单片机型号为stc12c5a60s2温度传感器为DS18B20
无线传输为NRF24L01
温度显示LCD1602
- #include <STC12C5A60S2.H>
- #include <stdio.h>
- #include "DELAY.h"
- #include "NRF24L01.h"
- #include "LCD1602.h"
- #include "DS18B20.h"
- void main(void)
- int temp,intt,dect;
- unsigned char temp_buf[16]={0};
- EA=1;
- LCD_Init(); //LCD1602初始化
- Start18B20(); //配置DS18B20
- P23=0;
- while(1)
- temp=Get18B20Temp(); //读取温度
- if(temp>0)
- intt=temp>>4; //分理出整数部分
- dect=temp&0xf; //分理出小数部分
- intt=intt*16*0.0625; //处理整数部分
- dect=(dect*10)/16; //处理小数部分
- sprintf(temp_buf,"Temp now:%2d.%d^C",intt,dect);//把温度转化为字符串temp_buf
- NRF24L01_Init_TX(0); //配置NRF24L01的通道0
- CE=0;
- SPI_Write_Reg(WRITE_REG + RF_CH,40); ////设置RF通道为40
- CE=1;
- nRF24L01_TxPacket(temp_buf); //发送temp_buf中数
- delay_ms(5);
- LCD_ShowString(0,0,"Mode:launching ");
- LCD_ShowString(1,0,temp_buf); //LCD1602显示温度
- delay_ms(5);
复制代码- #include <stc12c5a60s2.H>
- #include <intrins.h>
- #include "NRF24L01.H"
- uchar xdata RX_ADDRESS0[TX_ADR_WIDTH]={0x30,0xE6,0x45,0x82,0x7E}; //通道0地址
- uchar xdata RX_ADDRESS1[TX_ADR_WIDTH]={0xC2,0x49,0x49,0x49,0x49}; //通道1地址
- uchar xdata RX_ADDRESS2[TX_ADR_WIDTH]={0x94,0x49,0x49,0x49,0x49}; //通道2地址
- uchar xdata RX_ADDRESS3[TX_ADR_WIDTH]={0x33,0x49,0x49,0x49,0x49}; //通道3地址
- uchar xdata RX_ADDRESS4[TX_ADR_WIDTH]={0x00,0x49,0x49,0x49,0x49}; //通道4地址
- uchar xdata RX_ADDRESS5[TX_ADR_WIDTH]={0x24,0x49,0x49,0x49,0x49}; //通道5地址
- uchar xdata *pipe_add[6] = {RX_ADDRESS0,RX_ADDRESS1,RX_ADDRESS2,RX_ADDRESS3,RX_ADDRESS4,RX_ADDRESS5};//所有通道地址的集合
- /**********************************RNF24L01状态标志位************************************************/
- uchar bdata sta;
- sbit RX_DR =sta^6;
- sbit TX_DS =sta^5;
- sbit MAX_RT =sta^4;
- 函数名:毫秒级CPU延时函数
- 调 用:DELAY_MS (?);
- 参 数:1~65535(参数不可为0)
- 返回值:无
- 结 果:占用CPU方式延时与参数数值相同的毫秒时间
- 备 注:应用于1T单片机时i<600,应用于12T单片机时i<125
- void Delayms (uint a)
- uint i;
- while( --a != 0)
- for(i = 0; i < 600; i++);
- 函数名称:uchar SPI_RW(uchar dat)
- 函数功能:NRF24L01的SPI时序
