- #include<reg52.h> //包含头文件,一般情况不需要改动,头文件包含特殊功能寄存器的定义
- sbit IR=P3^2; //红外接口标志
- #define DataPort P0 //定义数据端口 程序中遇到DataPort 则用P0 替换
- sbit LATCH1=P2^2;//定义锁存使能端口 段锁存
- sbit LATCH2=P2^3;// 位锁存
- unsigned char code dofly_DuanMa[10]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};// 显示段码值0~9
- unsigned char irtime;//红外用全局变量
- bit irpro_ok,irok;
- unsigned char IRcord[4];
- unsigned char irdata[33];
- void Ir_work(void);
- void Ircordpro(void);
- unsigned char code dofly_WeiMa[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};//分别对应相应的数码管点亮,即位码
- unsigned char TempData[8]; //存储显示值的全局变量
- void delay(unsigned int t); //函数声明
- void Display();
- void asd(unsigned char t);
- void shaomiao(void);
- #define AddWr 0x90 //写数据地址
- #define AddRd 0x91 //读数据地址
- #define _Nop() _nop_() //定义空指令
- bit ack; //应答标志位
- sbit SDA=P2^1;
- sbit SCL=P2^0;
- unsigned char RcvByte();
- extern bit ack; //外部点应答
- unsigned char ReadADC(unsigned char Chl);
- void Start_I2c();
- void Stop_I2c();
- void SendByte(unsigned char c);
- void NoAck_I2c(void);
- void _nop_(void);
- void guang(void);
- void zhixing(void);
- long num;
- unsigned char kkk;
- void mjian(void);
- void mjia(void);
- void hjian(void);
- void hjia(void);
- void jieshu(void);
- void kaiguan(void);
- void kaiguan()
- { kkk++;
- while(kkk==2)
- kkk=0;
- void jieshu()
- { P1=0xff;
- DataPort=0; //清空数据,防止有交替重影
- LATCH1=1; //段锁存
- LATCH1=0;
- kkk++;
- if(kkk==2)
- {kkk=0;}
- void mjian()
- { num=num-60;
- if(num<=0)
- {num=86400+num;}
- zhixing();
- void mjia()
- { num=num+60;
- if(num>=86400)
- {num=num-86400;}
- zhixing();
- void hjian()
- { num=num-3600;
- if(num<=0)
- {num=86400+num;}
- zhixing();
- void hjia()
- { num=num+3600;
- if(num>=86400)
- {num=num-86400;}
- zhixing();
- { if(irok) //如果接收好了进行红外处理
- Ircordpro();
- irok=0;
- if(irpro_ok) //如果处理好后进行工作处理,如按对应的按键后显示对应的数字等
- Ir_work();
- num=t*3600 ;
- zhixing();
- void zhixing()
- unsigned char i;
- while(num>0)
- {for(i=0;i<82;i++)
- TempData[0]=dofly_DuanMa[num/36000];
- TempData[1]=dofly_DuanMa[(num/3600)%10];
- TempData[2]=0x40;
- TempData[3]=dofly_DuanMa[(num%3600)/600];
- TempData[4]=dofly_DuanMa[(num%600)/60];
- TempData[5]=0x40;
- TempData[6]=dofly_DuanMa[(num%60)/10];
- TempData[7]=dofly_DuanMa[(num%60)%10];
- Display();
- shaomiao();
- if(kkk==0)
- {guang();}
- num--;
- jieshu();
- void Delay(unsigned int t)
- while(--t);
- void Display()
- unsigned char i;
- for(i=0;i<8;i++)
- LATCH1=1; //段锁存
- LATCH1=0;
- DataPort=dofly_WeiMa[i]; //取位码
- LATCH2=1; //位锁存
- LATCH2=0;
- DataPort=TempData[i]; //取显示数据,段码
- LATCH1=1; //段锁存
- LATCH1=0;
- Delay(80); // 扫描间隙延时,时间太长会闪烁,太短会造成重影
- void tim0_isr (void) interrupt 1 using 1
- irtime++; //用于计数2个下降沿之间的时间
- void EX0_ISR (void) interrupt 0 //外部中断0服务函数
- static unsigned char i; //接收红外信号处理
- static bit startflag; //是否开始处理标志位
- if(startflag)
- if(irtime<63&&irtime>=33)//引导码 TC9012的头码,9ms+4.5ms
- i=0;
- irdata[i]=irtime;//存储每个电平的持续时间,用于以后判断是0还是1
- irtime=0;
- i++;
- if(i==33)
- irok=1;
- i=0;
- else
- irtime=0;
- startflag=1;
- void TIM0init(void)//定时器0初始化
- TMOD=0x02;//定时器0工作方式2,TH0是重装值,TL0是初值
- TH0=0x00; //重载值
- TL0=0x00; //初始化值
- ET0=1; //开中断
- TR0=1;
