查看: 2051|回复: 4
单片机+ADC0808芯片,现在精确度是0.05,希望精确度是0.02,求指导如何修改?
回帖奖励 50 黑币 回复本帖可获得 10 黑币奖励! 每人限 1 次
这是文件,里面有仿真和程序
数字电压表.rar (108.94 KB, 下载次数: 14)
这是程序
#include<reg52.h>
#define LCD_DB  P2
sbit LCD_RS = P1^0;
sbit LCD_RW = P1^1;
sbit LCD_EN = P1^2;
sbit AD_OE=P3^1;
sbit AD_EOC=P3^2;
sbit AD_A=P3^4;
sbit AD_B=P3^5;
sbit AD_C=P3^6;
sbit AD_START=P3^0;
unsigned char Zh1[]="    voltmeter   ";
unsigned char Zh2[]=" Voltage:       ";
unsigned char sj,ai;
int AD_sj=0,AD_ai=0;
void Busy()                 //检忙
    unsigned char sta;
    LCD_DB = 0xff;
    LCD_RS = 0;
    LCD_RW = 1;
    do
    LCD_EN = 1;
    sta = LCD_DB;
    LCD_EN = 0;
    while(sta&0x80);
void Lcd_Write_Cmd(unsigned char cmd)      //命令
    Busy();
    LCD_RS = 0;
    LCD_RW = 0;
    LCD_DB = cmd;
    LCD_EN = 1;
    LCD_EN = 0;
void Lcd_Write_Data(unsigned char dat)     //数据
    Busy();
    LCD_RS = 1;
    LCD_RW = 0;
    LCD_DB = dat;
    LCD_EN = 1;
    LCD_EN = 0;
void InitLcd()                            //初始化
    Lcd_Write_Cmd(0x38);
    Lcd_Write_Cmd(0x08);
    Lcd_Write_Cmd(0x01);
    Lcd_Write_Cmd(0x06);
    Lcd_Write_Cmd(0x0c);
void LcdSetCursor(unsigned char x,unsigned char y)   //坐标
    unsigned char addr;
    if(y == 0)
        addr = 0x00 + x;
        addr = 0x40 + x;
    Lcd_Write_Cmd(addr|0X80);
void LcdShowStr(unsigned char x,unsigned char y,unsigned char *s)  //字符串
    LcdSetCursor(x,y);
    while(*s)
        Lcd_Write_Data(*s);
        s++;
//AD转换
void AD_xsgs()  //显示格式
//    AD_sj=100- sj*5.00/25.5;
        AD_sj=5.00*100/255*sj;
    Zh2[10]=(AD_sj/100)+0x30;
    Zh2[11]='.';
    Zh2[12]=(AD_sj%100/10)+0x30;
    Zh2[13]=(AD_sj%100%10)+0x30;
    Zh2[14]='V';
void AD_csh()     //AD主程序
        AD_A=0;
        AD_B=0;
        AD_C=0;
        AD_START=1;
        AD_START=0;
        AD_OE=0;
        AD_START=1;
        AD_START=0;
        while(AD_EOC==1);
        AD_OE=1;
        sj=P0;
        AD_OE=0;
void ad ()
        AD_A=1;
        AD_B=0;
        AD_C=0;
        AD_START=1;
        AD_START=0;
        AD_OE=0;
        AD_START=1;
        AD_START=0;
        while(AD_EOC==1);
        AD_OE=1;
        ai=P0;
        AD_OE=0;
        InitLcd();
        LcdShowStr(0,0,Zh1);
    LcdShowStr(0,1,Zh2);
     AD_csh();
     AD_xsgs();
     ad ();
数字电压表.rar
175.59 KB, 下载次数: 7
收藏收藏1 分享淘帖 顶 踩
ID:648281 发表于 2020-5-14 08:35 | 只看该作者
你好!
1、首先,仿真里面可调电位器的变化量是1%
2、0808直接加外接时钟,实物测量没有任何意义
ID:213173 发表于 2020-5-14 08:41 | 只看该作者
分辨率可以做到0.02V,精确度做不到±0.02V。
ID:318131 发表于 2020-5-14 15:08 | 只看该作者
分辨率怎么改为0.02V呢,可以解释一下吗。麻烦了
ID:755472 发表于 2020-5-21 15:40 | 只看该作者
不容易做到
