程序代码(需要请留):
功能说明:贪吃蛇
编译环境:keil4
MCU :STC89C52RC
时钟频率: 22.1184MHz
_|__| O|
\/ /~ \_/ \
\____|__________/ \
\_______ \
/ / _----_ \ \
/ / _-~ ~-_ | |
( ( _-~ _--_ ~-_ _/ |
\ ~-____-~ _-~ ~-_ ~-_-~ /
~-_ _-~ ~-_ _-~
~--______-~ ~-___-~
#include "stc.h"
#include "Lcd12864.h"
#include "Key.h"
static unsigned long Seed = 1;
#define A 48271L
#define M 2147483647L
#define Q (M / A)
#define R (M % A)
伪随机数发生器
double Random(void)
long TmpSeed;
TmpSeed=A*(Seed%Q)-R*(Seed/Q);
if(TmpSeed>=0)
Seed=TmpSeed;
Seed=TmpSeed+M;
return (double)Seed/M;
为伪随机数发生器播种
void InitRandom(unsigned long InitVal)
Seed=InitVal;
//延时子程序
void delay(unsigned int t)
unsigned int i,j;
for(i=0;i<t;i++)
for(j=0;j<10;j++);
初始化MPU
void InitCpu(void)
TMOD=0x01;
TH0=0;
TL0=0;
TR0=1;
ET0=1;
EA=1;
#define N 25
struct Food
unsigned char x;
unsigned char y;
unsigned char yes;
}food;//食物结构体
struct Snake
unsigned char x[N];
unsigned char y[N];
unsigned char node;
unsigned char direction;
unsigned char life;
}snake;//蛇结构体
unsigned char Flag=0;
unsigned char Score=0;
unsigned char Speed=5; //speed越大,速度越慢
unsigned char KeyBuffer=0;
#define FUNC 1 //(P3^1)表示级别
#define UP 2 //(P3^3)表示左
#define DOWN 3 //(P3^5)表示右
#define LEFT 4 //(P3^4)表示下
#define RIGHT 5 //(P3^2)表示上
#define PASSSCORE 20 //预定义过关成绩
void Timer0Int(void) interrupt 1
switch(OSReadKey())
case 5:
KeyBuffer=FUNC; //表示级别
/*if(++Speed>=10)
Speed=1;
Flag|=1<<1;//速度变化标志置1*/
break;
case 21:
KeyBuffer=DOWN; //表示右
/*if(snake.direction!=2)
snake.direction=1;*/
break;
case 13:
KeyBuffer=UP; //表示左
/*if(snake.direction!=1)
snake.direction=2;*/
break;
case 9:
KeyBuffer=RIGHT; //表示上
/*if(snake.direction!=4)
snake.direction=3;*/
break;
case 17:
KeyBuffer=LEFT; //表示下
/*if(snake.direction!=3)
snake.direction=4;*/
break;
default:
break;
画墙壁,初始化界面
void DrawBoard(void)
unsigned char n;
for(n=0;n<31;n++)
Lcd_Rectangle(3*n,0,3*n+2,2,1);
Lcd_Rectangle(3*n,60,3*n+2,62,1);
for(n=0;n<21;n++)
Lcd_Rectangle(0,3*n,2,3*n+2,1);
Lcd_Rectangle(90,3*n,92,3*n+2,1);
Lcd_HoriLine(93,31,35,1);
Lcd_HoriLine(93,63,35,1);
打印成绩
void PrintScore(void)
unsigned char Str[3];
Lcd_WriteStr(6,0,"成绩");
Str[0]=(Score/10)|0x30;//十位
Str[1]=(Score%10)|0x30;//个位
Str[2]=0;
Lcd_WriteStr(7,1,Str);
打印速度级别
void PrintSpeed(void)
unsigned char Str[2];
Lcd_WriteStr(6,2,"级别");
Str[0]=Speed|0x30;
Str[1]=0;
Lcd_WriteStr(7,3,Str);
游戏结束处理
void GameOver(void)
unsigned char n;
Lcd_Rectangle(food.x,food.y,food.x+2,food.y+2,0);//消隐出食物
for(n=1;n<snake.node;n++)
