查看: 2992|回复: 1
我做的无线WIFI除尘系统的程序
这是我做的无线WIFI除尘系统的程序
51单片机主程序源程序如下:
  1. #include "lcd1602.h"
  2. #include "reg52.h"
  3. #include "intrins.h"
  4. #include "stdio.h"
  5. #include "delay.h"
  6. #include "key.h"
  7. #include "DJ.h"
  8. sbit JIASHI = P3^7;
  9. sbit led_lv = P1^6;
  10. sbit led_red = P1^5;
  11. extern void ReadHumidityTemperature(void);
  12. extern unsigned char data  byHumidityValue,byTemperatureValue;
  13. extern uchar flag_zheng,flag_fan,flag_left,flag_right,flag_jia,flag_jian,flag_stop,flag_start,flag_jiashiqi,speed;//电机使用变量和标志位
  14. unsigned char data dis1[16] = {"RH:    TEMP:   C"};
  15. uchar down_data=75,up_data=80;
  16. uint DAT = 0;
  17. uchar num=0;
  18. uchar count=0;//电机使用变量
  19. void tmod_init()
  20. {
  21.         TMOD = 0X11;
  22.         TH1 = (65536-100)/256;
  23.         TL1 = (65536-100)%256;
  24.         TH0 = (65536-100)/256;
  25.         TL0 = (65536-100)%256;
  26.         EA = 1;
  27.         ET1 = 1;
  28.         TR1 = 1;
  29.         ET0 = 1;
  30.         TR0 = 1;
  31. }
  32. void Delay1000ms()                //@12.000MHz
  33. {
  34.         unsigned char i, j, k;
  35.         i = 46;
  36.         j = 153;
  37.         k = 245;
  38.         do
  39.         {
  40.                 do
  41.                 {
  42.                         while (--k);
  43.                 } while (--j);
  44.         } while (--i);
  45. }
  46. void adjust()
  47. {
  48.
  49.             if(byHumidityValue<down_data)  //灯和加湿器都是低电平有效
  50.                 {
  51.                         JIASHI = 0;  //打开
  52.                         led_red = 0;   //打开
  53.                         led_lv = 1;
  54.                 }
  55.                 else if(byHumidityValue>up_data)
  56.                 {
  57.                         JIASHI = 1;
  58.                         led_lv = 1;
  59.                         led_red = 0;
  60.                 }
  61.                 else if((byHumidityValue>=down_data)&&(byHumidityValue<=up_data))
  62.                 {
  63.                       led_lv = 0;
  64.                         led_red = 1;
  65.             }
  66.                 else if(flag_jiashiqi==1)          JIASHI = 0;
  67.                 else if(flag_jiashiqi==0)  JIASHI = 1;
  68. }
  69. void main()
  70. {
  71.         float dat=0;
  72.         lcd_init();
  73.         tmod_init();
  74.         dis1[14]=0xDF;
  75.           while(1)
  76.         {
  77.             ReadHumidityTemperature();
  78.                   LCD_Write_String(0,0,dis1);
  79.                 adjust();
  80.                 Delay1000ms();
  81.   }
  82. }
  83. void t0_interrupt() interrupt 1
  84. {
  85.           TH0 = (65536-10000)/256;
  86.         TL0 = (65536-10000)%256;
  87.         keyscan();
  88. }
  89. void t1_interrupt() interrupt 3
  90. {
  91.         TH1 = (65536-100)/256;
  92.         TL1 = (65536-100)%256;
  93.
  94.         if(flag_zheng==1)//ZHENG
  95.         {
  96.                         IN2=0;
  97.                           IN4=0;
  98.                         if(count==speed) {IN1=1;IN3=1;}
  99.                         if(count==100) {count=0;IN1=0;IN3=0;}
  100.           }
  101.         else if(flag_fan==1)//FAN
  102.         {
  103.                         //flag_zheng=0;
  104.                         IN1=0;
  105.                           IN3=0;
  106.                         if(count==speed) {IN2=1;IN4=1;}
  107.                         if(count==100) {count=0;IN2=0;IN4=0;}
  108.   }
  109.
  110.         else if(flag_stop == 1)//TING
  111.         {
  112.                         IN1=0;
  113.                     IN2=0;
  114.                           IN3=0;
  115.                           IN4=0;
  116.   }
  117.
  118.         else if(flag_left == 1)//ZUO ZHUAN
  119.         {
  120.
  121.                           IN2=0;        IN4=0;
  122.                         if(speed>=70) speed = 60;
  123. ……………………
  124. …………限于本文篇幅 余下代码请从51黑下载附件…………
WiFi除尘.zip (84.47 KB, 下载次数: 9)
ID:1 发表于 2017-7-4 01:46 | 只看该作者
WIFI除尘是个什么概念啊
