52单片机驱动rc522读cpu卡资料包:
- #include "reg52.h"
- #include <string.h>
- #include <intrins.h>
- #include "main.h"
- #include "RC522.H"
- #include "12864.h"
- #include "uart.h"
- #include "FM1208.H"
- #include "psam.h"
- unsigned char Serial_Num[8]; //用户卡序列号
- unsigned char code S_KEY_1[8]={0x11,0x22,0x33,0x44,0x55,0x66,0x77,0x88}; //分散因子1(为自定义城市标识)
- unsigned char code S_KEY_2[8]={0x88,0x77,0x66,0x55,0x44,0x33,0x22,0x11}; //分散因子2(为自定义各成员银行标识)
- //////////////////文件标识的定义/////////////////////////////////////////////////////////////////////////////////
- //为统一方便管理阅读代码,我们在所有的文件名后面加个_Flag,表示就是该对应文件的标识//
- unsigned char code CZKey_Flag={0x01}; //圈存密钥标识为01
- unsigned char code DPKey_Flag={0x00}; //消费密钥标识为00
- unsigned char code DF_ExKey_Flag = {0x00}; //DF下的外部密钥标识00
- unsigned char code DF_Inital_Key_Flag = {0x00}; //DF下的内部密钥标识00
- unsigned char code FM1208_DF_0015_Flag[]={0x00,0x15}; //公共应用基本数据文件标识0015
- unsigned char code FM1208_DF_0016_Flag[]={0x00,0x16}; //持卡人基本信息数据的文件标识0016
- //文件标识
- unsigned char code File_3F00[] ={0x3f,0x00}; //MF下的文件标识3F00
- unsigned char code File_3F01[] ={0x3f,0x01}; //DF下的文件标识3F01
- unsigned char code File_0016={0x16}; //终端机短文件标识
- unsigned char Temporary_Key[8];
- unsigned char xdata Challenge_Num[8]; //随机数
- unsigned char code DateTime[]={0x20,0x16,0x10,0x26,0x11,0x32,0x45}; //交易时间,如果板子带有时钟芯片,可以把实时时间写入卡中。
- unsigned char xdata NameBuf[20]; //临时存放姓名
- unsigned char xdata NameLen; //姓名长度
- unsigned char code Purchase_Pay[4]={0x00,0x00,0x00,0x01}; //操作的金额 高位在前,16进制计算的,定额消费1元
- unsigned int xdata PAY;
- unsigned int xdata Pay_1 ;
- unsigned char xdata POSNum[6]; //终端机编号 从SAM卡中读取
- unsigned char xdata g_cSNR[4];
- unsigned char xdata DataBuf[MAXRLEN];
- unsigned char xdata g_cReceBuf[MAXRLEN];
- void NameToStr(char *s) //计算姓名的长度,及临时保存姓名
- char i;
- NameLen=strlen(s);
- for(i=0;i<NameLen;i++)
- NameBuf[i]=s[i];
- void CLRBuff()
- memset(g_cReceBuf, 0x00, MAXRLEN); //清0
- memset(DataBuf, 0x00, MAXRLEN);
- void Request_loop()
- s8 status,atq[2] ;
- while(1)
- status = PcdRequest(PICC_REQALL, atq);
- if(status != MI_OK)
- break;
- void main( )
- unsigned int xdata st;
- unsigned char xdata tt[2];
- unsigned char xdata i;
- unsigned char status;
- InitializeSystem( );
- DelayMs(200); //等待上电稳定
- UART_Init(); //串口初始化
- RC522_Init(); //RC522初始化 ,
- initial_LCD(); //显示屏初始化
- if(PSAMInit(g_cReceBuf)) //PSAM卡初始化
- UART_Send_Str("无PSAM卡,请插入PSAM卡!");
- UART_Send_Enter();
- while(1);