- void EX0init(void)
- IT0 = 1; //指定外部中断0下降沿触发,INT0 (P3.2)
- EX0 = 1; //使能外部中断
- EA = 1; //开总中断
- void Ir_work(void)//红外键值散转程序
- switch(IRcord[2])//判断第三个数码值
- case 0x0c:asd(1);break;//1
- case 0x18:asd(2);break;//2
- case 0x5e:asd(3);break;//3
- case 0x08:asd(4);break;//4
- case 0x1c:asd(5);break;//5
- case 0x5a:asd(6);break;//6
- case 0x42:asd(7);break;//7
- case 0x52:asd(8);break;//8
- case 0x4a:asd(9);break;//9
- case 0x07:mjian();break;//9
- case 0x15:mjia();break;//9
- case 0x44:hjian();break;//9
- case 0x40:hjia();break;//9
- case 0x43:num=0;break;//9
- case 0x09:kaiguan();break;//9
- case 0x16:P1=0xff;;break;//9
- default:break;
- irpro_ok=0;//处理完成标志
- void Ircordpro(void)//红外码值处理函数
- unsigned char i, j, k;
- unsigned char cord,value;
- k=1;
- for(i=0;i<4;i++) //处理4个字节
- for(j=1;j<=8;j++) //处理1个字节8位
- cord=irdata[k];
- if(cord>7)//大于某值为1,这个和晶振有绝对关系,这里使用12M计算,此值可以有一定误差
- value|=0x80;
- if(j<8)
- value>>=1;
- k++;
- IRcord[i]=value;
- value=0;
- irpro_ok=1;//处理完毕标志位置1
- void main(void)
- EX0init(); //初始化外部中断
- TIM0init();//初始化定时器
- while(1)//主循环
- if(kkk==0)
- {guang();}
- if(irok) //如果接收好了进行红外处理
- Ircordpro();
- irok=0;
- Ir_work();
- unsigned char Val;
- Start_I2c(); //启动总线
- SendByte(AddWr); //发送器件地址
- if(ack==0)return(0);
- SendByte(0x40|Chl); //发送器件子地址
- Start_I2c();
- SendByte(AddWr+1);
- Val=RcvByte();
- NoAck_I2c(); //发送非应位
- Stop_I2c(); //结束总线
- return(Val);
- void Start_I2c()
- SDA=1; //发送起始条件的数据信号
- _Nop();
- SCL=1;
- _Nop(); //起始条件建立时间大于4.7us,延时
- _Nop();
- _Nop();
- _Nop();
- _Nop();
- SDA=0; //发送起始信号
- _Nop(); //起始条件锁定时间大于4μ
- _Nop();
- _Nop();
- _Nop();
- _Nop();
- SCL=0; //钳住I2C总线,准备发送或接收数据
- _Nop();
- _Nop();
- void Stop_I2c()
- SDA=0; //发送结束条件的数据信号
- _Nop(); //发送结束条件的时钟信号
- SCL=1; //结束条件建立时间大于4μ
- _Nop();
- _Nop();
- _Nop();
- _Nop();
- _Nop();
- SDA=1; //发送I2C总线结束信号
- _Nop();
- _Nop();
- _Nop();
- _Nop();
- unsigned char BitCnt;
- for(BitCnt=0;BitCnt<8;BitCnt++) //要传送的数据长度为8位
- if((c<<BitCnt)&0x80)SDA=1; //判断发送位
- else SDA=0;
- _Nop();
- SCL=1; //置时钟线为高,通知被控器开始接收数据位
- _Nop();
- _Nop(); //保证时钟高电平周期大于4μ
- _Nop();
- _Nop();
- _Nop();
- SCL=0;
- _Nop();
- _Nop();
- SDA=1; //8位发送完后释放数据线,准备接收应答位
- _Nop();
- _Nop();
- SCL=1;
- _Nop();
- _Nop();
- _Nop();
- if(SDA==1)ack=0;
- else ack=1; //判断是否接收到应答信号
- SCL=0;
- _Nop();
- _Nop();
- unsigned char retc;
- retc=0;
- SDA=1; //置数据线为输入方式
- _Nop();
- SCL=0; //置时钟线为低,准备接收数据位
- _Nop();
- _Nop(); //时钟低电平周期大于4.7us
- _Nop();
- _Nop();
- _Nop();
- SCL=1; //置时钟线为高使数据线上数据有效
- _Nop();
- _Nop();
- retc=retc<<1;
- if(SDA==1)retc=retc+1; //读数据位,接收的数据位放入retc中
- _Nop();
- _Nop();
- SCL=0;
- _Nop();
- _Nop();
- return(retc);
- SDA=1;
- _Nop();
- _Nop();
- _Nop();
- SCL=1;
- _Nop();
- _Nop(); //时钟低电平周期大于4μ
- _Nop();
- _Nop();
- _Nop();
- SCL=0; //清时钟线,钳住I2C总线以便继续接收
- _Nop();
- _Nop();
- void guang()
- unsigned char num1=0; //主循环
- num1=255-ReadADC(0);//值取差值,用于显示光强越小,数值越小
- if(num1 >=70)
- {P1=0xff;}
- else if(num1>=60)
- {P1=0xfe;}
- else if(num1>=50)
- {P1=0xfc;}
- else if(num1>=40)
- {P1=0xf8;}
- else if(num1>=30)
- {P1=0xf0;}
- else if(num1>=20)
- {P1=0xe0;}
- else if(num1>=10)
- {P1=0xc0;}
- else if(num1>=5)
- {P1=0x80;}
- else{P1=0x00;}
