ADXL363引脚图如下:
ADXL363管脚功能:
功能框图:
GENERAL DESCRIPTION
The ADXL363 is an ultralow power, three-sensor combination consisting of a 3-axis MEMS accelerometer, a temperature sensor, and an on-board ADC input for synchronous conversion of an external signal. The entire system consumes less than 2 µA at a 100 Hz output data rate and 270 nA when in motion triggered wake-up mode.
The ADXL363 communicates via a serial port interface (SPI) and always provides 12-bit output resolution for all three
sensors. The ADXL363 accelerometer provides selectable measurement
ranges of ±2 g, ±4 g, and ±8 g, with a resolution of 1 mg/LSB on the ±2 g range. Unlike accelerometers that use power duty
cycling to achieve low power consumption, the ADXL363 does not alias input signals by undersampling; it samples the full bandwidth of the sensor at all data rates.
The ADXL363 temperature sensor operates with a scale factor of 0.065°C (typical). Acceleration and temperature data can be stored in a 512-sample multimode FIFO buffer, allowing up to 13 sec of data to be stored.
In addition to the accelerometer and temperature sensor, the ADXL363 also provides access to an internal ADC for synchronous conversion of an additional analog input.
The ADXL363 operates on a wide 1.6 V to 3.5 V supply range, and can interface, if necessary, to a host operating on a separate, lower supply voltage. The ADXL363 is available in a 3 mm × 3.25 mm × 1.06 mm package.
ADXL363数据手册下载:
ADXL363.pdf
(1.84 MB, 下载次数: 6)
