查看: 3695|回复: 0
用51单片机做的计算器跟密码锁
我用ad软件画了原理图跟pcb图,并且利用手头资源做了出来,现在把这个给大家拿出来共享,因为我是学硬件的,所以软件编程不是太好,程序都是自己打的,但是没用到中断跟延时。望各位大神给指点程序的改进之处。
下面是程序
下面是初始界面跟计算器还有密码锁的图片
  1. #include<reg52.h>
  2. #include<stdio.h>
  3. #include"1602.h"
  4. #include"delay.h"
  5. #include"keyboard.h"
  6. sbit key1=P3^0;
  7. sbit key2=P3^1;
  8. unsigned char code password[]={'1','2','3','4','5','6','7','8'};//可以更改此密码做多组测试
  9. //定义密码,实际上密码需要存在eeprom中,可以通过程序更改。
  10. unsigned char code cg_1602[]={ 0x08,0x0f,0x12,0x0f,0x0a,0x1f,0x02,0x02,
  11. 0x0f,0x09,0x0f,0x09,0x0f,0x09,0x11,0x00,
  12. 0x0f,0x09,0x09,0x0f,0x09,0x09,0x0f,0x00,
  13. 0x1f,0x04,0x04,0x0e,0x04,0x04,0x04,0x1f,
  14. 0x0a,0x1f,0x0a,0x1f,0x02,0x04,0x09,0x1f,
  15. 0x00,0x1b,0x1b,0x00,0x11,0x1b,0x0e,0x04};//"年月日王艺xiaolian"
  16. /*------------------------------------------------
  17.                     主程序
  18. ------------------------------------------------*/
  19. main()
  20. {
  21. unsigned char num,i,j;
  22. unsigned char passwordtemp[16];        //最大输入16个
  23. unsigned char inputtimes;              //密码输入错误次数
  24. unsigned char passwordlength,PLEN=8;     //输入密码长度,实际密码长度
  25. unsigned char q,p,sign;
  26. unsigned char temp[16];   //最大输入16个
  27. unsigned char s,num1;
  28. float a=0,b=0;
  29. bit firstflag;
  30. bit Flag;
  31. LCD_Init();         //初始化液晶屏
  32. DelayMs(10);        //延时用于稳定,可以去掉
  33. LCD_Clear();        //清屏
  34. LCD_Write_Com(0x40); //设定CGRAM地址
  35.         for(num1=0;num1<48;num1++) //将自定义字型码写入CGRAM中
  36.         {
  37.                 LCD_Write_Data(cg_1602[num1]);
  38.         }
  39.                 LCD_Write_Com(0x82);//年
  40.         {
  41.                 LCD_Write_Data(0);
  42.         }
  43.                 LCD_Write_Com(0x85);//月
  44.         {
  45.                 LCD_Write_Data(1);
  46.         }
  47.                 LCD_Write_Com(0x88);//日
  48.         {
  49.                 LCD_Write_Data(2);
  50.         }
  51.                 LCD_Write_Com(0x8a);//王
  52.         {
  53.                 LCD_Write_Data(3);
  54.         }
  55.                 LCD_Write_Com(0x8b);//艺
  56.         {
  57.                 LCD_Write_Data(4);
  58.         }
  59.                 LCD_Write_Com(0x89);//
  60.         {
  61.                 LCD_Write_Data(5);
  62.         }
  63.          LCD_Write_String(0,0,"17");
  64.          LCD_Write_String(3,0,"11");
  65.          LCD_Write_String(6,0,"19");
  66.          LCD_Write_String(12,0,"Chao");
  67.          LCD_Write_String(1,1,"Welcome to YOU");
  68.         for(s=0;s<5;s++)//延时5s
  69.             DelayMs(500);
  70.                  LCD_Write_Com(0x01);
  71. if(key1==0)
  72. {  LCD_Init();         //初始化液晶屏
  73. DelayMs(10);        //延时用于稳定,可以去掉
  74. LCD_Clear();        //清屏
  75. LCD_Write_String(0,0,"I LIKE MCU");    //写入第一行信息,主循环中不再更改此信息,所以在while之前写入
  76. LCD_Write_String(0,1,"Tian He Number 1");    //写入第二行信息,提示输入密码    //写入第二行信息,提示输入密码
  77. for(s=0;s<25;s++)//延时5s
  78.     DelayMs(200);
  79. LCD_Write_Com(0x01);
  80. while (1)         //主循环
  81.   {
  82. q=KeyPro();  //扫描键盘
  83. if(q!=0xff)  //如果扫描是按键有效值则进行处理
  84.    {
  85.     if(p==0)    //输入是第一个字符的时候需要把改行清空,方便观看
  86.    LCD_Write_Com(0x01);
  87. if(('+'==q)|| (p==16) || ('-'==q) || ('x'==q)|| ('/'==q) || ('='==q))//输入数字最大值16,输入符号表示输入结束
  88.    {
  89.    p=0;  //计数器复位
  90.   if(firstflag==0)  //如果是输入的第一个数据,赋值给a,并把标志位置1,到下一个数据输入时可以跳转赋值给b
  91.       {
  92.       sscanf(temp,"%f",&a);
  93.          firstflag=1;
  94.    }
  95.    else
  96.       sscanf(temp,"%f",&b);
  97.    for(s=0;s<16;s++) //赋值完成后把缓冲区清零,防止下次输入影响结果
