代码示例:
- using System;
- using System.Collections.Generic;
- using System.ComponentModel;
- using System.Data;
- using System.Drawing;
- using System.Linq;
- using System.Text;
- using System.Threading.Tasks;
- using System.Windows.Forms;
- namespace 步进电机调试
- public partial class Form1 : Form
- public Form1()
- InitializeComponent();
- System.Windows.Forms.Control.CheckForIllegalCrossThreadCalls = false;
- static Int16 speed_add = 0x01;
- static Int16 direction_data_clockwise = 0x11; //顺时针
- static Int16 direction_data_anticlockwise = 0x12; //逆时针
- private void button1_Click(object sender, EventArgs e)
- if (textBox2.Text != "" & textBox3.Text != "" & (radioButton1.Checked | radioButton2.Checked) & comboBox1.Text != "" & comboBox2.Text != "")
- if (button1.Text == "打开串口")
- serialPort1.PortName = comboBox1.Text;
- serialPort1.BaudRate = Convert.ToInt32(comboBox2.Text);
- try
- { serialPort1.Open(); }
- catch { MessageBox.Show("串口不存在"); }
- button1.Text = "关闭串口";
- //label3.Text = serialPort1.ReadExisting();
- else
- button1.Text = "打开串口";
- serialPort1.Close();
- else
- { MessageBox.Show("请填入相关参数"); }
- byte[] data = new byte[5];//方向+(速度1+速度2)+圈数+路程
- private void trackBar1_Scroll(object sender, EventArgs e)
- ushort y, x;
- if (radioButton1.Checked)
- data[0] = Convert.ToByte(direction_data_clockwise);//将方向数据放入data中
- else
- data[0] = Convert.ToByte(direction_data_anticlockwise);
- serialPort1.Write(data, 0, 1);
- //速度1
- textBox1.Text = trackBar1.Value.ToString(); //滚动条的值转为字符串显示于Textbox1
- y = Convert.ToUInt16(trackBar1.Value);
- data[1] = Convert.ToByte((y & 0xff00) >> 8);
- serialPort1.Write(data, 1, 1);
- //速度2
- data[2] = Convert.ToByte(y & 0x00ff);
- serialPort1.Write(data, 2, 1);
- //圈速
- data[3] = Convert.ToByte(textBox2.Text);
- serialPort1.Write(data, 3, 1);
- //角度
- data[4] = Convert.ToByte(textBox3.Text);
- serialPort1.Write(data, 4, 1);
- label10.Text = "转动";
- private void textBox1_TextChanged(object sender, EventArgs e)
- try
- trackBar1.Value = Convert.ToInt32(textBox1.Text);
- catch
- private void serialPort1_DataReceived(object sender, System.IO.Ports.SerialDataReceivedEventArgs e)
- Int16 a;
- a = Convert.ToInt16(serialPort1.ReadExisting());
- if (a == 0x88)
- label10.Text = "停止";
- private void Form1_Load(object sender, EventArgs e)
- private void radioButton2_CheckedChanged(object sender, EventArgs e)
- private void radioButton2_Click(object sender, EventArgs e)
- /* try
- ushort y;
- else
- catch { MessageBox.Show("出错,检查串口"); }*/
- private void radioButton1_Click(object sender, EventArgs e)
- /* ushort y;
- else
- serialPort1.Write(data, 2, 1);*/
- private void button2_Click(object sender, EventArgs e)
- try
- ushort y, x;
- else
- //速度1
- //速度2
- //圈速
- //角度
- catch
- MessageBox.Show("请检查错误");
