查看: 16792|回复: 20
智能小车黑线循迹实验程序
ID:229064 发表于 2017-8-24 08:21 | 只看该作者 回帖奖励 |正序浏览 |阅读模式
关于小车沿黑线循迹的程序!!!!!
  1. #include <reg52.h>                                    //包含52系统头文件
  2. #include "zncar.h"                                     //包含能小车头文件
  3. unsigned char pwmval_left   = 0;              //变量定义
  4. unsigned char pwmval_right  = 0;
  5. unsigned char pwmval_left_init  = 5;          //左电机占空比调节 ,调节值在0到20之间             此值越大,电机的转速越快
  6. unsigned char pwmval_right_init = 5;          //右电机占空比调节 ,调节值在0到20之间
  7. bit right_pwm = 1;                                    //右电机PWM开关,为1时打开
  8. bit left_pwm  = 1;                                            //左电机PWM开关,为1时打开
  9. void delay(int In,int Out)                    //定义延时函数
  10. {
  11. int i,j;
  12. for( i = 0;i < In;i++ )
  13. {
  14.   for( j = 0;j < Out;j++ )
  15.   {;}
  16. }
  17. }
  18. /**************************************************前进  左转   右转******************************************************************************/
  19. void forward(void)                                   //智能小车前进
  20. {
  21. IN1 = 0;
  22. IN2 = 1;                          //左车轮的正转
  23. IN3 = 0;
  24. IN4 = 1;                          //右车轮的正转
  25. }
  26. void left_turn(void)                       //智能小车左转
  27. {
  28. IN1 = 0;
  29. IN2 = 0;                          //左车轮停转
  30. IN3 = 0;
  31. IN4 = 1;                          //右车轮正转
  32. }
  33. void right_turn(void)                   //智能小车右转
  34. {
  35. IN1 = 0;
  36. IN2 = 1;                          //左车论的正转
  37. IN3 = 0;
  38. IN4 = 0;                          //右车轮停转
  39. }
  40. /****************************左电机控制函数********************************************/
  41. void left_moto(void)
  42. {
  43. if(left_pwm)
  44. {
  45.   if(pwmval_left <= pwmval_left_init)
  46.   {
  47.    EN1 = 1;
  48.   }
  49.   else
  50.   {
  51.    EN1 = 0;
  52.   }
  53.   if(pwmval_left >= 20)
  54.   {
  55.    pwmval_left = 0;
  56.   }
  57. }
  58. else
  59. {
  60.   EN1 = 0;
  61. }
  62. }
  63. /***************************右电机控制函数***************************************/
  64. void right_moto(void)
  65. {
  66. if(right_pwm)
  67. {
  68.   if(pwmval_right <= pwmval_right_init)
  69.   {
  70.    EN2 = 1;
  71.   }
  72.   else if(pwmval_right > pwmval_right_init)
  73.   {
  74.    EN2 = 0;
  75.   }
  76.   if(pwmval_right >= 20)
  77.   {
  78.    pwmval_right = 0;
  79.   }
  80. }
  81. else
  82. {
  83.   EN2 = 0;
  84. }
  85. }
  86.
  87. /**************单片机定时器0的中断处理函数***************/
  88. void timer0()interrupt 1 using 2
  89. {
  90. TH0 = 0xfc;                                      //1Ms定时
  91. TL0 = 0x66;
  92. pwmval_left  = pwmval_left  + 1;
  93. pwmval_right = pwmval_right + 1;
  94. left_moto();
  95. right_moto();
  96. }
  97. void keyscan(void)                         //按键扫描函数
  98. {
  99. loop:if(SWITCH_S7 == 0)                                  //判断是否有按下信号
  100.           {
  101.            delay(5,10);                                    //延时10ms
  102.            if(SWITCH_S7 == 0)                                 //再次判断是否按下
  103.            {
  104.             BEEP_IO = 0;                       //蜂鸣器响
  105.                 while(SWITCH_S7 == 0);                   //判断是否松开按键
  106.             BEEP_IO = 1;                       //蜂鸣器停止
  107.            }
  108.            else
  109.            {
  110.                 goto loop;                        //跳转到loop重新检测
  111.            }
  112.           }
  113.           else
  114.           {
  115.            goto loop;                        //跳转到loop重新检测
  116.           }
  117. }
  118. /******将定时器0设置成每隔1MS申请一次中断*********/
  119. void timer_init()
  120. {
  121. TMOD=0x01;
  122. TH0= 0xfc;                                  //1ms定时
  123. TL0= 0x66;
  124. TR0= 1;
  125. ET0= 1;
  126. EA = 1;                                                     //开总中断
  127. }
  128. //主函数
  129. void main(void)
  130. {
  131. P1 = 0x00;                                     //关电机
  132. keyscan();                                            //按键启动检测
  133. delay(100,1000);                               //1s后启动
  134. timer_init();        //调用定时器0的初始化函数
  135. while(1)                                            //无限循环
  136. {
  137.   //有信号为0  没有信号为1
  138. ……………………
  139. …………限于本文篇幅 余下代码请从51黑下载附件…………
7、智能小车黑线循迹实验.rar (31.03 KB, 下载次数: 151)
收藏收藏4 分享淘帖 顶 踩
ID:259955 发表于 2020-7-6 16:12 | 只看该作者
你好,有个问题请教一下,小车是怎么判断黑色的 ?
ID:789860 发表于 2020-6-25 23:02 | 只看该作者
感谢分享!!
ID:664199 发表于 2019-12-15 11:40 | 只看该作者
借用一下 大佬
ID:629701 发表于 2019-10-25 13:49 | 只看该作者
有问:楼主的电机是用的无刷电机?没有使用电机驱动模块?
ID:629701 发表于 2019-10-25 13:48 | 只看该作者
ARM的KEIL
ID:624645 发表于 2019-10-15 20:33 | 只看该作者
谢谢啊
ID:617434 发表于 2019-9-27 23:36 | 只看该作者
貌似不对啊,我咋编译不了?
ID:590918 发表于 2019-8-2 16:22 | 只看该作者
有帮助
ID:587564 发表于 2019-7-26 14:12 | 只看该作者
看了有很大帮助,谢谢
ID:588628 发表于 2019-7-23 12:50 | 只看该作者
用啥软件编程的
ID:575799 发表于 2019-7-2 14:16 | 只看该作者
51小车能用这个程序吗
ID:575799 发表于 2019-7-1 16:51 | 只看该作者
用什么软件编程呀
ID:467843 发表于 2019-4-5 14:08 | 只看该作者
郭文玲呀 发表于 2019-4-5 13:07
用的什么传感器啊
红外传感器
ID:473311 发表于 2019-4-5 13:07 | 只看该作者
用的什么传感器啊
ID:401857 发表于 2018-11-26 16:16 | 只看该作者
对我很有帮助‘’
ID:400569 发表于 2018-11-23 15:16 来自手机 | 只看该作者
解决了我的疑惑
ID:423048 发表于 2018-11-8 15:44 | 只看该作者
这个是什么意思啊
自动循迹小车程序.doc
24 KB, 下载次数: 14, 下载积分: 黑币 -5
ID:299036 发表于 2018-4-24 15:33 来自手机 | 只看该作者
看了有很大的帮助,谢谢
ID:254856 发表于 2018-1-27 15:15 | 只看该作者
谢谢啊
ID:246031 发表于 2017-11-21 13:22 | 只看该作者
这个有电路图吗???大佬