- 函数备注:Writes one byte to nRF24L01, and return the byte read from nRF24L01 during write
- uchar SPI_RW(uchar dat)
- uchar i;
- for(i=8;i>0;i--)
- dat <<= 1;
- MOSI = CY;
- SCK = 1;
- dat |= MISO;
- SCK = 0;
- return(dat);
- 函数名称:uchar SPI_Read(uchar cmd_reg)
- 函数功能:NRF24L01的SPI读时序
- 函数备注:
- //uchar SPI_Read(uchar cmd_reg)
- // uchar value;
- // CSN = 0;
- // SPI_RW(cmd_reg);
- // value = SPI_RW(0);
- // CSN = 1;
- // return(value);
- 函数名称:void SPI_Write_Reg(uchar cmd_reg, uchar value)
- 函数功能:写入NRF24L01寄存器
- 函数备注:
- void SPI_Write_Reg(uchar cmd_reg, uchar value)
- CSN = 0;
- SPI_RW(cmd_reg);
- SPI_RW(value);
- CSN = 1;
- 函数名称:uchar SPI_Read_Buf(uchar cmd_reg, uchar *pBuf, uchar num)
- 函数功能:从NRF24L01寄存器中读出数据
- 函数备注:reg:为寄存器地址,pBuf:为待读出数据地址,uchar:读出数据的个数
- //uchar SPI_Read_Buf(uchar cmd_reg, uchar *pBuf, uchar num)
- // uchar status,i;
- // CSN = 0;
- // status = SPI_RW(cmd_reg);
- // for(i=0;i<num;i++)
- // pBuf[i] = SPI_RW(0);
- // CSN = 1;
- // return(status);
- 函数名称:void SPI_Write_Buf(uchar cmd_reg, uchar *pBuf, uchar num)
- 函数功能:在NRF24L01寄存器中写入数据
- 函数备注:reg:为寄存器地址,pBuf:为待写入数据地址,uchar:写入数据的个数
- void SPI_Write_Buf(uchar cmd_reg, uchar *pBuf, uchar num)
- uchar i;
- CSN = 0; //SPI使能
- SPI_RW(cmd_reg);
- for(i=0; i<num; i++)
- SPI_RW(*pBuf++);
- CSN = 1; //关闭SPI
- 函数名称:uchar nRF24L01_RxPacket(uchar* rx_buf)
- 函数功能:数据读取后放入rx_buf接收缓冲区中
- 函数备注:
- //uchar nRF24L01_RxPacket(uchar* rx_buf)
- // uchar flag;
- // CE = 1; //很重要!启动接收!
- // Delayms(1);
- // sta=SPI_Read(READ_REG+STATUS); // 读取状态寄存其来判断数据接收状况 //寄存器前面要加是读还是写
- // if(RX_DR) // 判断是否接收到数据 如果置1则说明接到数据并且放置在接收缓存器
- // CE = 0;
- // SPI_Read_Buf(RD_RX_PLOAD,rx_buf,RX_PLOAD_WIDTH); //这本来就是指令,不用加,意思说去缓存器里读
- // flag =1; //读取数据完成标志
- // SPI_Write_Reg(WRITE_REG+STATUS,sta); //接收到数据后RX_DR,TX_DS,MAX_PT都置高为1,通过写1来清除中断标志
- // return flag;
- 函数:Check_ACK(bit clear)
- 描述:检查接收设备有无接收到数据包,设定没有收到应答信
- 号是否重发
- uchar Check_ACK(bit clear)
- while(IRQ);
- sta = SPI_RW(NOP); // 返回状态寄存器
- if(MAX_RT)
- if(clear) // 是否清除TX FIFO,没有清除在复位MAX_RT中断标志后重发
- SPI_RW(FLUSH_TX); //清空寄存器,很重要!!!
