcd_clr();
        lcd_wcmd(0x80);
                while(jp==-1)
                        jp=key();
                deplay(jp);
                switch (jp)
                        case '=':        switch(flat)
                                                        case '+':  a+=b;  deplay_s(a);   break;
                                                        case '-':  a=b-a; deplay_s(a);  break;
                                                        case '*':  a*=b;  deplay_s(a);   break;
                                                        case '/':  a=b/a; deplay_s(a);  break;
                                                        default:break;
                                                break;
                        case '+':flat='+';b=a;i=0;break;
                        case '-':flat='-';b=a;i=0;break;
                        case '*':flat='*';b=a;i=0;break;
                        case '/':flat='/';b=a;i=0;break;
                        case 'c':a=0;b=0;lcd_clr();break;
                        case 0:
                        case 1:
                        case 2:
                        case 3:
                        case 4:
                        case 5:
                        case 6:
                        case 7:
                        case 8:
                        case 9:a=a*10*i+jp;i=1;break;
                jp=-1;
计算器
计算器
收藏收藏 分享淘帖 顶1 踩
