查看: 1047|回复: 1
STMF103ZET6的在线IAP升级程序
ID:433305 发表于 2018-11-26 11:30 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  1. #include "led.h"
  2. #include "delay.h"
  3. #include "key.h"
  4. #include "sys.h"
  5. #include "lcd.h"
  6. #include "usart.h"
  7. #include "stmflash.h"
  8. #include "iap.h"
  9. int main(void)
  10. {
  11.         u8 t;
  12.         u8 key;
  13.         u16 oldcount=0;                                //老的串口接收数据值
  14.         u16 applenth=0;                                //接收到的app代码长度
  15.         u8 clearflag=0;
  16.         NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2); //设置NVIC中断分组2:2位抢占优先级,2位响应优先级
  17.         uart_init(115200);        //串口初始化为115200
  18.         delay_init();                            //延时初始化
  19.         LED_Init();                                          //初始化与LED连接的硬件接口
  20.         KEY_Init();                                        //初始化按键
  21.         LCD_Init();                                           //初始化LCD
  22.         POINT_COLOR=RED;//设置字体为红色
  23.         LCD_ShowString(30,50,200,16,16,"Warship STM32");
  24.         LCD_ShowString(30,70,200,16,16,"IAP TEST");
  25.         LCD_ShowString(30,90,200,16,16,"ATOM@ALIENTEK");
  26.         LCD_ShowString(30,110,200,16,16,"2015/1/27");
  27.         LCD_ShowString(30,130,200,16,16,"KEY_UP:Copy APP2FLASH");
  28.         LCD_ShowString(30,150,200,16,16,"KEY2:Erase SRAM APP");
  29.         LCD_ShowString(30,170,200,16,16,"KEY1:Run FLASH APP");
  30.         LCD_ShowString(30,190,200,16,16,"KEY0:Run SRAM APP");
  31.         POINT_COLOR=BLUE;
  32.         //显示提示信息
  33.         POINT_COLOR=BLUE;//设置字体为蓝色
  34.         while(1)
  35.         {
  36.                  if(USART_RX_CNT)
  37.                 {
  38.                         if(oldcount==USART_RX_CNT)//新周期内,没有收到任何数据,认为本次数据接收完成.
  39.                         {
  40.                                 applenth=USART_RX_CNT;
  41.                                 oldcount=0;
  42.                                 USART_RX_CNT=0;
  43.                                 printf("用户程序接收完成!\r\n");
  44.                                 printf("代码长度:%dBytes\r\n",applenth);
  45.                         }else oldcount=USART_RX_CNT;
  46.                 }
  47.                 t++;
  48.                 delay_ms(10);
  49.                 if(t==30)
  50.                 {
  51.                         LED0=!LED0;
  52.                         t=0;
  53.                         if(clearflag)
  54.                         {
  55.                                 clearflag--;
  56.                                 if(clearflag==0)LCD_Fill(30,210,240,210+16,WHITE);//清除显示
  57.                         }
  58.                 }
  59.                 key=KEY_Scan(0);
  60.                 if(key==WKUP_PRES)
  61.                 {
  62.                         if(applenth)
  63.                         {
  64.                                 printf("开始更新固件...\r\n");
  65.                                 LCD_ShowString(30,210,200,16,16,"Copying APP2FLASH...");
  66.                                 if(((*(vu32*)(0X20001000+4))&0xFF000000)==0x08000000)//判断是否为0X08XXXXXX.
  67.                                 {
  68.                                         iap_write_appbin(FLASH_APP1_ADDR,USART_RX_BUF,applenth);//更新FLASH代码
  69.                                         LCD_ShowString(30,210,200,16,16,"Copy APP Successed!!");
  70.                                         printf("固件更新完成!\r\n");
  71.                                 }else
  72.                                 {
  73.                                         LCD_ShowString(30,210,200,16,16,"Illegal FLASH APP!  ");
  74.                                         printf("非FLASH应用程序!\r\n");
  75.                                 }
  76.                         }else
  77.                         {
  78.                                 printf("没有可以更新的固件!\r\n");
  79.                                 LCD_ShowString(30,210,200,16,16,"No APP!");
  80.                         }
  81.                         clearflag=7;//标志更新了显示,并且设置7*300ms后清除显示
  82.                 }
  83.                 if(key==KEY2_PRES)
  84.                 {
  85.                         if(applenth)
  86.                         {
  87.                                 printf("固件清除完成!\r\n");
  88.                                 LCD_ShowString(30,210,200,16,16,"APP Erase Successed!");
  89.                                 applenth=0;
  90.                         }else
  91.                         {
  92.                                 printf("没有可以清除的固件!\r\n");
  93.                                 LCD_ShowString(30,210,200,16,16,"No APP!");
  94.                         }
  95.                         clearflag=7;//标志更新了显示,并且设置7*300ms后清除显示
  96.                 }
  97.                 if(key==KEY1_PRES)
  98.                 {
  99.                         printf("开始执行FLASH用户代码!!\r\n");
  100.                         if(((*(vu32*)(FLASH_APP1_ADDR+4))&0xFF000000)==0x08000000)//判断是否为0X08XXXXXX.
  101.                         {
  102.                                 iap_load_app(FLASH_APP1_ADDR);//执行FLASH APP代码
  103.                         }else
  104.                         {
  105.                                 printf("非FLASH应用程序,无法执行!\r\n");
  106.                                 LCD_ShowString(30,210,200,16,16,"Illegal FLASH APP!");
  107.                         }
  108.                         clearflag=7;//标志更新了显示,并且设置7*300ms后清除显示
  109.                 }
  110.                 if(key==KEY0_PRES)
  111.                 {
  112.                         printf("开始执行SRAM用户代码!!\r\n");
  113.                         if(((*(vu32*)(0X20001000+4))&0xFF000000)==0x20000000)//判断是否为0X20XXXXXX.
  114.                         {
  115.                                 iap_load_app(0X20001000);//SRAM地址
  116.                         }else
  117.                         {
  118.                                 printf("非SRAM应用程序,无法执行!\r\n");
  119.                                 LCD_ShowString(30,210,200,16,16,"Illegal SRAM APP!");
  120.                         }
  121.                         clearflag=7;//标志更新了显示,并且设置7*300ms后清除显示
  122.                 }
  123.
  124.         }
  125. }
实验47 串口IAP实验.rar (1.1 MB, 下载次数: 12)
收藏收藏1 分享淘帖 顶 踩
ID:396960 发表于 2018-12-7 09:12 | 只看该作者
最近在研究,谢谢分享