- UART_Send_Str("PSAM卡复位成功!");
- Dis_Deduct_Charge(0); //12864显示
- PcdAntennaOff();
- DelayMs(3);
- PcdAntennaOn();
- CLRBuff();
- while ( 1 )
- st =PcdRequest(PICC_REQALL, tt); //寻卡
- if(st){continue;}
- st =PcdAnticoll(g_cSNR);//防冲撞,
- if(st){continue;}
- st =PcdSelect(g_cSNR); //选择卡片
- if(st){continue;}
- if (pro_reset(g_cReceBuf,tt)!=MI_OK) //用户卡(CPU卡)复位,成功后才能往下操作//
- CLRBuff();
- continue;
- UART_Send_Str("用户卡复位成功!");
- CLRBuff();
- st=Sam_Select_File(File_3F00, 2, 0,g_cReceBuf, 0x28 ); //选择SAM卡中PBOC的3F00文件// 0x2E
- if(st!=SAM_OK)
- UART_Send_Str("SAM卡3F00文件打开错误:");
- UART_Put_Num(g_cReceBuf,2); //显示错误代码
- CLRBuff();
- Request_loop();
- continue;
- CLRBuff();
- st=Sam_ReadBinary( File_0016,g_cReceBuf, 6 ); //读取SAM卡里面的终端机编号//
- if(st!=SAM_OK)
- UART_Send_Str("SAM卡的终端机编号读取错误:");
- CLRBuff();
- Request_loop();
- continue;
- UART_Send_Str("终端机编号为:");
- memcpy(POSNum, g_cReceBuf, 6);
- UART_Put_Num(POSNum,6);
- CLRBuff();
- st=Sam_Select_File(File_3F01, 2, 0,g_cReceBuf, 0x27 ); //选择SAM卡中PBOC的3F01文件
- if(st!=SAM_OK)
- UART_Send_Str("SAM卡PBOC文件打开错误:");
- CLRBuff();
- Request_loop();
- continue;
- UART_Send_Str("SAM卡PBOC文件打开成功!");
- CLRBuff();
- st=FM1208_SelectFile(File_3F01,g_cReceBuf,tt); //打开CPU卡中PBOC的3F01文件//
- if(st!=0x9000)
- if(st!=ST_ERR)
- UART_Send_Str("用户卡PBOC文件打开错误!");
- CLRBuff();
- Request_loop();
- continue;
- UART_Send_Str(">>用户卡PBOC文件打开成功<<");
- CLRBuff();
- st=FM1208_Read_Binary(FM1208_DF_0015_Flag[1],g_cReceBuf, 0x1E ); //读取0015文件公共应用基本数据//
- if(st!=0x9000)
- if(st!=ST_ERR)
- UART_Send_Str("公共应用基本文件读取失败:");
- CLRBuff();
- Request_loop();
- continue;
- UART_Send_Str(">>公共应用基本文件读取成功<<");
- memcpy(Serial_Num, &g_cReceBuf[12], 8); //拷入用户卡序号
- UART_Send_Str("用户卡序号:");
- UART_Put_Num(Serial_Num,8); //用户卡序号
- UART_Send_Str("启动日期:");
- UART_Put_Num(&g_cReceBuf[20],4); //这里可做判断一张卡的生命周期
- UART_Send_Str("停用日期:");
- UART_Put_Num(&g_cReceBuf[24],4);
- //主要是用户卡判断终端的合法性,即是否是有人伪造的终端机
- st=FM1208_GetChallenge(8,Challenge_Num); //从用户卡取一组随机数//
- if(st!=0x9000)
- if(st!=ST_ERR)
- UART_Send_Str("用户卡读取随机码错误:");
- CLRBuff();
- Request_loop();
- continue;
- UART_Send_Str("取得随机数");
- UART_Put_Num(Challenge_Num,8);
- CLRBuff();
- st=Init_for_descrypt(Serial_Num, 0x8, 0x27,DF_ExKey_Flag, g_cReceBuf); //用3DE初始化 1级分散产生过程密钥 27--密钥用途,为加密密钥
- if(st!=SAM_OK)
- UART_Send_Str("SAM卡的3DES初始化失败:");
- CLRBuff();
- Request_loop();
- continue;
- CLRBuff();
- st=Descrypt(Challenge_Num, 0x8, 0, g_cReceBuf, 0x8 ); //3DES算法 对刚才临时保存的随机数进行加密//
