查看: 4028|回复: 2
单片机外部中断0和1控制两位数码管进行计数源程序+Proteus仿真
ID:634529 发表于 2019-11-3 10:45 | 显示全部楼层 |阅读模式
  1. #include <reg52.h>
  2. #define uint unsigned int
  4. sbit LED1=P2^0;
  5. sbit LED2=P2^1;
  6. sbit LED3=P2^2;
  7. sbit LED4=P2^3;
  8. sbit LED5=P0^4;
  9. sbit LED6=P0^5;
  10. sbit LED7=P0^6;
  11. sbit LED8=P0^7;
  12. sbit LEVEL=P2^6;//LEVEL,P2.4引脚上的电平值
  13. sbit LEVEL1=P2^5;
  14. sbit LEVEL2=P2^6;
  15. sbit LEVEL3=P2^7;
  16. uchar highcount;        //记录高电平定时次数
  17. uchar zhaowei=0,zhaoweide=0;
  18. uchar count;
  19. uchar counth,countl,count2,count3;
  20. const uchar tab[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,}; /*显示0~9*/
  21. const uchar tab1[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,}; /*显示0~9*/
  22. void delay()
  23. {
  24.   uint i,j;
  25.   for(i=0;i<256;i++);
  26.     for(j=0;j<256;j++);
  27. }
  28. void timer0isr(void) interrupt 1 using 1
  29. {
  30.         TH0 = 0xD8;
  31.         TL0 = 0xF0;   //重置计数初值
  32.         highcount++;           //溢出次数加1
  33.         if(highcount == zhaowei)
  34.         {
  35.                 LEVEL = 0;
  36.                 if(highcount==100)
  37.                 {
  38.                         highcount=0;
  39.         }
  40. }
  41.         if(highcount == zhaoweide)
  42.         {
  43.                 LEVEL = 1;
  44.                 if(highcount==100)
  45.                 {
  46.                         highcount=0;
  47.         }
  48. }
  49. }
  50. void int0( ) interrupt 0 using 1
  51. {
  52. zhaowei=zhaowei+5;
  53.                 if(zhaowei==100)
  54.                 zhaowei=0;
  55. }
  56. void int1( ) interrupt 2 using 2
  57. {
  58. zhaoweide=zhaoweide+5;
  59.         if(zhaoweide==100)
  60.                 zhaoweide=0;
  61. }
  62. void main(void)
  63. {
  64.         zhaowei=0;
  65.         zhaoweide=0;
  66.         highcount = 0;          //记录高电平定时次数
  67.         TMOD = 0x01;  //设定T/C0工作在定时器方式1
  68.         LEVEL = 0;        //初始电平为高
  69.         TH0 = 0xD8;
  70.         TL0 = 0xF0;         //装载计数初值
  71.         EA = 1;                 //开总中断
  72.         ET0 = 1;         //开T/C0中断
  73.         TR0 = 1;         //启动T/C0
  74.   IT0=1;
  75.   IT1=1;
  76.   EX0=1;
  77.   EX1=1;
  78.   PX1=1;
  79.   while(1)
  80.   {
  81.     counth=zhaowei/10;
  82.     countl=zhaowei%10;
  83.     P1=tab[counth];
  84.     LED1=1;
  85.     delay();
  86.                 LEVEL1=0;
  87.     LED1=0;
  88.           P1=tab[countl];
  89.     LED2=1;
  90.     delay();
  91.                 LEVEL1=1;
  92.     LED2=0;
  93.                 //第二段数码管
  94.                 count2=zhaoweide/10;
  95.     count3=zhaoweide%10;
  96.     P0=tab1[count2];
  97.     LED3=1;
  98.     delay();
  99.                 LEVEL3=0;
  100.     LED3=0;
  101.           P1=tab1[count3];
  102.     LED4=1;
  103.                 delay();
  104.                 LEVEL3=0;
  105.     LED4=0;
  106.    }
  107. }
由于我是新手以上资料肯定存在一些错误,欢迎大家批评指正,一起学习 提高技术(仅供参考 切勿照搬):
利用定时器产生脉冲.zip (184.24 KB, 下载次数: 41)
ID:98992 发表于 2019-11-5 12:06 | 显示全部楼层
不错很好 学习学习
ID:564430 发表于 2020-5-7 16:43 | 显示全部楼层
附件里仿真文件和说的不一样哦,仿真只是单纯加减数
