用数码管的前两位显示一个十进制数,,变化范围为00~59,开始时显示00,每按下S2键一次,数值加1;每按下S3键一次,数值减一;每按下S4键一次,数值归零;按下S5键一次,利用定时器功能使数值开始自动每秒加1,再次按下S5键,数值停止自动加1,保持显示原数。
#include<reg52.h>
sbit key1=P3^4;
sbit key2=P3^5;
sbit key3=P3^6;
sbit key4=P3^7;
sbit dula=P2^6;
sbit wela=P2^7;
uchar code table[]={
0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x7c};
void delayms(uint);
uchar num0,num;
void display(uint num)
uint shi,ge;
shi=num/10;
ge=num%10;
dula=1;
P0=table[shi];
dula=0;
P0=0xff;
wela=1;
P0=0xfe;
wela=0;
delayms(5);
dula=1;
P0=table[ge];
dula=0;
P0=0xff;
wela=1;
P0=0xfd;
wela=0;
delayms(5);
void delayms(uint xms)
uint i,j;
for(i=xms;i>0;i--)
for(j=110;j>0;j--);
void init()
TMOD=0x01;
TH0=(65536-45872)/256;
TL0=(65536-45872)%256;
EA=1;
ET0=1;
void keyscans()
if(key1==0)
delayms(10);
if(key1==0)
num++;
if(num==60)
num=0;
while(!key1);
if(key2==0)
delayms(10);
if(key2==0)
if(num==0)
num=60;
num--;
while(!key2);
if(key3==0)
delayms(10);
if(key3==0)
num=0;
while(!key3);
if(key4==0)
delayms(10);
if(key4==0)
while(!key4);
TR0=~TR0;
init();
keyscans();
display(num);
void T0_time()interrupt 1
num0++;
if(num0==20)
num0=0;
num++;
if(num==60)
num=0;