  98.       temp[s]=0;
  99.       LCD_Write_Char(0,1,q);
  100.    ///////////////////////
  101.    if(q!='=')      //判断当前符号位并做相应处理
  102.       sign=q;      //如果不是等号记下标志位
  103.    else
  104.       {
  105.    firstflag=0;   //检测到输入=号,判断上次读入的符合
  106.          switch(sign)
  107.         {
  108.       case '+':a=a+b;
  109.    break;
  110.    case '-':a=a-b;
  111.    break;
  112.    case 'x':a=a*b;
  113.    break;
  114.    case '/':a=a/b;
  115.    break;
  116.    default:break;
  117.      }
  118.    sprintf(temp,"%g",a);    //输出浮点型,无用的0不输出
  119.          LCD_Write_String(1,1,temp);//显示到液晶屏
  120.    sign=0;a=b=0;            //用完后所有数据清零
  121.    for(s=0;s<16;s++)
  122.       temp[s]=0;
  123.    }
  124.    }
  125.   else if(p<16)
  126.    {
  127.     if((1==p)&& (temp[0]=='0') )//如果第一个字符是0,判读第二个字符
  128.       {
  129.     if(q=='.')  //如果是小数点则正常输入,光标位置加1
  130.       {
  131.       temp[1]='.';
  132.    LCD_Write_Char(1,0,q);//输出数据
  133.    p++;
  134.             } //这里没有判断连续按小数点,如0.0.0
  135.    else
  136.     {
  137.      temp[0]=q; //如果是1-9数字,说明0没有用,则直接替换第一位0
  138.      LCD_Write_Char(0,0,q);//输出数据
  139.      }
  140.    }
  141.     else
  142.       {
  143.          temp[p]=q;
  144.          LCD_Write_Char(p,0,q);//输出数据
  145.       p++;   //输入数值累加
  146.    }
  147.     }
  148.     }
  149.   }
  150. }
  151. else if(key2==0)
  152. {
  153. PLEN=sizeof(password)/sizeof(password[0]);//用于计算出实际密码长度
  154. LCD_Init();         //初始化液晶屏
  155. DelayMs(10);        //延时用于稳定,可以去掉
  156. LCD_Clear();        //清屏
  157. LCD_Write_String(0,0,"  Welcome! ");    //写入第一行信息,主循环中不再更改此信息,所以在while之前写入
  158. LCD_Write_String(0,1,"Input password!");
  159. //写入第二行信息,提示输入密码
  160. while (1)         //主循环
  161.   {
  162. num=KeyPro();  //扫描键盘
  163. if(num!=0xff)  //如果扫描是按键有效值则进行处理
  164.    {
  165.     if(i==0)    //输入是第一个字符的时候需要把改行清空,方便观看密码
  166.           LCD_Write_String(0,1,"                ");//清除该行
  167.         if(i<16)
  168.           {
  169.        passwordtemp[i]=num;
  170.        LCD_Write_Char(i,1,'*');//输入的密码用"*"代替
  171.            }
  172.         i++;   //输入数值累加
  173.         if(('='==num)|| (i==16))//输入按键值15或者密码输入到最大值16,表示输入结束,需要进行比对
  174.           {
  175.       passwordlength=i-1;  //计算输入密码长度
  176.           i=0;  //计数器复位
  177.           if(passwordlength==PLEN)//长度相等则比较,否则直接输出错误
  178.             {
  179.              Flag=1;//先把比较位置1
  180.              for(j=0;j<PLEN;j++)//循环比较8个数值,如果有一个不等 则最终Flag值为0
  181.                 Flag=Flag&&(passwordtemp[j]==password[j]);//比较输入值和已有密码
  182.          }
  183.       if(Flag)//如果比较全部相同,标志位置1
  184.            {
  185.             LCD_Write_String(0,1,"                ");//清除该行
  186.         LCD_Write_String(0,1,"Right Open!>>>>");//密码正确显示的信息
  187.         inputtimes=0;//输入正确则次数清零,重新计数
  188.         Flag=0;      //清除正确标志
  189.                 }
  190.           else
  191.             {
  192.                 LCD_Write_String(0,1,"                ");//清除该行
  193.                 LCD_Write_String(0,1,"Wrong! Retry!");//密码错误,提示重新输入
  194.                 inputtimes++;//连续输入错误,则次数累加
  195.                 if(inputtimes==3)
  196.                   {
  197.                    LCD_Write_String(0,1,"                ");//清除该行
  198.                    LCD_Write_String(0,1,"Wrong 3 times!");//密码错误,提示重新输入
  199.                    while(1);//停止该位置,重启电源后才能输入,实际实用中则需要等到一定时间后才能再次输入。
  200.                   }
  201. …………
  202. …………
  203. …………限于本文篇幅 余下代码请从51黑下载附件…………
计算器.rar (976.86 KB, 下载次数: 13)
143-实用密码锁.rar (57.42 KB, 下载次数: 14)