- if(st!=SAM_OK)
- UART_Send_Str("SAM卡的3DES计算错误:");
- CLRBuff();
- Request_loop();
- continue;
- UART_Send_Str("外部认证的加密结果:");
- UART_Put_Num(g_cReceBuf,8);
- memcpy(Temporary_Key, g_cReceBuf, 8); //临时保存加密结果
- CLRBuff();
- st=FM1208_External_Authenticate(DF_ExKey_Flag,Temporary_Key,g_cReceBuf);
- if(st!=0x9000)
- if(st!=ST_ERR)
- UART_Send_Str("终端POS机非法,外部认证错误:");
- CLRBuff();
- Request_loop();
- continue;
- UART_Send_Str("外部认证成功,终端POS机合法!");
- //主要用于终端判断卡的合法性,也就是说你这张用户卡是否能在我的终端上使用
- st=Get_challenge(Challenge_Num, 8); //从SAM卡里取一组随机数//
- if(st!=SAM_OK)
- UART_Send_Str("SAM卡读取随机码错误:");
- CLRBuff();
- Request_loop();
- continue;
- CLRBuff();
- st=FM1208_Inital_Authenticate(DF_Inital_Key_Flag, 8, Challenge_Num,g_cReceBuf); //用户卡内部认证,加密该随机数//
- if(st!=0x9000)
- UART_Send_Str("内部认证错误:");
- CLRBuff();
- Request_loop();
- continue;
- CLRBuff();
- st=Init_for_descrypt(Serial_Num, 0x8, 0x2C, DF_Inital_Key_Flag, g_cReceBuf); //用3DE初始化 1级分散产生过程密钥 2C--密钥用途,为解密密钥
- if(st!=SAM_OK)
- CLRBuff();
- Request_loop();
- continue;
- CLRBuff();
- st=Descrypt(Temporary_Key, 0x8, 0, g_cReceBuf, 0x8 ); //3DES算法 对刚才临时保存的加密了的数据进行解密//
- if(st!=SAM_OK)
- CLRBuff();
- Request_loop();
- continue;
- UART_Send_Str("内部认证的解密结果:");
- for(i=0;i<8;i++)
- if(g_cReceBuf[i]!=Challenge_Num[i]) //这里判断卡的合法性//
- status=1;
- break;
- if(status==1)
- status=0;
- UART_Send_Str("非法卡!不能在本终端使用!");
- CLRBuff();
- Request_loop();
- continue;
- UART_Send_Str("内部认证成功,用户卡合法!");
- CLRBuff();
- st=FM1208_Read_Binary(FM1208_DF_0016_Flag[1],g_cReceBuf, 0x27 ); //读取0016文件持卡人基本信息
- if(st!=0x9000)
- if(st!=ST_ERR)
- UART_Send_Str("持卡人基本信息文件读取失败:");
- CLRBuff();
- Request_loop();
- continue;
- UART_Send_Str(">>持卡人基本信息文件读取成功<<");
- UART_Send_Str("卡类型标识:");
- UART_Put_Num(&g_cReceBuf[0],1);
- UART_Send_Str("本行职工标识:");
- UART_Put_Num(&g_cReceBuf[1],1);
- UART_Send_Str("持 卡 人 的姓名:");
- UART_Send_Str(&g_cReceBuf[2]);
- NameToStr(&g_cReceBuf[2]);
- UART_Send_Str("持 卡 人 的证件类型:");
- UART_Put_Num(&g_cReceBuf[38],1);
- UART_Send_Str("持 卡 人 的证件号码:");
- UART_Put_Num(&g_cReceBuf[22],16);
- CLRBuff();
- DataBuf[0]=DPKey_Flag; //1个字节的消费密钥标识
- memcpy(&DataBuf[1], Purchase_Pay, 4); //4个字节的交易金额,即扣款金额
- memcpy(&DataBuf[5], POSNum, 6); //6个字节的终端机编号
- st=FM1208_Initalize_For_Purchase(EP, DataBuf,g_cReceBuf,tt); //消费初始化操作//
- if(st!=0x9000)
- if(st!=ST_ERR)
- UART_Send_Str("初始化消费错误:");
- UART_Put_Num(g_cReceBuf,tt[0]); //当返回9403时,此时检查一下你的用户卡里面的消费密钥的标识号,是否对应?
