基于stm32mini实现bh1750测光照。
串口通信,波特率9600
接线说明:
SDA <-> PA3
SCL <-> PA2
VCC <-> VCC
GND <-> GND
ADDR <-> GND (取决于slave address )这里接地
main.c文件如下:
- #include "led.h"
- #include "delay.h"
- #include "sys.h"
- #include "usart.h"
- #include "BH1750.h"
- #include "lcd.h"
- int main(void)
- // float light;
- NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);// 设置中断优先级分组2
- delay_init(); //延时函数初始化
- uart_init(9600); //串口初始化为9600
- LED_Init(); //初始化与LED连接的硬件接口
- Init_BH1750(); //初始化BH1750
- LCD_Init(); //初始化LED
- LCD_Clear(WHITE); //清屏
- while(1)
- // light=read_BH1750(); //读取BH1750的光强数据
- extern float temp_integer;
- extern float temp_fractions;
- read_BH1750();
- LCD_ShowString(20,50,72,12,12,"light:");
- LCD_ShowNum(60,50,temp_integer,4,12);
- LCD_ShowString(84,50,12,12,12,".");
- LCD_ShowNum(90,50,temp_fractions,2,12);
- LCD_ShowString(110,50,12,12,12,"lx");
- if(temp_integer<100)
- LED1=0;
- LCD_ShowString(50,2,72,12,12,"LED-ON");
- else
- LED1=1;
- LCD_ShowString(50,2,72,12,12,"LED-OFF");
复制代码 bh1750.c如下:
- * 文件名 :bh1750.c
- * 描述 :光强传感模块
- #include "lcd.h"
- float temp_integer;
- float temp_fractions;
- uchar BUF[8]; //接收数据缓存区
- int mcy; //进位标志
- /***开始信号***/
- void BH1750_Start()
- SDA=1; //拉高数据线
- SCL=1; //拉高时钟线
- delay_us(5); //延时
- GPIO_ResetBits(bh1750_PORT, sda); //产生下降沿
- delay_us(5); //延时
- GPIO_ResetBits(bh1750_PORT, scl); //拉低时钟线
- /*****停止信号******/
- void BH1750_Stop()
- SDA=0; //拉低数据线
- SCL=1; //拉高时钟线
- delay_us(5); //延时
- GPIO_SetBits(bh1750_PORT, sda); //产生上升沿
- delay_us(5); //延时
- 发送应答信号
- 入口参数:ack (0:ACK 1:NAK)
- void BH1750_SendACK(int ack)
- GPIO_InitTypeDef GPIO_InitStruct;
- GPIO_InitStruct.GPIO_Mode = GPIO_Mode_Out_PP;
- GPIO_InitStruct.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_InitStruct.GPIO_Pin = sda;
- GPIO_Init(bh1750_PORT, &GPIO_InitStruct);
- if(ack == 1) //写应答信号
- SDA=1;
- else if(ack == 0)
- SDA=0;
- else
- return;
- SCL=1; //拉高时钟线
- delay_us(5); //延时
- SCL=0; //拉低时钟线
- delay_us(5); //延时
- 接收应答信号
- int BH1750_RecvACK()
- GPIO_InitStruct.GPIO_Mode=GPIO_Mode_IPU; /*这里一定要设成输入上拉,否则不能读出数据*/
- GPIO_InitStruct.GPIO_Speed=GPIO_Speed_50MHz;
- GPIO_InitStruct.GPIO_Pin=sda;
- GPIO_Init(bh1750_PORT,&GPIO_InitStruct);
- SCL=1; //拉高时钟线
- delay_us(5); //延时
- if(GPIO_ReadInputDataBit(GPIOA,sda)==1)//读应答信号
- mcy = 1 ;
- else
- mcy = 0 ;
- SCL=0; //拉低时钟线
- delay_us(5); //延时
- GPIO_InitStruct.GPIO_Mode=GPIO_Mode_Out_PP;
- return mcy;
- 向IIC总线发送一个字节数据
- void BH1750_SendByte(uchar dat)
- uchar i;
- for (i=0; i<8; i++) //8位计数器
- if( 0X80 & dat )
- GPIO_SetBits(bh1750_PORT,sda);
- else
- GPIO_ResetBits(bh1750_PORT,sda);
