#include < reg52.h >
#include < character.h >
#include < lcd.h >
#include < clock.h >
#include < sensor.h>
#include < calendar.h >
#include < key.h >
sbit bell = P2 ^ 0;
sbit LED1 = P2 ^ 6;
sbit LED2 = P2 ^7;
void Delay_ms(unsigned int t)
unsigned int i,j;
for(i=0;i<t;i++)
for(j=0;j<120;j++)
void Timer0_Service() interrupt 1
static uchar count = 0;
static uchar flag = 0;
count = 0;
TR0 = 0;
TH0 = 0x3c;
TL0 = 0XB0;
TR0 = 1 ;
count ++;
if( count == 20 )
bell = ~ bell;
count = 0;
flag ++;
if( flag == 6 )
flag = 0;
TR0 = 0;
uchar HexNum_Convert(uchar HexNum)
uchar Numtemp;
Numtemp=(HexNum>>4)*10+(HexNum&0X0F);
return Numtemp;
void main( void )
unsigned char wendu[2]={30,20};
unsigned char clock_time[6] = {0X00,0X59,0X23,0X09,0X04,0X11};
unsigned char alarm_time[12]={20,8,12,10,11,10,10,13,11,14,10,16};
unsigned char temperature[2] ,temperature1[2] ;
unsigned int zhengshuA,zhengshuB,zhengshu=0;
unsigned int xiaoshu_aA,xiaoshu_aB,xiaoshu_a;
unsigned int all;
zhengshuA=temperature[0]/16+temperature[1]*16;
xiaoshu_aA=(temperature[0]&0x0f)*10/16
zhengshuB=temperature1[0]/16+temperature1[1]*16
xiaoshu_aB=(temperature1[0]&0x0f)*10/16;
zhengshu=zhengshuA+zhengshuB;
xiaoshu_a=xiaoshu_aA+xiaoshu_aB;
all=(zhengshu*10+xiaoshu_a)/2;
Lcd_Initial();
Clock_Fresh( clock_time );
Clock_Initial( clock_time )
LED1=0;
LED2=0;
EA = 1
ET0 = 1;
ET2 = 1
TMOD = 0x01
RCAP2H = 0x3c
RCAP2L = 0xb0
while( 1
switch( Key_Scan()
case up_array:
Key_Idle()
break;
case down_array
Key_Idle()
break;
case clear_array:
Key_Idle()
break;
case function_array:
Key_Function( clock_time, alarm_time,wendu)
case null:
Lcd_Clock( clock_time )
Sensor_Fresh( temperature )
Sensor1_Fresh( temperature1 );
Delay_ms(1000);
Delay_ms(1000);
Lcd_Temperture( temperature )
Lcd_Temperture1( temperature1 )
Lcd_pingjun(temperature, temperature1);
Delay_ms(1000);
if((all)<(wendu[1]*10))
LED1=1;
LED2=0;
break;}
{if((all)>(wendu[0]*10))
LED2=1;
LED1=0;
break;}
else{LED2=0;
LED1=0;break;}}
break;}