- if(st==0x9401)
- DisNotMoney(); //卡余额不足
- DelayMs(2000);
- CLRBuff();
- Request_loop();
- continue;
- UART_Send_Str(">>消费初始化成功<<");
- UART_Send_Str("电子钱包未消费前的余额:");
- UART_Put_Num(g_cReceBuf,4);
- UART_Send_Str("电子钱 包 交 易序号:");
- UART_Put_Num(&g_cReceBuf[4],2);
- UART_Send_Str(" 限 额:");
- UART_Put_Num(&g_cReceBuf[6],3);
- UART_Send_Str("密钥版本号:");
- UART_Put_Num(&g_cReceBuf[9],1);
- UART_Send_Str("算法标识:");
- UART_Put_Num(&g_cReceBuf[10],1);
- UART_Send_Str("伪随机码:");
- UART_Put_Num(&g_cReceBuf[11],4);
- PAY=g_cReceBuf[2]<<8;
- PAY|=g_cReceBuf[3];
- Dis_Money(NameLen,NameBuf,PAY); //屏显示消费前的余额
- memcpy(DataBuf, &g_cReceBuf[11], 4); //拷伪随机数
- memcpy(&DataBuf[4], &g_cReceBuf[4], 2); //用户卡交易序号
- memcpy(&DataBuf[6], Purchase_Pay, 4); //交易金额
- DataBuf[10]=0x06; //交易类型
- memcpy(&DataBuf[11], DateTime, 7); //交易日期时间
- DataBuf[18]=DPKey_Flag; //消费密钥版本标识号
- DataBuf[19]=0x00; //算法标识,3DES
- memcpy(&DataBuf[20], Serial_Num, 8); //用户卡序号
- memcpy(&DataBuf[28], S_KEY_2, 8); //分散因子2(为各成员银行标识)
- memcpy(&DataBuf[36], S_KEY_1, 8); //分散因子1(为各城市标识)
- st=Init_SAM_For_Purchase(DataBuf, 0x2C, g_cReceBuf); //MAC1计算初始化//
- if(st!=SAM_OK)
- UART_Send_Str("MAC1计算错误:"); //当返回9403时,此时检查一下你的SAM卡里面的消费密钥的版本标识号,是否对应?
- UART_Put_Num(g_cReceBuf,0x02);
- CLRBuff();
- Request_loop();
- continue;
- UART_Send_Str(">>MAC1计算初始化成功<<");
- UART_Send_Str("终端交易序号:");
- UART_Put_Num(g_cReceBuf,0x04);
- UART_Send_Str("返回的MAC1码:");
- UART_Put_Num(&g_cReceBuf[4],0x04);
- memcpy(DataBuf, g_cReceBuf, 4); //拷终端交易序号
- memcpy(&DataBuf[4], DateTime, 7); //拷交易日期时间
- memcpy(&DataBuf[11], &g_cReceBuf[4], 4); //拷MAC1
- st=FM1208_Debit_For_Capp_Purchase(DataBuf,g_cReceBuf,tt); //消费命令//
- if(st!=0x9000)
- if(st!=ST_ERR)
- UART_Send_Str("扣款失败:");
- UART_Put_Num(g_cReceBuf,tt[0]); //当返回9302时,此时检查一下你的密钥因子是否正确,包括用户卡序列号,成员银行及城市代码,由于密钥因子错了,分散出的过程密钥也是错的,所以计算出的MAC也是错的
- DisCardfail();
- CLRBuff();
- Request_loop();
- continue;
- UART_Send_Str("用户卡返回的交易验证TAC:");
- UART_Send_Str("用户卡返回的MAC1:");
- UART_Put_Num(&g_cReceBuf[4],4);
- memcpy(DataBuf, &g_cReceBuf[4], 4); //拷MAC2,然后发送给PSAM卡进行校验
- st=Credit_SAM_For_Purchase(DataBuf, g_cReceBuf); //MAC2校验//
- if(st!=SAM_OK)
- UART_Send_Str("校验MAC2错误:");
- DisCardfail();
- CLRBuff();
- Request_loop();
- continue;
- UART_Send_Str("扣款MAC2校验成功!");
- st=FM1208_ReadNomey(EP ,g_cReceBuf); //读充值后的余额//
CPU卡定额消费带PSAM卡操作并显示屏显示.zip
(222.9 KB, 下载次数: 261)
