- #include"reg52.h"
- #include"intrins.h"
- sbit add=P1^0;
- sbit dec=P1^1;
- sbit key=P3^2;
- #define uchar unsigned char
- #define uint unsigned int
- int tab[6],x,y,z,n,a,b,c,o;
- void delay20ms(void) //软件延时子程序
- unsigned char i,j;
- for(i=0;i<100;i++)
- for(j=0;j<60;j++)
- uchar code SEG[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
- void delay()
- {uint i;
- for(i=0;i<500;i++);
- void chaifen()
- tab[0]=x%10;
- tab[1]=x/10;
- tab[2]=y%10;
- tab[3]=y/10;
- tab[4]=z%10;
- tab[5]=z/10;
- void main()
- TMOD=0x01;
- TH0=0x3c;
- TL0=0xb0;
- EA=1;
- EX0=1;
- PX0=1;
- TR0=1;
- ET0=1;
- n=0;
- x=0;
- y=0;
- z=0;
- chaifen();
- while(1)
- uchar i;
- P2=0x40;
- for(i=0;i<6;i++)
- P2=_cror_(P2,1);
- P0=SEG[tab[i]];
- delay();
- void wai() interrupt 0
- while(!key)
- a=x;
- b=y;
- c=z;
- if (add==0)
- delay20ms();
- while(add==0);
- a++;
- else if(dec==0)
- delay20ms();
- while(dec==0);
- a--;
- x=a;
- y=b;
- z=c;
- if(x==(60))
- x=0;
- y++;
- if(y==(60))
- y=0;
- z++;
- if(z==(24))
- {z=0;}
- if(x==(-1))
- x=59;
- y--;
- if(y==(-1))
- y=59;
- z--;
- if(z==(-1))
- {z=23;}
- P2=0x40;
- for(o=0;o<6;o++)
- P2=_cror_(P2,1);
- P0=SEG[tab[o]];
- delay();
- chaifen();
- void timer() interrupt 1
- n++;
- if(n==10)
- n=0;
- x--;
- if(x==(-1))
- x=59;
- y--;
- if(y==(-1))
- y=59;
- z--;
- if(z==(-1))
- {z=23;}
- chaifen();
- TH0=0x3c;
- TL0=0xb0;
复制代码 |