- SPI_Write_Reg(WRITE_REG + STATUS, sta); // 清除TX_DS或MAX_RT中断标志
- IRQ = 1;
- if(TX_DS)
- return(0x01);
- else
- return(0x00);
- 函数名称:void nRF24L01_TxPacket(unsigned char * tx_buf)
- 函数功能:发送 tx_buf中数据
- 函数备注:
- uchar nRF24L01_TxPacket(uchar * tx_buf)
- uchar Return_Flag=0;
- CE=0; //StandBy I模式
- SPI_Write_Buf(WR_TX_PLOAD, tx_buf, TX_PLOAD_WIDTH); // 装载数据 WR_TX_PLOAD本来就是指令 不用加 将数据放入发送缓存器
- CE=1; //置高CE,激发数据发送
- Delayms(2);
- Return_Flag = Check_ACK(1);
- return Return_Flag;
- 函数名称:void NRF24L01_Init_TX(uchar pipe)
- 函数功能:初始化NRF24L01
- 函数备注:在调用NRF24L01作为发射时,都要先调用该函数对NRF24L01进行初始化
- void NRF24L01_Init_TX(uchar pipe)//输入通道值
- /*待机模式*/
- CE=0;
- CSN=1;
- SCK=0;
- /*装载数据*/
- SPI_Write_Buf(WRITE_REG + TX_ADDR, pipe_add[pipe], TX_ADR_WIDTH);//写TX节点地址
- SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, pipe_add[pipe], RX_ADR_WIDTH); //设置RX节点地址,主要为了使能ACK
- /*配置寄存器*/
- SPI_Write_Reg(WRITE_REG + EN_AA, 0x3F); //使能所有通道自动应答
- SPI_Write_Reg(WRITE_REG + EN_RXADDR, 0x3F);//使能所有通道的接收地址(这两项定义的通道数不得小于当前使用的通道数,奇怪的NRF24L01+(O__O "…))
- //SPI_Write_Reg(WRITE_REG + RF_CH, 40);//设置RF通道为40 收发必须一致!
- SPI_Write_Reg(WRITE_REG + SETUP_RETR, 0xFF);//自动重发 4000+86us 重发15次
- SPI_Write_Reg(WRITE_REG + RF_SETUP, 0x0F); //设置TX发射参数,0db增益,2Mbps,低噪声增益开启 收发必须一致!
- SPI_Write_Reg(WRITE_REG + CONFIG, 0x0E); //配置基本工作模式的参数;PWR_UP,EN_CRC,16BIT_CRC,发送模式,开启所有中断
- 函数名称:void NRF24L01_Init_RX(uchar pipe)
- 函数功能:初始化NRF24L01
- 函数备注:在调用NRF24L01作为接收时,都要先调用该函数对NRF24L01进行初始化
- //void NRF24L01_Init_RX(uchar pipe)//输入通道值
- // /*待机模式*/
- // CE=0;
- // CSN=1;
- // SCK=0;
- // /*装载数据*/
- // if(pipe == 0) //通道0或通道1,对应设置40位地址
- // SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, RX_ADDRESS0, RX_ADR_WIDTH); //设置RX节点地址,主要为了使能ACK
- // SPI_Write_Buf(WRITE_REG + (RX_ADDR_P0+pipe), RX_ADDRESS0+pipe, RX_ADR_WIDTH); //设置RX节点地址,主要为了使能ACK
- // else //其他通道,对应设置通道1公共地址和相应8位地址
- // SPI_Write_Buf(WRITE_REG + RX_ADDR_P1, RX_ADDRESS1, RX_ADR_WIDTH); //设置RX节点地址,主要为了使能ACK
- // SPI_Write_Buf(WRITE_REG + (RX_ADDR_P0+pipe), pipe_add[pipe], 1); //设置RX节点地址,主要为了使能ACK(地址长度只能是1,不能多写,写一样的值也不行)
- // /*配置寄存器*/
- // SPI_Write_Reg(WRITE_REG + EN_AA, 1<<pipe);//使能通道的自动应答
- // SPI_Write_Reg(WRITE_REG + EN_RXADDR, 1<<pipe); //使能通道的接收地址
- // //SPI_Write_Reg(WRITE_REG + RF_CH, 40); //设置RF通道为40 收发必须一致!
- // SPI_Write_Reg(WRITE_REG + (RX_PW_P0+pipe), RX_PLOAD_WIDTH); //选择通道的有效数据宽度
- // SPI_Write_Reg(WRITE_REG + RF_SETUP, 0x0F); //设置TX发射参数,0db增益,2Mbps,低噪声增益开启 收发必须一致!
- // SPI_Write_Reg(WRITE_REG + CONFIG, 0x0F); //配置基本工作模式的参数;PWR_UP,EN_CRC,16BIT_CRC,接收模式,开启所有中断
温度发送.zip
(124.49 KB, 下载次数: 138)