- dat <<= 1;
- SCL=1; //拉高时钟线
- delay_us(5); //延时
- SCL=0; //拉低时钟线
- delay_us(5); //延时
- BH1750_RecvACK();
- uchar BH1750_RecvByte()
- uchar i;
- uchar dat = 0;
- uchar bit;
- GPIO_InitStruct.GPIO_Mode = GPIO_Mode_IPU; /*这里一定要设成输入上拉,否则不能读出数据*/
- GPIO_Init(bh1750_PORT,&GPIO_InitStruct );
- GPIO_SetBits(bh1750_PORT,sda); //使能内部上拉,准备读取数据,
- dat <<= 1;
- SCL=1; //拉高时钟线
- delay_us(5); //延时
- if( SET == GPIO_ReadInputDataBit(bh1750_PORT,sda))
- bit = 0X01;
- else
- bit = 0x00;
- dat |= bit; //读数据
- SCL=0; //拉低时钟线
- delay_us(5); //延时
- GPIO_Init(bh1750_PORT, &GPIO_InitStruct );
- return dat;
- void Single_Write_BH1750(uchar REG_Address)
- BH1750_Start(); //起始信号
- BH1750_SendByte(SlaveAddress); //发送设备地址+写信号
- BH1750_SendByte(REG_Address); //内部寄存器地址,请参考中文pdf22页
- // BH1750_SendByte(REG_data); //内部寄存器数据,请参考中文pdf22页
- BH1750_Stop(); //发送停止信号
- //初始化BH1750,根据需要请参考pdf进行修改****
- void Init_BH1750()
- /*开启GPIOB的外设时钟*/
- RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOA, ENABLE);
- GPIO_InitStruct.GPIO_Pin = sda | scl ;
- Single_Write_BH1750(0x01);
- delay_ms(180); //延时180ms
- //连续读出BH1750内部数据
- void mread(void)
- uchar i;
- BH1750_SendByte(SlaveAddress+1); //发送设备地址+读信号
- for (i=0; i<3; i++) //连续读取6个地址数据,存储中BUF
- BUF[i] = BH1750_RecvByte(); //BUF[0]存储0x32地址中的数据
- if (i == 3)
- BH1750_SendACK(1); //最后一个数据需要回NOACK
- else
- BH1750_SendACK(0); //回应ACK
- BH1750_Stop(); //停止信号
- delay_ms(5);
- void read_BH1750(void)
- int dis_data; //变量
- // float temp_integer;
- // float temp_fractions;
- Single_Write_BH1750(0x01); // power on
- Single_Write_BH1750(0x10); // H- resolution mode
- mread(); //连续读出数据,存储在BUF中
- dis_data=BUF[0];
- dis_data=(dis_data<<8)+BUF[1]; //合成数据
- temp_integer=dis_data/1.2;
- temp_fractions=10*dis_data/1.2;
- temp_fractions=(int)temp_fractions%10;
- // return temp_integer;
复制代码 bh1750.h文件如下
- #ifndef __BH1750_H__
- #define __BH1750_H__
- #include "sys.h"
- #define uchar unsigned char
- #define uint unsigned int
- #define SDA PAout(3)
- #define SCL PAout(2)
- #define sda GPIO_Pin_3
- #define scl GPIO_Pin_2
- #define bh1750_PORT GPIOA
- #define SlaveAddress 0x46 //定义器件在IIC总线中的从地址,根据ALT ADDRESS地址引脚不同修改
- //ALT ADDRESS引脚接地时地址为0x46,接电源时地址为0xB8
- extern uchar BUF[8]; //接收数据缓存区
- extern int dis_data; //变量
- extern int mcy; //表示进位标志位
- void Init_BH1750(void);
- void conversion(uint temp_data);
- void Single_Write_BH1750(uchar REG_Address);//单个写入数据
- uchar Single_Read_BH1750(uchar REG_Address); //单个读取内部寄存器数据
- void mread(void); //连续的读取内部寄存器数据
- void read_BH1750(void);
- #endif
全部程序51hei下载地址:
bh1750程序.7z
(262.93 KB, 下载次数: 68)