Lcd_Rectangle(snake.x[n],snake.y[n],snake.x[n]+2,snake.y[n]+2,0);//消隐食物,蛇头已到墙壁内,故不用消去
if(snake.life==0)//如果蛇还活着
Lcd_WriteStr(2,1,"过关");
else //如果蛇死了
Lcd_WriteStr(2,1,"输了");
Lcd_WriteStr(1,2,"游戏结束");
游戏的具体过程,也是贪吃蛇算法的关键部分
void GamePlay(void)
unsigned char n;
InitRandom(TL0);
food.yes=1;//1表示需要出现新事物,0表示已经存在食物尚未吃掉
snake.life=0;//表示蛇还活着
snake.direction=DOWN;
snake.x[0]=6;snake.y[0]=6;
snake.x[1]=3;snake.y[1]=6;
snake.node=2;
PrintScore();
PrintSpeed();
if(food.yes==1)
food.x=Random()*85+3;
food.y=Random()*55+3;//获得随机数
while(food.x%3!=0)
food.x++;
while(food.y%3!=0)
food.y++;
for(n=0;n<snake.node;n++)//判断产生的食物坐标是否和蛇身重合
if((food.x==snake.x[n])&&(food.y==snake.y[n]))
break;
if(n==snake.node)
food.yes=0;
break;//产生有效的食物坐标
if(food.yes==0)
Lcd_Rectangle(food.x,food.y,food.x+2,food.y+2,1);
for(n=snake.node-1;n>0;n--)
snake.x[n]=snake.x[n-1];
snake.y[n]=snake.y[n-1];
switch(snake.direction)
case DOWN:snake.x[0]+=3;break;
case UP:snake.x[0]-=3;break;
case RIGHT:snake.y[0]-=3;break;
case LEFT:snake.y[0]+=3;break;
default:break;
for(n=3;n<snake.node;n++)//从第三节开始判断蛇头是否咬到自己
if(snake.x[n]==snake.x[0]&&snake.y[n]==snake.y[0])
GameOver();
snake.life=1;
break;
if(snake.x[0]<3||snake.x[0]>=90||snake.y[0]<3||snake.y[0]>=60)//判蛇头是否撞到墙壁
GameOver();
snake.life=1;
if(snake.life==1)
break;//蛇死,则跳出while(1)循环
if(snake.x[0]==food.x&&snake.y[0]==food.y)//判蛇是否吃到食物
Lcd_Rectangle(food.x,food.y,food.x+2,food.y+2,0);//消隐食物
snake.x[snake.node]=200;
snake.y[snake.node]=200;//产生蛇新的节坐标先放在看不见的位置
snake.node++;//蛇节数加1
food.yes=1;//食物标志置1
if(++Score>=PASSSCORE)
PrintScore();
GameOver();
break;
PrintScore();
Lcd_Rectangle(snake.x[n],snake.y[n],snake.x[n]+2,snake.y[n]+2,1);
}//根据蛇的节数画出蛇
delay(Speed*1000); //调速
delay(Speed*1000);
Lcd_Rectangle(snake.x[snake.node-1],snake.y[snake.node-1],snake.x[snake.node-1]+2,snake.y[snake.node-1]+2,0);
switch(KeyBuffer)
case FUNC:
KeyBuffer=0;
if(++Speed>=10)
Speed=1;
PrintSpeed();
break;
case DOWN:
KeyBuffer=0;
if(snake.direction!=UP)
break;
case UP:
KeyBuffer=0;
if(snake.direction!=DOWN)
snake.direction=UP;
break;
case RIGHT:
KeyBuffer=0;
if(snake.direction!=LEFT)
snake.direction=RIGHT;
break;
case LEFT:
KeyBuffer=0;
if(snake.direction!=RIGHT)
snake.direction=LEFT;
break;
default:
break;
}//结束while(1)
void Main()
InitCpu();//初始化CPU
Lcd_Reset(); //初始化LCD屏
Lcd_WriteStr(2,1,"航峰兴业");
delay(5000);
delay(5000);
Lcd_WriteCmd(0x01); //清除显示,并且设定地址指针为00H
Lcd_Clear(0);//清屏
DrawBoard();//画界面
GamePlay();//玩游戏
GameOver();//游戏结束
while(1);//要想重玩,只能重启,可继续完善该游戏
